Thread Tools Search this Thread Rating: Thread Rating: 403 votes, 4.93 average. Display Modes
Old 03-05-2013, 10:49 AM   #7111
dvmvm
Oddometer: 23
Originally Posted by snooker View Post
I must say I am honored to be the "cause" of your very first post to ADV ! ?.....
I have translated some solutions on this ADVrider forum to the Dutch forum. I'm glad to do something back!
dvmvm is offline   Reply With Quote
Old 03-05-2013, 11:59 AM   #7112
Timmer
Timmer's Avatar
Oddometer: 2,359
Originally Posted by Emmbeedee View Post
No, there is no 'Detour' in the Montana. You can insert via points into a route you're currently navigating but that's about as close as you can get to the detour feature.
You can't insert via points in uploaded routes. If you do, it wipes out all the other via points except the destination. Also, one can't edit an uploaded route.
Just this past 4 days I got lots of practice with this while riding in a rally.
Tim in Burien, WA
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 03-05-2013, 12:12 PM   #7113
joefromsf
Dark Happens
joefromsf's Avatar
Oddometer: 1,549
Are you serious? I'm a "route" person and this was a common use case for me using my 276C.
joefromsf is offline   Reply With Quote
Old 03-05-2013, 12:37 PM   #7114
mbabc
Curmudgeon trainee
mbabc's Avatar
Oddometer: 1,955
There's a groove which you can likely create yourself as bli55 did in his post.
This is the wall I was in front of yesterday:
These are all standard sizes but they also had metric.
Or maybe you were thinking of the security part of it, the little pin in the head of the screw which keeps a standard Torx driver from working? These "Tamper Proof" ones have that pin.
Wow, neat hardware store! I'll check around town. My local mom-n-pop doesn't have them, nor Radioshack.
"I have never seen a Kentuckian without a gun and a pack of cards and a bottle of whiskey." - Gen. Andrew Jackson
'08 WR250R - '12 Super Tenere - '64 CT-Frankentrail
Little Blue goes looking for Orange
I don't know what time it is, I've switched to kilometers
mbabc is offline   Reply With Quote
Old 03-05-2013, 01:02 PM   #7115
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
Let me know if you can't find 'em. I will be back in town on Thursday so I can get you a couple.
Emmbeedee is online now   Reply With Quote
Old 03-05-2013, 05:19 PM   #7116
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
Anyone else seeing this problem? Anytime I try to simulate driving a route, I end up in the Atlantic ocean south of Accra.
My software version is 4.70 and it doesn't seem to matter which maps I have enabled. This happened on various profiles with different maps in each.
Old 03-05-2013, 05:26 PM   #7117
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
WHat are the exact coordinates in the Atlantic Ocean?
I have an erroneous track file that took me out to the coast of Africa and back at MACH 10,000 (super high speed). Of course, I never really was there. I'll have to find the GPX and compare the coordinates if you can share yours :)
atlas cached is offline   Reply With Quote
Old 03-05-2013, 05:52 PM   #7118
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
This is it:
And it even takes me into tomorrow.
Old 03-05-2013, 06:18 PM   #7119
atlas cached
OX Ambassador
Oddometer: 688
This is it:
Awesome! Doesn't look like a DeLorean, but you apparently have a Time Machine!
Here is my Glitch: Look slike it goes tot he SAME PLACE. Why do Garmin GPSr want to go there so badly?
Oh, and look! I was doing 812,700 MPH! (Now that's a FAST time machine!)
atlas cached screwed with this post 03-05-2013 at 06:32 PM
Old 03-05-2013, 06:27 PM   #7120
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
This is it:
You know, that nearly looks like a default number, with that northing of nearly 0, it just seems strange, like something went belly up, the easting also is strange, as I assume you are in the states.
It nearly looks by the map that the point is directly south of the Garmin Europe HQ and on the equator
Just a thought?
Cheers
TS
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 03-05-2013, 06:42 PM   #7121
atlas cached
OX Ambassador
Oddometer: 688
Just a thought?
Cheers
TS
My track anomaly did not occur while simulating anything. I was simply recording my travels as I do every day, and when I got home one day to open my saved track record, I saw that I had warped through the very fabric of space and time to visit the coast of Africa. Several times. This very glitch has occurred on multiple occasions, and I have multiple track records which display the odd behavior.
WHY does the Garmin briefly think it is near the coast of South Africa, for just a SINGLE track log recording point, then snap right back to it's true position?
Old 03-05-2013, 06:47 PM   #7122
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
Just a thought?
Cheers
TS
It does look like some stack overflowed or whatever, and it took me back to a zero location. I've heard of it happening to at least one other person so I think it's time to report it.
Old 03-05-2013, 06:50 PM   #7123
atlas cached
OX Ambassador
Oddometer: 688
Will you start a thread about it at the Wiki? If you know the other party with similar experience, ask them to chime in?
I will assign a Bug Report and we can all send a copy of the report to Garmin with our supporting data files?
I will need to know as much detail about exactly what you were doing with the Montana when it occurred, so that I may write the Bug Report as accurately as possible.
Old 03-05-2013, 07:00 PM   #7124
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
That's a Toyota Land Cruiser. Better than a DeLorean, anyday.
I'll start a thread tomorrow. The other guy's on Facebook, so I'll see if he wants to play.
Old 03-05-2013, 07:03 PM   #7125
atlas cached
OX Ambassador
Oddometer: 688
What vintage LC?
Thanks for playing!
Times are GMT -7.   It's 05:29 AM.
