Thread Tools Search this Thread Rating: Thread Rating: 345 votes, 4.92 average. Display Modes
Old 01-25-2013, 10:44 PM   #6706
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,425
Originally Posted by atlas cached View Post
The route was created in BaseCamp, with very specific path. Why would it change on the GPSr? I sent the specific route I created to my GPSr, should not the GPSr follow the route exactly as created, so long as the maps are identical in BaseCamp and the GPSr (they were)?
Well, very few Garmin units will follow a route created in BS/MS that the unit does not go ahead and automatically recalculate on it's own. The Montana is one of those few units. I'm betting the Nuvi on the other hand isn't. Your Montana was probably following the route you created correctly. The Nuvi, probably recalculated the route and changed it.
Old 01-25-2013, 10:47 PM   #6707
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,425
Originally Posted by mass-klr View Post
I am a little confuse why we have to hack hardware to have it work correctly if we pay all that big $$$ for the Montana. I know the Montana can do a lot and I really like mine but come on, really? What's up with the hardware. GPS switching off, Rugged mount security screw screwed, etc...
Don't mind me. I am just having a bad day and want to bitch a little...
Well, both Garmins hardware and software are mediocre at best, but unfortunately for us, it's the best thing out there.
Old 01-25-2013, 11:53 PM   #6708
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Absolutely correct! The nuvi did not follow the route as originally created.
atlas cached is offline   Reply With Quote
Old 01-25-2013, 11:54 PM   #6709
atlas cached
OX Ambassador
Oddometer: 688
Unfortunately, you are (again) absolutely correct.
Old 01-26-2013, 12:23 AM   #6710
Jon_PDX
Oddometer: 1,114
This is good info to know and is encouraging.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 01-26-2013, 12:30 AM   #6711
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
@Atlascached. Sorry to hear your dramas but I am glad it is not just me having issues
One of the complaints that have not been addressed by Garmin is the "truncated route". Why it cannot install a complete route over 650km is beyond me :(
It is not as if the amount of roads here in SEA are over the top either
And, this particular unit, my third, very nearly crashed the other day. By that I mean it froze a few times while navigating Bangkok, the largest city it has been in since I got this replacement. I very nearly had to do a master reset but I got away with it. I was on major roads with only a few tall buildings so there should have been no reason to lock up
But, at least I have a GPS, it was a pain without it
Cheers from Siem Reap
Travellingstrom
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 01-26-2013, 07:58 AM   #6712
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,425
Travellingstrom
Wow, haven't done any long route planning on the 650 yet, still using my Zumo for that. Didn't realize there was a length limit. It's bad enough dealing with the shitty 50 via point limit on the damn thing that I can easily hit on a short 150 mile route. A buddy sent me a route for todays ride that has 55 via points so I either have to redo the route and trim it down to 50 or just convert it to track. Since I'm not leading I'll just covert it to a track.
Old 01-26-2013, 08:44 AM   #6713
mass-klr
mass-klr's Avatar
Oddometer: 153
One of my friends with a new Zumo 660 has the same issue where it will only route a certain distance and when you get there it will route the rest. Must be the new CN maps?
_____________________________
Leon
'11 KLR650 ... '04 DRZ400S
Paved Roads are just another example of wasted Taxpayer Dollars
mass-klr is online now   Reply With Quote
Old 01-26-2013, 04:13 PM   #6714
cropear
cropear's Avatar
Oddometer: 86
English is Hard
Originally Posted by Riteris View Post
I think it might be more user error on my part. AAAAAUUUUGH!!!
Under "External Power Only" in "Set Mount Profiles," the selection was "Last Used." I changed it to "No Change." I am guessing the change happened when I plugged it in to update the maps.
Can we get a "No Change" selection on all the features of this thing?
English Is Hard
cropear is offline   Reply With Quote
Old 01-26-2013, 06:21 PM   #6715
Jon_PDX
Oddometer: 1,114
Question
I'm confuse as to why that would happen. I just created a route that was just under 2,800 miles (4506.16 km), loaded it on my Montana 650 from BaseCamp, and it shows the full route on the Montana when I bring it up on the map screen.
Montana 650 (Firmware: 4.60)
CNNA 2012.40
BaseCamp: 4.1.0 (Mac version)
Default automotive mode
I did notice that the Montana was slow drawing the route on the map but it did complete after about 15 +/- seconds. I did not hit the "GO" button to start the route but I don't see why it would not have worked.
What am I missing that is causing you, or anyone else, to be limited to 650 km?
Jon...
Old 01-27-2013, 03:21 AM   #6716
TravellingStrom
Oddometer: 397
CNNA 2012.40
Jon...
Ahhhhh, yes it looks good when you start and there is NOTHING to show that it won't work until you start riding. The routing all works until a certain but unknown point then suddenly at the top of the screen it shows truncated route
I am mostly doing short legs over here so did not notice this issue. But, once I land back in Oz I will have to do a long, maybe 4,000km route back home so I may be able to narrow it down then
Old 01-27-2013, 06:04 AM   #6717
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,022
Has anyone raised this truncation issue to Garmin customer support? Does this happen on other units?
Old 01-27-2013, 03:04 PM   #6718
Jon_PDX
Oddometer: 1,114
Very interesting.......thanks for the clarification.
Jon...
Old 01-27-2013, 04:27 PM   #6719
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,626
Found a weird glitch, maybe emmbeedee can duplicate it.
Was east bound on the 417 out of Renfrew heading to Alexandria. So, 417E through Ottawa. Used to a Garmin giving directions to stay on 417 @ 416, and on 417 at the split.
It did that. But it also had me jumping off at Metcalfe, then back on.
Next time you're through there Mike, see what yours does.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 01-27-2013, 04:49 PM   #6720
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,594
Which map? Likely City Nav? Were you using Shorter Distance or Faster Time in your routing option?
I have to go through there on Tuesday so I'll give it a try.
Times are GMT -7.   It's 04:23 PM.
