01-15-2013, 10:10 AM
#6601 |
Oddometer: 2,488
Embee..it may just be the pic, but it looks like the back end of the gold spring clip? is different.
01-15-2013, 02:40 PM
#6602 |
Kool Aid poisoner
Oddometer: 4,806
I would imagine that since they don't want the faulty one back then it's some kind of component change rather then a simple firmware change.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
01-15-2013, 06:05 PM
#6603 | |
Oddometer: 124
I Just Like To Ride ![]() '03 BMW R1150GSA '06 BMW K1200LT |
01-15-2013, 07:51 PM
#6604 | |
Procrastinators
Oddometer: 5,768
Speaking of springs, is it Spring yet?
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
01-15-2013, 07:54 PM
#6605 | |
Procrastinators
Oddometer: 5,768
My wife's happy to get my flawed one.
01-16-2013, 05:10 AM
#6606 |
Oddometer: 925
Unfortunately not......
![]() Jon...
2007 FZ6 Past Bikes.....Check with my Wife.....I've lost count :-) |
01-16-2013, 11:31 AM
#6607 |
Sam
Which mount for off-road use?
Hi guys
I have got a Garmin Montana 650 for Xmas, and I would like to mount it to my XT660Z using a ram mount. Do you think it will be strong enough for off-road use? Also, do you suggest using the Garmin Rugged Mount http://salestores.com/stores/images/...0101165401.jpg or the RAM Mount? http://shop.touratech.co.uk/media/im...068-0026-0.jpg I dont really need to use the power cables of the Garmin Rugged Mount. I just want a solid mount Any suggestion is appreciated Cheers Sam |
01-16-2013, 12:06 PM
#6608 |
Deputy Cultural Attaché
I use a rugged mount, attached with RAM hardware, for both on and off road use. It holds up just fine.
Successfully surviving motorcycling since 1976. |
01-16-2013, 01:15 PM
#6609 | |
Oddometer: 191
http://www.gpscity.com/ram-mount-gar...unt-steel.html You may change your mind on powering the Montana after discovering how fast the batts go down with full backlight on all the time. I'll bet there's very few here who haven't hooked up the power. |
01-16-2013, 01:40 PM
#6610 | |
Procrastinators
Oddometer: 5,768
![]() Also, while testing the Tempe I found I could walk away to about 100' and the Tempe was still connected to the gps. This was in a straight line, with no obstructions in the way. I'm amazed it was still connected at that point. I didn't actually find the limit, but I ran out of time for playing around with it. Edit: I took the dog out for a walk in the back yard and tested the Tempe to see just how far it would connect. The experiment: Tempe hanging from a thermometer right outside my back door. Walked straight back, still connected at 74 metres. Lost connection at 105 metres. Reconnected at about 80 metres. That's pretty decent for a device of this kind. I think the limit is about 100 metres. BTW, I didn't wait for the Tempe to cool off from inside temperature - that's why the reading indicates 12C.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 01-16-2013 at 03:57 PM |
01-16-2013, 02:42 PM
#6611 | |
Oddometer: 191
Now I can check the temperature in the cooler in the wife's car while I'm following behind in the truck! ![]() I'm still not sure this thing is worth bothering with, and I'd like to know what else folks find to do with it, aside from esoteric data logging when temperature at the data point is an important part of the data needed.
01-16-2013, 04:03 PM
#6612 | |
Procrastinators
Oddometer: 5,768
Re: other purposes for the Tempe. Dunno - if you're on a multi day trip it might be interesting to look back on the temperatures in the track log. It's so inexpensive that it seemed reasonable to buy one just to see if it had a use rather than try to figure the uses out beforehand. Like in the case of the meat thermometer use I found, I wouldn't have thought of that prior to having the occasion present itself.
01-16-2013, 04:16 PM
#6613 |
Oddometer: 1,637
Tempe
Sorry if this has already been mentioned, but where are you putting the Tempes when riding? Jacket pocket, on the bike somewhere?
With this recent discussion, I've just ordered one to play with with my new Montana, which still isn't sorted. Supposedly a new LiIon battery enroute. |
01-16-2013, 04:32 PM
#6614 | |
Procrastinators
Oddometer: 5,768
In using mine on the bike I found a few things:
That being said, I keep mine on a short strap/carabiner and move it where it looks like it'll not be affected by sunlight. It usually ends up behind my tank bag, between me and the bag. This might raise the temperature a little but in practice, I haven't noticed any problem.
01-16-2013, 04:44 PM
#6615 | |
Oddometer: 1,637
