Thread Tools Search this Thread Rating: Thread Rating: 348 votes, 4.92 average. Display Modes
Old 03-11-2013, 07:02 PM   #7186
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,598
Originally Posted by gspdbill View Post
How did you know I'm on a Mac?
It was an inspired guess.
Old 03-11-2013, 09:28 PM   #7187
BajaDave
Crazy Bastard
BajaDave's Avatar
Oddometer: 263
No, zoom level was not high at all, don't remember the exact resolution but think it was about 500 ft. per 1/2 in. and was never touched between ride out and return ride.
I'm just going to ride with it again sometime this week and see if the F/W update did anything to change the behavior and will report back.
Thanks for all the help. I'll spend some more time in the Wisdom thread....
Did you check your track to confirm it placed you in the same location in both directions? I'm guessing a very weak or intermittent signal put you off of your actual location as far as the map goes. Checking your track can verify this.
Our Baja California Loop GPS Tour is now available and shipping!
GripTwister Dual Sport Tours
BajaDave is offline   Reply With Quote
Old 03-12-2013, 06:52 AM   #7188
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,598
New Basecamp Version Available: BaseCamp software version 4.1.2 (For Windows Only)
Check here for details.
Emmbeedee screwed with this post 03-12-2013 at 07:06 AM
Old 03-12-2013, 11:02 AM   #7189
OneEffinName
Oddometer: 465
Originally Posted by Bli55 View Post
OneEffinName, that's sad....
Which mount was it in?
Did it just break whilst riding or something hit it in an off?
It was in the the rugged mount. Rubber mounted. Keep in mind it saw a hard life.
OneEffinName is offline   Reply With Quote
Old 03-12-2013, 03:57 PM   #7190
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Originally Posted by cablebandit View Post
Anyone else having any hinky selection issues since the latest firmware update? Since upgrading, my selections don't seem to be working as they should.
For instance, if I'm on the menu page and hit the map icon it will not go to the map. It scrolls to the second page of menu icons. Eventually you can get there after multiple attempts. This is just one of the anomalies.
Everything was well until I upgraded to the latest firmware. I'm thinking of going back one version and see if that solves the issue.
Happens alot with me. It then locks up and won't do anything. Taking the battery out does nothing. Strange thing is this only happens in a car with or without 12v power. Version 4.6.
tahoeacr is offline   Reply With Quote
Old 03-13-2013, 05:26 PM   #7191
TrotterD
Geek
TrotterD's Avatar
Oddometer: 17
I would probably need a bit of a hint on how to do that but in this case the other maps aren't showing up anymore. These are the maps I have now via Setup Map > Map Information > Select Map:
WW DEM Basemap, NR
CN NA NT 2013.30
Topo US 24k Southeast
Digital Globe
USGS Quads
Hi Bill, hope you are well.
Do you have all those maps you have listed enabled all at the same time on one profile. Most of the time you will probably only need one map set enabled for most activities. Eg. I don't see much use for the WW DEM Basemap to be enabled if you are using City Navigator. The more maps enabled the more memory used and processing power, thus slowing the device down slightly.
Regards
Dave
Look where you want to go, not where your going.
TrotterD is offline   Reply With Quote
Old 03-14-2013, 08:10 AM   #7192
gspdbill
noobie allover again
Oddometer: 404
Regards
Dave
Dave, thanks, I was going to ask about that. Thanks for pointing that out. I'll go through my profiles today and disable the maps I don't need for the individual profiles. I would assume I wouldn't need the WW DEM Basemap for anything the US City Navigator covers correct?
Now that I'm almost done with the maint/repairs on the new-to-me bike I'll be playing with the Montana a lot more. I've had a heck of a time finding a good mounting spot where it wouldn't interfere w/ the tankbag but still give me unobstructed view of the dash/inst console, finally settled on the "Twin Headlamp Ernie" dash shelf and mounting a RAM ball mount to it w/ the RAM arm and Garmin AMPS Rugged Mount, I think that should do the trick.
Dave, (and the rest who have contributed to this informative thread) thanks so much for your help.
Bill
'05 R1200GS for now......
gspdbill screwed with this post 03-14-2013 at 08:43 AM
gspdbill is offline   Reply With Quote
Old 03-14-2013, 09:09 AM   #7193
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,598
People report that the WW DEM (Digital Elevation Model) map needs to be on, or else searches take longer. I have no problem keeping the DEM map on in addition to any other. It supplements other maps, it does not duplicate or conflict with them.
Old 03-14-2013, 09:43 AM   #7194
TrotterD
Geek
TrotterD's Avatar
Oddometer: 17
Hi Bill, no problem.
I have mine on a 2009 GS mounted using the RAM mount ball onto a aftermarket GPS bar. Looks great and am also using the HUGE Garmin spiny security nut thingy.
Regards,
Dave
Old 03-14-2013, 11:10 AM   #7195
vabuckaroo68
Gnarly!
vabuckaroo68's Avatar
Oddometer: 1,212
Putting tracks on Google Earth
Is it possible to move tracks from the Montana to Google Earth? If so how do I do that? Thanks in advance
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
vabuckaroo68 is offline   Reply With Quote
Old 03-14-2013, 11:40 AM   #7196
ACP
ACP's Avatar
Oddometer: 73
Simplest way I found, assuming you have Basecamp, at the top, click view, Google Earth... Voila
950 GO!!!!!!!
690 Enduro R
ACP is offline   Reply With Quote
Old 03-14-2013, 03:16 PM   #7197
BergDonk
BergDonk's Avatar
Oddometer: 3,488
Otherwise upload the file and convert it with something like GPSBabel to a KM file and done too. BaseCamp is simplest though.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 03-14-2013, 03:24 PM   #7198
BergDonk
BergDonk's Avatar
Oddometer: 3,488
I finally got my new Montana. Originally arrived just before Christmas and found faulty. After toing and froing by the vendor, its now working properly, ie I got a new replacement. I just hope it lasts now.
The problem was that it did not recognise, or connect to, the LiIon battery pack, but otherwise it worked fine. As a result, I did get some quality time with the first one, and its a good thing for sure.
With the Oz Topo maps, I find that I can plan tracks by using the routing which follows in detail the route, then convert it to a track. Occasionally, the route will not follow a track on the map, so I stop it there, and join it up later when both ends are tracks.
Terrific helpful thread, juts like the rest of ADV
Old 03-14-2013, 04:32 PM   #7199
TrotterD
Geek
TrotterD's Avatar
Oddometer: 17
Hello, hope you are well.
If you plug your device into your PC / Mac. Then run Basecamp, you will see the under your device a folder called "Internal Storage". Highlight this to show the contents of your internal storage in the bottom pane. You will see everything such as waypoints, tracks, routes etc. If you have tons of stuff in the device "Internal Storage" you can click the foot print symbol at the bottom to filter to just show tracks.
Left click one of the tacks so that id is highlighted on the map over to the left of the screen. Then from the menu, click -> View -> Google Earth -> Selected Items. This should invoke Google Earth to load and display your track on the Google Earth Map.
Regards,
Dave
Old 03-14-2013, 06:01 PM   #7200
vabuckaroo68
Gnarly!
Oddometer: 1,212
Tracks
Thanks Dave. That worked very well. I used the tracks to mark out my hare scrambles course on my ranch.
Question about how the Montana recorded the tracks though......I had some over lap where I went back over the same tracks but, it didn't mark it that way. It looked like I had paralleled my previous track. Is there a setting that makes the tracks more accurate? I remember seeing a number with decemal points when I turned the tracks on this morning., but I'm not sure what that was.
Times are GMT -7.   It's 05:27 PM.
