02-01-2013, 12:45 PM
#6826 | |
Sure, why not?
Oddometer: 16,128
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
02-01-2013, 12:55 PM
#6827 | |
Oddometer: 192
BAD GARMIN!!! GO LIE DOWN!!!
02-01-2013, 12:56 PM
#6828 | |
Oddometer: 1,560
daryl |
02-01-2013, 01:02 PM
#6829 | |
Oddometer: 192
I sometimes wonder if even a Mensa could really understand the byzantine nature of Garmin's new devices. I sure as hell can't. |
02-01-2013, 01:04 PM
#6830 | |
OX Ambassador
Oddometer: 404
02-01-2013, 01:08 PM
#6831 | |
Oddometer: 192
02-01-2013, 01:13 PM
#6832 |
OX Ambassador
Oddometer: 404
never mind...
02-01-2013, 01:18 PM
#6834 |
Procrastinators
Oddometer: 5,774
There likely is a serial number range but I have never seen it published. Is yours causing you problems?
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
02-01-2013, 01:19 PM
#6835 |
OX Ambassador
Oddometer: 404
If your GPSr supports USB Mass Storage Mode, and you can view internal folder and file structure, you have a newer unit :)
#6836 |
Procrastinators
Oddometer: 5,774
What, you mean we're the guinea pigs? Okelydokely!
02-01-2013, 01:35 PM
#6837 |
Oddometer: 2,203
how does one ascertain the age of a unit in a shop?If i buy one from a local shop i want it to be a NEW one not an old NIB one
aka BMWST?
02-01-2013, 01:46 PM
#6838 | |
Oddometer: 1,560
In BC, If you right click on a via point in a route's property window, a drop down list will appear that will allow you to change its property to ‘Alert On Arrival’ or ‘Don’t Alert on Arrival (Shaping Point)’. Not all gps support non announcement of shaping points. It would appear that the Montana doesn't. and thus treats them as way-points, The 62s doesn't as well, but I think some Nuvi's do. That's why you see the Blue Flags when the route loads. I feel like I've beat this horse enough for one day. daryl dlh62c screwed with this post 02-01-2013 at 02:05 PM |
02-01-2013, 02:00 PM
#6839 | |
Kool Aid poisoner
Oddometer: 4,810
POI - A formal Point Of Interest. An entry in the internal POI database with a name, location and usually other information associated with it. Waypoint - Any arbitrary point on the map that you have designated you want to keep track of. Usually stored in the "Favorites" or "My Locations" or whatever your personal navigation device calls its waypoint storage database. Your device will usually allow you to store such things as the location, any arbitrary name you want to supply and other information such as address, phone number, category(ies) and a symbol/icon to be used when displaying it. Via Point - A point used to create a multipoint route, e.g. Go from Point A to Point B via some other arbitrary point(s) that you will designate. If your personal navigation device supports multipoint routing, the via point can be a POI, an existing waypoint/favorite or any other form of location that is searchable on your device, e.g. address, intersection/junction, custom POI, etc. In most cases, to use something as a via point it must already exist in one of the devices' searchable databases. Shaping Point - In Mapsource, to "shape" a route to go exactly where you want there are a couple of methods. Just as with the personal navigation device, you can edit the route's properties to insert Via points (these are not shaping points although they do serve a similar purpose). You can also just use the route tool to click on spots on the map to force the shape of a route. When you do that, you are using a location that is not already in one of the searchable location databases. Mapsource does not force you to add these points to any of the formal databases. It simply inserts the actual coordinates invisibly into the route. These are shaping points. Shaping points occur in another, automatic, fashion as well. Even when you only designate a two-point route, e.g. go from Point A to Point B, there will usually be multiple places, usually intersections, where a change in direction is required. When building the route, the personal navigation device (or Mapsource/Basecamp) will automatically include all of these points in the route.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
02-01-2013, 02:03 PM
#6840 | |
Kool Aid poisoner
Oddometer: 4,810
