01-14-2013, 12:49 PM
#6586 |
de-composer
Oddometer: 317
If you touch the screen and pause before swiping, the screen will move and a pin will not drop.
If you touch short and quick, a pin drops. That's about the best I've found and agree, I wish I could bypass it somehow. |
01-14-2013, 01:05 PM
#6587 | |
Sure, why not?
Oddometer: 16,137
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
01-14-2013, 01:10 PM
#6588 | |
Procrastinators
Oddometer: 5,804
There isn't anything in the software to prevent dropping pins.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
01-14-2013, 01:13 PM
#6589 |
de-composer
Oddometer: 317
When I first started using the Montana the pin drops really bothered my, now I ignore them.
They are also useful when you want to see the name of a road but don't want to have to zoom in. I do wish the little arrow to hide the dashboard was a bigger. I have a hell of a time getting that to work with gloves. |
01-14-2013, 01:15 PM
#6590 | |
AttitudeIsEverything
Oddometer: 1,255
I knew that from experimentation and have been trying to re-train myself to do the "long touch" first.. i.e. pause before swiping... it is what it is and it's not an iPad as far as screen touch goes. Just have to remember what device I'm actually using at the moment! ![]() Thanks!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~ Kids: OSET electric | Honda CRF50FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar! |
#6591 | |
Procrastinators
Oddometer: 5,804
There are times where you want the pushpin - you can leave it on the screen and drag the map around under the pin, and it tells you what that location represents.
01-14-2013, 02:26 PM
#6592 |
Happy Days
Oddometer: 96
I was experimenting with this same issue and found the pause technique works. The pin can be annoying.
Dave 2011 DRZ 400 |
01-14-2013, 02:54 PM
#6593 | |
Oddometer: 199
![]() I've had it since last May and never knew that! Sometimes the pin would show up, sometimes not, I could not figure out why. ![]() Thanks Dude! So I thought I'd do some experimenting with the zoom buttons, with which I end up getting a pin instead of a zoom about 2/3rds of the time; one of the most annoying things about the unit, since that's the control I use the most. It appears that the zoom buttons have a similar reaction to how they are touched. If you stab at them you are very likely to get a pin, much more so when riding, because your hand is bouncing somewhat and the stab is not real accurate. The following is for vertical orientation, the only one I use on a bike. If, however, you place the tip of your finger on the edge of the frame and roll it to the left onto the button and wait until the zoom changes, you are much more likely to get a zoom instead of a pin. You may go two levels until you train your finger, but this is still way better than the damn pin. Trying this with gloves on, when using my right index finger it seemed to work OK, but with the left, which those of us without cruise control must use, it didn't work at all, until I hit on the bright idea of pointing my left index finger as if it was a pistol, meaning the fingernail was vertical, and getting the area of the glove finger tip right over the nail to contact the screen button while the tip of the finger was still on the frame edge. My success rate went from about 10% to 80%!!!! Maybe I'll have to grow my left index nail long!![]() Now I doubt that this will work with heavy winter gloves, the tip area is just too large. For a while I used DRTBK's method by gluing the little plastic bumpers to the glove fingertip, but they kept falling off and didn't seem to improve matters all that much. I may try them again with this approach, now that I know just how sensitive the screen is to different types of touches. I'm still hoping that the Beta team will enlalrge these buttons as that's the only sure fix. Rocky TFS screwed with this post 01-14-2013 at 03:15 PM |
01-14-2013, 05:45 PM
#6594 | |
Furthermore, if you press and hold the zoom control, you can zoom in or out as many levels as you like without seeing the pushpin. And I agree that best results are obtained if you approach the zoom controls from the edge of the display rather than the middle. Larger buttons would help as would left side zoom contols on the Nuvi dashboard. |
01-14-2013, 07:11 PM
#6595 |
Oddometer: 199
One other thing I just noticed is that whenever you are in a list, i.e. drawer, POI list, Waypoint list, Setup list, etc. you can page down the list by a finger flick, just like an Ipod, as long as you don't stab at it.
A narrow scroll bar appears on the right margin while doing so. Quite handy for long lists. ![]() It's not too surprising that Garmin has not touted this much!. (Don't tell Apple fanatics!)
01-14-2013, 07:19 PM
#6596 | |
Procrastinators
Oddometer: 5,804
![]() Also, like the iDevices, if you hold your finger on an icon, it sticks to your finger and can be placed elsewhere. How long before Apple sues for copyright infringement, you figure?
01-14-2013, 07:25 PM
#6597 |
Oddometer: 199
01-15-2013, 04:14 AM
#6598 | |
Procrastinators
Oddometer: 5,804
I marked the flawed one with an X just so I know which is which.
01-15-2013, 04:30 AM
#6599 |
Oddometer: 66
So are the problems with the Tempe sorted out with the new one?
_____________________________ Leon '11 Orange KLR650 |
01-15-2013, 05:00 AM
#6600 |
Procrastinators
Oddometer: 5,804
I hope so. Time will tell but I have no reason to think I ended up with another defective one.
