Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 464 votes, 4.94 average. Display Modes
Old 12-23-2012, 04:41 AM   #6331
guavadude
de-composer
guavadude's Avatar
Oddometer: 903
When the unit is plugged into the computer and mounted you should be able to view the drive itself and see what's really there.
guavadude is offline   Reply With Quote
Old 12-23-2012, 04:43 AM   #6332
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,952
Originally Posted by Drif10 View Post
Did that, it went to mapmanager, showing it was there. Like it did before.
Ok, that's not the problem then.
Old 12-23-2012, 04:49 AM   #6333
guavadude
de-composer
guavadude's Avatar
Oddometer: 903
Originally Posted by atlas cached View Post
Speed limit information is embedded in City Navigator maps. The Montana does not and can not use FM cable information.
Using CNNA It seems like the speed limit info only works when I'm following a route. When I'm just using map without routing, I'm not getting speed limit to show in the dashboard after setting it to view speed limit. Am I missing something?
Old 12-23-2012, 05:09 AM   #6334
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,952
Is that while using the Nuvi Dashboard? It works for me, even when I'm not navigating.
Here's an example.
Old 12-23-2012, 06:27 AM   #6335
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,927
Drif10,
Is it me reading this thread wrong is is, coming from a 478, the Montana not nearly as user friendly ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 12-23-2012, 09:04 AM   #6336
guavadude
de-composer
guavadude's Avatar
Oddometer: 903
Here's an example.
Not using the Nuvi dashboard. I'm using the motorcycle profile but have added speed limit to the four field dashboard.
Old 12-23-2012, 09:38 AM   #6337
SCflyer
SCflyer's Avatar
Oddometer: 1,657
Originally Posted by DockingPilot View Post
Drif10,
Just an observation but seems like its not user friendly because it has so many options to be able to do things. I have a 478 and like it. I'm used to it but have a Montana on the way. Seems like there's alot to learn but once you get things set it works well...though my thoughts may change once I have it. Fortunately, LOTS of info and help here by those who've gone through the "start-up" phase already.
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 12-23-2012, 09:47 AM   #6338
DockingPilot
Oddometer: 9,927
The size of this thread and the relentless questions on how to use it to poor Emmbeedee and Drtbyk give me cause for alarm!
These fellas are carrying this thread.
Frank Reinbold
Old 12-23-2012, 09:53 AM   #6339
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,714
Agreed; it seems like the same basic questions are asked and answered several times a week. Perhaps new-to-Montana folks should be directed to read through the wiki first. I know it was a huge help to me when I got my Montana.
Old 12-23-2012, 10:05 AM   #6340
rockinrog
rockinrog's Avatar
Oddometer: 2,953
I have your same concerns DP. I have been following this thread since the beginning and still haven't pulled the trigger.
I used a $80 Tom Tom for a 5000+ mile trip last year and it never once froze, shut off or had to be rebooted. I do understand that this GPS has far more capabilities, but when I am traveling I just want information from a GPS. I don't want it to be a liability. That being said I have been thinking about buying one for use in geo caching and let it and myself graduate to using it on the bike.
rockinrog is offline   Reply With Quote
Old 12-23-2012, 10:17 AM   #6341
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,952
You can still switch to the Nuvi Dashboard in the Motorcycle profile to test if you get the speed limit indicator.
Sent using strings and tin cans and Tapatalk
Emmbeedee screwed with this post 12-23-2012 at 12:25 PM
Old 12-23-2012, 10:52 AM   #6342
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,590
I successfully installed CNNANT 2013 from the DVD onto my old XP desktop with the Montana connected via USB. Then I did the Lifetime Maps update.
Now on a 2nd brand new Win8 notebook I'm trying to do the same but the DVD won't install. The same Montana is connected in Mass Storage as I can see both the main internal memory and the 8GB uSD as 2 driver letters. DVD runs Garmin Map Setup and after I type in the product key from the DVD case it says "The Product Key is Not Valid for this Map Update."
I am supposed to be able to install it on multiple PC's as long as the same GPSr is connected during install, right?
Ok so I thought maybe it wants the nuMaps Lifetime product key. No, if I use that product key it says "The Product Key you entered is not a valid Product Key."
Googled around but don't see the answer.
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 12-23-2012, 12:29 PM   #6343
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,952
If you use BaseCamp, you don't need to install the maps on the computer. If the gps is plugged in, it should see the maps on the gps.
Old 12-23-2012, 01:13 PM   #6344
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,952
I think this is key - it doesn't appear "user friendly" until you're used to it - then it becomes "user friendly" once it's no longer intimidating.
Old 12-23-2012, 01:17 PM   #6345
snooker
snooker's Avatar
Oddometer: 1,590
ok that's good to know. But in this case this is a new computer that I do want all the maps on. Also I haven't even installed maps onto the Montana yet, only on my old PC. So is there some trick to install maps onto 2 PC's? no issues with Win8 right? And why does the window say it is doing an update instead of an install?
Times are GMT -7.   It's 12:13 PM.
