Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 01-23-2013, 07:54 AM   #6691
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
Originally Posted by Rocky TFS View Post
Edit: Boy we've sure done a good job of hijacking THIS thread!
I'm just trying to beat DRTBYK's record of posts in the thread.
Who Posted?
User Name Oddometer
DRTBYK 1,032
Emmbeedee 1,007
Besides, when it's this cold, what else can you do but plug in the block heater, battery charger and log on? (The fire)
"Don't play a lute to a cow" (Old Chinese Idiom)
Emmbeedee screwed with this post 01-23-2013 at 09:29 AM
Old 01-23-2013, 08:37 AM   #6692
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,830
Originally Posted by Emmbeedee View Post
Sure glad I don't need to go outside today...
Holy crap that's effing cold!!!
Guess what doofus, nobody reads your lame blog.
Old 01-23-2013, 09:06 AM   #6693
BigOgre
Oddometer: 2
At $35 each, it's easy to justify buying a Rugged Mount for each bike but it's also easy to make the mount movable, by putting a SAE plug on the end of it, and running a cable up to the steering head of the bikes. I used to do this until I bought the second mount for my DR. Actually I still have the SAE plug on each cable, it's just that I no longer need to move the mount over. I like having the SAE plug though because when I don't need to power the gps, I can hook up a Battery Tender to the bike.
New to the world of GPS and decided to start with the Montana. Very grateful for this thread but DAMN there's a lot to learn!
Re. switching between bikes. Anything bad to say about using a Powerlet connector instead of the SAE plug here? This would be the simpliest solution for me but after reading about the Montana's sensitivity to current, wondering if vibration/movement within this type of connection would cause any issues.
BigOgre is offline   Reply With Quote
Old 01-23-2013, 09:25 AM   #6694
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
A Powerlet would work just as well.
Old 01-23-2013, 09:31 AM   #6695
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 558
So. I've had the Montana for quite a while and it generally stays on the bike. Since it's so damn cold out I decided to bring it in and play around with it a little. I have CN2012 installed and have all of North America and Mexico. I wanted to make a smaller mapset with just a few states. I installed the maps using Mapinstall and renamed the IMG file MidAtlantic.
My question is this: Why can I not see this map when I go to the select map portion of the Montana. It is in the same /Garmin directory as the other map that covers the entire country.
IBA #33260
cablebandit is offline   Reply With Quote
Old 01-23-2013, 09:36 AM   #6696
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
Have you tried using JaVaWa Device Manager to see if the map is set up properly? It's a great program. (I am not affiliated with them in any way - I just like the program)
Old 01-23-2013, 10:03 AM   #6697
cablebandit
Web Adventurer
Oddometer: 558
OK, I was able to rename the Nationwide map to Nationwide instead of the tile listing it formerly was. I also updated the name of the MidAtlantic set as well. However, it's still not showing up as a selection in the Montana.
JaVaWa shows the following error for both mapsets, even thought the Nationwide set works fine.
Error: segment codes from this file reside in other files. This will cause problems with routing and/or displaying maps
IBA #33260
Old 01-23-2013, 10:28 AM   #6698
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
The Javawa message is fairly clear - you have duplicate tiles in multiple img files and that will cause problems.
Old 01-23-2013, 10:41 AM   #6699
cablebandit
Web Adventurer
Oddometer: 558
So no maps can contain overlapping map data. That's just silly.
IBA #33260
Old 01-23-2013, 12:39 PM   #6700
AugustFalcon OP
AugustFalcon's Avatar
Oddometer: 925
Wow: From -30C to +32C in 24 hours???
That would be -22 F to 89.6 F
cheers... jack
04 BMW R1100S
02 KTM 250 Exc Racing
SmugMug referral code: jXF8ohDWlTm56
AugustFalcon is offline   Reply With Quote
Old 01-23-2013, 01:31 PM   #6701
bighopper
Oddometer: 124
He went indoors, to the sauna ...contribution to the Globe Warming
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 01-23-2013, 04:08 PM   #6702
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
No, no sauna, but I guess the wood stove got fairly hot last night. The Tempe's attached to a knapsack in that room when it's not outside in the cold.
Old 01-23-2013, 06:09 PM   #6703
Patch
Patch's Avatar
Oddometer: 407
Rugged Mount Question...
... found my answer. the video from gpscity shows it. Just thought it was odd that the contacts aren't the same between the auto and the rugged mount. No worries!
2011 R1200 R
Patch screwed with this post 01-23-2013 at 07:11 PM
Patch is offline   Reply With Quote
Old 01-23-2013, 06:33 PM   #6704
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,463
Send a message via MSN to Attico
How good is the tempe? Reliable?
"Build a man a fire and he will be warm for the night, set a man on fire and he will be warm for the rest of his life."
Attico is offline   Reply With Quote
Old 01-23-2013, 06:39 PM   #6705
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
I haven't compared its reading to other thermometers but it seems about right. And it stays connected to the gps as it should. I find it interesting that it stores the high and low values then resets them daily, I assume at the time I first activated it by putting the battery in.
I've been trying to think if it would be best to have the reset happen during the night, or if it even matters what time it resets.
It's spending the night outside. Will be interesting to see what the temps get down to. Was at -28 C when I last looked.
Emmbeedee screwed with this post 01-23-2013 at 06:47 PM
Times are GMT -7.   It's 12:58 AM.
