Thread Tools Search this Thread Rating: Thread Rating: 433 votes, 4.94 average. Display Modes
Old 12-21-2012, 03:46 PM   #6316
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,668
Originally Posted by Emoto View Post
What are you guys liking for a protective carrying case to keep the unit in when not in use?
In spite of all of the good suggestions, I kept looking, hoping to find that elusive nice protective case for not a lot of money.
I think we have a winner. I bought "The Classic Case - Camera / Hard Drive / GPS Case" by HandStands on Amazon. They did not claim it fit the Montana or any other specific GPS from what I could see, but did list the dimensions, which looked fairly close, so I took a chance. It was only $6.99 and eligible for the regular free shipping deal. Link: http://www.amazon.com/gp/product/B00...ls_o00_s01_i02
It arrived today, so I wasted no time in seeing how it fit. It fits really well. There is a small amount of space around it, which seems fine, and elastic straps to hold the unit in when you open it, and mesh pockets on the facing side for random crap. The shell material is firm with a little flex to it, but seems sturdy. I am very happy with this.
Pics:
Old 12-21-2012, 04:11 PM   #6317
Gerg
Cupcake
Gerg's Avatar
Oddometer: 8,457
Memory cards in the mesh pockets.
Nice score.
Greg
Certified Ole Fart
Gerg is offline   Reply With Quote
Old 12-21-2012, 04:33 PM   #6318
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,996
Originally Posted by Drif10 View Post
Yeah, figured that one out quick. But those data fields in the corners were really handy, especially when they were transparent. Really helped maximize the screen.
I see on the wiki that it's been requested. Hope they come through with it.
Spent the day with it on the dash of the transport.
Day time colors suck, switched from auto to night mode. Much better. Any chance there's another color palette? Liked the other garmin color schemes.
Messed with menu setups. Nice to be able to.
On battery, it wore out in 4 hours. Not something that I'm likely to be bothered about, plugged into the bike is where it will live.
Need to mess with it more.
When I requested the "four corner" Dasboard I even drew them a picture....
It's been a year so I don't think we'll see this...
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 12-22-2012, 07:08 AM   #6319
mass-klr
mass-klr's Avatar
Oddometer: 179
Took the Montana to New York City this week, or it took me...
It switched off once while on I684 When we entered Manhattan between the tall buildings it just went crazy. It was not sure where we were and jumped all over the show. Luckily I knew my way around. It was as if it could not keep up. I was turning left on 6th and it was still stuck on saying that I should turn on 6th. Not sure if it could not see the satellites? I hope that was the case... I can't remember my old 255W having this issue.
I had it in the Garmin car mount. The speed limit did not show even though I could see it before on the Amps mount where it goes red if I go over the speed limit. Do you get the speed limit from FM? The car mount does not seem to have the FM section in the cable??
Thanks,
_____________________________
Leon
'11 KLR650 ... '04 DRZ400S
Paved Roads are just another example of wasted Taxpayer Dollars
mass-klr is offline   Reply With Quote
Old 12-22-2012, 07:38 AM   #6320
S H I F T Y
S H I F T Y's Avatar
Oddometer: 721
Going to order the montana, power cradle, and locking mount package from touratech today. How does it attach to the bike? Do I need to get the enduro engineering crossbar mount as well? Or is there something better?
I have a KTM 530 with a Scotts, and the Fastway clamp / barkbusters. I would like to have the montana right beyond my stock speedo, while still having the speedo be visible. See below. Anybody have a similar setup? Pics of how you have yours mounted would be much appreciated.
S H I F T Y is offline   Reply With Quote
Old 12-22-2012, 09:02 AM   #6321
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Thanks,
Speed limit information is embedded in City Navigator maps. The Montana does not and can not use FM cable information.
atlas cached is offline   Reply With Quote
Old 12-22-2012, 09:30 AM   #6322
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 796
I have a similar setup for my Montana on a 350exc w/scotts and HDB top clamp. Trick is the RAM part (RAM-B-367U) which replaces one of the top clamp bolts. Bolt pattern 100x38/40mm is pretty standard for 1 1/8th bars. Kit includes different length bolts. Can not tell the clearances in your pic, but may be an option for you....
dvwalker is offline   Reply With Quote
Old 12-22-2012, 01:07 PM   #6323
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,716
So I get a 32 gig card, put it in.
Use map install to do it's thing. Had bought the LM, which meant CN going from 2013.10 to .30.
Did the deed. Reboot the gps afterwards.
No CN of any kind on board. But mapinstall says it's there. Checked mygarmin. Says that it's registered for it. LM map updater says it's there.
But it isn't.
Tried installing it twice. Nothing.
What am I doing wrong here?
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 12-22-2012, 02:46 PM   #6324
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,668
Drif, I assume you checked the settings on the unit to see that the map set was enabled? (Map >then the three line icon > setup map > Map information/select map > you should then see a list of the maps installed and can click on each to enable or disable.
Old 12-22-2012, 03:51 PM   #6325
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,716
Yep. That's where I was confirming that it wasn't there.
Trying to re-install .10 right now to see if that will still work.
Old 12-22-2012, 04:15 PM   #6326
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,716
Well, that didn't work.
Can't see my canada topo either, though at least that one is listed on the gps itself, unlike CN which doesn't list at all. Only metroguide canada v4 is listed and shows on screen.
Gonna try wiping the card and re-install.
Old 12-22-2012, 04:55 PM   #6327
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,847
You're on a Mac, right? My most recent install to 2013.30 also didn't work. It kept telling me it was installed and the update was applied but it wasn't so I complained to Garmin. A nice young lady phoned me and I shared my computer with her, and she navigated to the place on my drive where the update resided, ran it from there and all was well from then on.
This screen shot shows where the update was found on my computer - yours should be similar.
Never mind the red arrows at the top left.
Old 12-22-2012, 07:04 PM   #6328
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,716
Took some doing, but I found it.
What do you mean 'ran it from there'?
Old 12-22-2012, 07:08 PM   #6329
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,847
Click on the gmap file to run the update. If you have the same problem I had, the update hasn't actually been applied yet.
Old 12-23-2012, 03:26 AM   #6330
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,716
Did that, it went to mapmanager, showing it was there. Like it did before.
Times are GMT -7.   It's 11:55 PM.
