Thread Tools Search this Thread Rating: Thread Rating: 306 votes, 4.91 average. Display Modes
Old 01-14-2013, 02:10 PM   #6571
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,543
Originally Posted by guavadude View Post
If you touch the screen and pause before swiping, the screen will move and a pin will not drop.
If you touch short and quick, a pin drops.
That's about the best I've found and agree, I wish I could bypass it somehow.
That's what I would have suggested as well. It's possible to do a lot of screen scrolling and not drop pins as long as you use your technique.
There isn't anything in the software to prevent dropping pins.
Old 01-14-2013, 02:13 PM   #6572
guavadude
de-composer
guavadude's Avatar
Oddometer: 775
When I first started using the Montana the pin drops really bothered my, now I ignore them.
They are also useful when you want to see the name of a road but don't want to have to zoom in.
I do wish the little arrow to hide the dashboard was a bigger. I have a hell of a time getting that to work with gloves.
guavadude is offline   Reply With Quote
Old 01-14-2013, 02:15 PM   #6573
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,538
ok thanks.
I knew that from experimentation and have been trying to re-train myself to do the "long touch" first.. i.e. pause before swiping... it is what it is and it's not an iPad as far as screen touch goes. Just have to remember what device I'm actually using at the moment!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~
FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar!
snooker is offline   Reply With Quote
Old 01-14-2013, 02:15 PM   #6574
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,543
+1
There are times where you want the pushpin - you can leave it on the screen and drag the map around under the pin, and it tells you what that location represents.
Old 01-14-2013, 03:26 PM   #6575
dhb400
No Regrets
dhb400's Avatar
Oddometer: 193
I was experimenting with this same issue and found the pause technique works. The pin can be annoying.
Dave
2013 Husky TE 511
2008 Yamaha Roadstar Silverado cruiser
dhb400 is offline   Reply With Quote
Old 01-14-2013, 03:54 PM   #6576
Rocky TFS
Rocky TFS's Avatar
Oddometer: 557
Well, I guess you get to learn something new every day!
I've had it since last May and never knew that! Sometimes the pin would show up, sometimes not, I could not figure out why.
Thanks Dude!
So I thought I'd do some experimenting with the zoom buttons, with which I end up getting a pin instead of a zoom about 2/3rds of the time; one of the most annoying things about the unit, since that's the control I use the most. It appears that the zoom buttons have a similar reaction to how they are touched. If you stab at them you are very likely to get a pin, much more so when riding, because your hand is bouncing somewhat and the stab is not real accurate. The following is for vertical orientation, the only one I use on a bike.
If, however, you place the tip of your finger on the edge of the frame and roll it to the left onto the button and wait until the zoom changes, you are much more likely to get a zoom instead of a pin. You may go two levels until you train your finger, but this is still way better than the damn pin.
Trying this with gloves on, when using my right index finger it seemed to work OK, but with the left, which those of us without cruise control must use, it didn't work at all, until I hit on the bright idea of pointing my left index finger as if it was a pistol, meaning the fingernail was vertical, and getting the area of the glove finger tip right over the nail to contact the screen button while the tip of the finger was still on the frame edge.
My success rate went from about 10% to 80%!!!! Maybe I'll have to grow my left index nail long!
Now I doubt that this will work with heavy winter gloves, the tip area is just too large. For a while I used DRTBK's method by gluing the little plastic bumpers to the glove fingertip, but they kept falling off and didn't seem to improve matters all that much. I may try them again with this approach, now that I know just how sensitive the screen is to different types of touches.
I'm still hoping that the Beta team will enlalrge these buttons as that's the only sure fix.
Rocky TFS screwed with this post 01-14-2013 at 04:15 PM
Rocky TFS is offline   Reply With Quote
Old 01-14-2013, 06:45 PM   #6577
AlaskaDave
AlaskaDave's Avatar
Oddometer: 16
Thanks to all for helping resolve problems I've been having with two of the most annoying "features" on the Montana, that blasted pushpin and those troublesome zoom controls. In short: Don't tap, press. Awesome!
Furthermore, if you press and hold the zoom control, you can zoom in or out as many levels as you like without seeing the pushpin.
And I agree that best results are obtained if you approach the zoom controls from the edge of the display rather than the middle. Larger buttons would help as would left side zoom contols on the Nuvi dashboard.
AlaskaDave is offline   Reply With Quote
Old 01-14-2013, 08:11 PM   #6578
Rocky TFS
Rocky TFS's Avatar
Oddometer: 557
One other thing I just noticed is that whenever you are in a list, i.e. drawer, POI list, Waypoint list, Setup list, etc. you can page down the list by a finger flick, just like an Ipod, as long as you don't stab at it.
A narrow scroll bar appears on the right margin while doing so. Quite handy for long lists.
It's not too surprising that Garmin has not touted this much!. (Don't tell Apple fanatics!)
Old 01-14-2013, 08:19 PM   #6579
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,543
Being an iPhone and iPad user, I knew about this long ago.
Also, like the iDevices, if you hold your finger on an icon, it sticks to your finger and can be placed elsewhere.
How long before Apple sues for copyright infringement, you figure?
Old 01-14-2013, 08:25 PM   #6580
Rocky TFS
Rocky TFS's Avatar
Oddometer: 557
Not long, I figure!
Old 01-15-2013, 05:14 AM   #6581
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,543
Garmin is sending me a new Tempe to replace my flawed one which doesn't update the 24 Hour Maximum and Minimum values without requiring battery removal. They don't want the flawed one back.
Got my new Tempe in the mail yesterday - there's no way of telling the difference between new and old, as far as I can tell, except the new one should work properly.
I marked the flawed one with an X just so I know which is which.
Old 01-15-2013, 05:30 AM   #6582
mass-klr
mass-klr's Avatar
Oddometer: 152
So are the problems with the Tempe sorted out with the new one?
_____________________________
Leon
'11 KLR650 ... '04 DRZ400S
Paved Roads are just another example of wasted Taxpayer Dollars
mass-klr is offline   Reply With Quote
Old 01-15-2013, 06:00 AM   #6583
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,543
I hope so. Time will tell but I have no reason to think I ended up with another defective one.
Old 01-15-2013, 11:10 AM   #6584
rockinrog
rockinrog's Avatar
Oddometer: 2,872
Embee..it may just be the pic, but it looks like the back end of the gold spring clip? is different.
rockinrog is online now   Reply With Quote
Old 01-15-2013, 03:40 PM   #6585
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,364
I would imagine that since they don't want the faulty one back then it's some kind of component change rather then a simple firmware change.
Times are GMT -7.   It's 10:25 AM.
