Thread Tools Search this Thread Rating: Thread Rating: 432 votes, 4.94 average. Display Modes
Old 02-22-2013, 07:03 PM   #7036
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
Originally Posted by FireDog45 View Post
Yea, my bad. I went back and re-read your post and I totally missed your point that's why I nuked the post. I was hoping you didn't see that...
I will post back after I get an answer from Garmin since that info may be useful to somebody.
No problem. When you get email notifications of new posts, it's hard to miss reading them even if they are deleted afterwards.
Old 02-23-2013, 09:53 AM   #7037
team ftb
Befuddled Adventurer
Oddometer: 1,759
Originally Posted by TravellingStrom View Post
Hmm, I am wondering if you are in the right screen format? Are you looking in 2D or 3D? That might be your problem.
if it looks like you are looking down from above it is 2D and I agree, the route is very small, but you can zoom right in, but it is not perfect.
Maybe change your map to 3D, go to Map/Setup, Orientation and select Automotive mode, then see if that screen is any better, put the unit in portrait mode and lock it to that position
- Main menu/Settings/Display/Orientation Lock/Lock Portrait
That may be helpful.
As for Bokor Mountain, on a fully loaded Vstrom, that racetrack is brilliant and I am not sorry to have found it paved ;) from Ticket office to Buddha=19 minutes and top checkpoint= 24 minutes, round trip to the bottom ticket office was 47 minutes
It was a blast ;)
Cheers from Sihnoukville, Cambodia
TravellingStrom
Thanks I'll give the 3d view a shot. The route stands out better in that mode in the living room I'll see how it works in practice. nice tip thanks.
Top to bottom of Bokor in 47 minutes. Sheeeeeet its changed a bunch. I ended up sleeping at the old stone Casino at the top.
Enjoy the lobster on the beach in Sihnoukville.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 02-24-2013, 05:31 AM   #7038
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
Originally Posted by team ftb View Post
Thanks Richard will check out how to do that.
Also want to say thanks to you for a presentation with some personality at the HU meeting in Thailand. Good shit. Sorry the Bokor mountain road in Cambodia you got was paved. Back a few years it was good fun
Hi
Mate I was happy to drink beer with other bikers and speak some shit, and if it turns out entertaining then so much better, thanks for your support
As for Bokor I like it the way it is ;)
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 02-24-2013, 06:14 AM   #7039
FreeTheBeast
Shunpiker
FreeTheBeast's Avatar
Oddometer: 3,046
Cool2 Little bit of a scare
I received the miniSD card with the Canada Topo maps. I put it in the unit and then went to look for it in the maps setup. It was not there! Upon subsequent investigation, I found the metal sleeve that locks the miniSD chip in place had come off. I thought it was broken. I must not have aligned the card correctly with the molded plastic guide. The card probably pushed the metal sleeve when I put the battery and door back on. Fortunately, I was able to snap the metal sleeve back into place and lined up the memory chip properly. All is well and the unit can see the maps on the card.
I need to be more careful! Well, it was a good reason to use my new reading glasses for the first time.
Think beyond yourself.
The Hampster Ride - A mainly dirt route to ride the length of New Hampshire.
Max the Motorcycle - children's book written by Mrs. FTB
SmugMug Photo Gallary
FreeTheBeast screwed with this post 02-24-2013 at 06:19 AM Reason: adding photo
FreeTheBeast is offline   Reply With Quote
Old 02-25-2013, 03:41 AM   #7040
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
There's a CNNA Lifetime Map Update out today. 2013.40 is the latest.
Not sure if this will happen for others, but even though the Lifetime Map Updater said it completed successfully, .40 was not installed on my Mac. I had to navigate using Finder to the place where the map had been downloaded and saved to on my computer, and run the update from there.
Emmbeedee screwed with this post 02-25-2013 at 04:13 AM
Old 02-25-2013, 03:45 AM   #7041
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
R: Reading Glasses - resistance is futile. Wear them.
That clip is delicate, but as you found it can be put back into its place.
I usually put some tape on the clip to keep it in place.
It's too bad you bought the SD version, but the gps itself has enough room for maps so you can add any other maps like CNNA to the gps itself.
Emmbeedee screwed with this post 02-25-2013 at 03:52 AM
Old 02-25-2013, 04:10 AM   #7042
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,635
Be advised that updating with "Express" may cause the update to go only to the GPS unit, and not also to your hard drive. I had to use an older version of the lifetime map updater to get it to go to both.
Old 02-25-2013, 03:58 PM   #7043
BruceWA
Oddometer: 575
I'm unable to download it to either my pc or Montana!
Figures don't lie, but liars can figure
BruceWA is offline   Reply With Quote
Old 02-25-2013, 04:41 PM   #7044
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
You bought the Lifetime Map Updater, applied it to a map in your gps but can't get it to download? Have you called Garmin?
Old 02-25-2013, 04:50 PM   #7045
BruceWA
Oddometer: 575
I've opted for the online support, they'll get back to me in 3 working days
Had no problem installing the CNNA NT 2013.3 version, but something seems to be amiss in the new Garmin Express installer.
Old 02-25-2013, 04:54 PM   #7046
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
So you gave Garmin 72 hours grace to get back to you.
The phone's the only way to go, IMHO.
I didn't even try Express - LMU works well for me.
Old 02-25-2013, 05:56 PM   #7047
BruceWA
Oddometer: 575
Unfortunately LMU is telling me I'm up to date!
As I write am back to mapupdater, it is s l o w l y updating.
It does get wearisome being a beta tester for far too many software apps these days.
Old 02-25-2013, 06:02 PM   #7048
MJS
MJS's Avatar
Oddometer: 1,912
Same issue on my PC but can't find the update in my Downloads folder. Anyone know where Garmin Express is supposed to put the file?
Second question, since I bought the maps on DVD, how does the new Express updater work if I don't have the GPS connected? I used to be able to download updates direct from the My Garmin web page.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 02-25-2013, 06:34 PM   #7049
BruceWA
Oddometer: 575
Garmin mapupdater has successfully installed CNNA NT 2013.4 on my pc, now installing it to my 650t. At least I hope it is.
Old 02-25-2013, 06:51 PM   #7050
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
You need to do this yourself, through MapInstall.
Times are GMT -7.   It's 11:29 AM.
