12-04-2012, 12:39 PM
#6136 | |
Oddometer: 310
Thanks again for this!!! ...
2000 Yamaha YZ250 2009 Yamaha YZ250 2013 Kawasaki Ninja 1000 |
12-04-2012, 12:51 PM
#6137 |
OX Ambassador
Oddometer: 413
For those who want an overview of which options are currently available when creating Shortcuts on Montana, you can see that here.
atlas cached screwed with this post 12-04-2012 at 02:56 PM |
12-04-2012, 01:14 PM
#6138 |
Oddometer: 66
Just received my replacement Amps Rugged Mount from Garmin. Looks like they fixed the security screw issue. Now I have 2, 1 with bad screw and 1 with good screw. Now I need another bike for the extra mount
12-04-2012, 03:37 PM
#6139 |
Procrastinators
Oddometer: 5,790
That reminds me - I should call Garmin and find out if they can send me a new Tempe to replace my flawed one.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
12-04-2012, 03:53 PM
#6140 | |
Procrastinators
Oddometer: 5,790
Yeah right. Like I'm going to do a Master Reset every morning I plan to use the unit.
12-04-2012, 04:38 PM
#6141 | |
OX Ambassador
Oddometer: 413
The quote about replacement Tempe units on the Montana wiki Tempe page is from Garmin Tech Support. Quote it back to them. |
12-04-2012, 06:59 PM
#6142 | |
Procrastinators
Oddometer: 5,790
I could always send it back to GPSCity too. I've still got the box.
12-05-2012, 09:06 AM
#6143 |
Oddometer: 71
The master reset doesn't work. I finally got mine replaced after many e-mails, and the new one works like it's supposed to. I don't know why they are so opposed to admitting there is problem with the first units that were shipped. Or do the tech support people really not understand how the Tempe works? The high and low temps are stored in the Tempe, and the reset has to occur in the Tempe unit. The GPS unit reading the Tempe data has no control over what the Tempe is sending it.
81husky screwed with this post 12-05-2012 at 09:08 AM Reason: spelling |
12-05-2012, 10:28 AM
#6144 | |
Oddometer: 124
I Just Like To Ride ![]() '03 BMW R1150GSA '06 BMW K1200LT |
12-05-2012, 10:44 AM
#6145 | |
OX Ambassador
Oddometer: 413
The issue IS a firmware bug in the original Tempe shipment. |
12-05-2012, 12:38 PM
#6146 |
Oddometer: 1,082
How do you diagnose the problem - I'm not sure that I understand. Does the initial min/max recorded temperature not change?
Operation: Battle Panda |
12-05-2012, 12:50 PM
#6147 |
Procrastinators
Oddometer: 5,790
If anyone's looking for a Montana 600, they're $399 Canadian at GPSCentral.ca until December 12.
12-05-2012, 12:54 PM
#6148 |
Procrastinators
Oddometer: 5,790
That's right. Whatever the highest and lowest temps the Tempe has seen and recorded to the gps is always retained unless you remove the Tempe battery for 30 seconds.
12-05-2012, 01:27 PM
#6149 |
Oddometer: 167
I finally got my AMPS Rugged Mount yesterday. I wired it up, mounted it, and then found that the damned lock screw doesn't reach the threads. I know about the issue and meant to test it before I went through the trouble of running the wires, etc. bummer.
Quick question: do I contact Garmin or do I contact the vendor from whom I purchased the item, in order to get it replaced? Also, will they take back the old one if I've chopped off the three data wires? Doh.... |
12-05-2012, 01:38 PM
#6150 | |
OX Ambassador
Oddometer: 413
