01-22-2013, 10:52 AM
#6676 | |
Procrastinators
Oddometer: 5,804
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
01-22-2013, 11:13 AM
#6677 | |
Procrastinators
Oddometer: 5,804
I've found it helps to just check once in a while, and if something looks or behaves differently, I try to restore it but not lose too much sleep over trying to figure out why it changed. But you're welcome to.
01-22-2013, 12:08 PM
#6678 | |
Oddometer: 1,876
01-22-2013, 12:26 PM
#6679 | |
Procrastinators
Oddometer: 5,804
Sent using strings and tin cans and Tapatalk
01-22-2013, 12:45 PM
#6680 |
Sure, why not?
Oddometer: 16,137
Forgive me if this is the wrong thread for this, but what are people using for Canadian topo maps on Montanas?
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
01-22-2013, 12:53 PM
#6681 |
Procrastinators
Oddometer: 5,804
Topo Canada V4 is the best.
01-22-2013, 12:58 PM
#6682 | |
Oddometer: 199
No, you don't have to buy a mount for each bike, just add an SAE connector on each bike and the mount, then swap the mount along with it's cables. You will have to figure out a way to coil and/or shorten the cable that allows for the different configuration of each bike. Some velcro bands like musicians or electricians use to keep wires and cables from turning into rat's nests would make it fast and clean. I would get a Ram ball for each bike, that will make the swap into a 15 second affair. Edit: Sheesh, in the time it took me to type this reply three people beat me to it!!! |
01-22-2013, 01:12 PM
#6683 |
Procrastinators
Oddometer: 5,804
Boy, you sure do type slowly. I responded at 1:52 and bighopper at 1:49. ;)
01-22-2013, 01:31 PM
#6684 |
Sure, why not?
Oddometer: 16,137
I am also intrigued by Toponav.
01-22-2013, 01:46 PM
#6685 | |
Oddometer: 1,876
Yep, rode a lot of dirt roads that day, didn't even go back to look for it. I used it on two bikes for six years, a refurb at that. Never tried to update the maps, probably time for a change anyway. |
01-22-2013, 03:08 PM
#6686 |
Oddometer: 199
01-22-2013, 03:38 PM
#6687 | |
What?!!!
Oddometer: 237
Ah!! Thanks! I knew it was there somewhere. And I agree - I think the updates wipe out that setting.
I'm still hot... it just comes in flashes now.
01-22-2013, 04:32 PM
#6688 | |
Procrastinators
Oddometer: 5,804
01-23-2013, 04:00 AM
#6689 |
Procrastinators
Oddometer: 5,804
Sure glad I don't need to go outside today...
01-23-2013, 07:44 AM
#6690 |
Oddometer: 199
OK, now it's your turn, you Easterners!
![]() It was +30F here yesterday and the pavement 150 yds from the house was dry so I went for a short ride, the first since November 28th! That 150 yds was interesting...... ![]() ![]() Edit: Boy we've sure done a good job of hijacking THIS thread! |
