Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 468 votes, 4.94 average. Display Modes
Old 03-14-2013, 07:59 PM   #7201
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
Originally Posted by vabuckaroo68 View Post
Thanks Dave. That worked very well. I used the tracks to mark out my hare scrambles course on my ranch.
Question about how the Montana recorded the tracks though......I had some over lap where I went back over the same tracks but, it didn't mark it that way. It looked like I had paralleled my previous track. Is there a setting that makes the tracks more accurate? I remember seeing a number with decemal points when I turned the tracks on this morning., but I'm not sure what that was.
That happens to me all the time..
It is due to the accuracy reading for the satellites. At any one time if you stand in one spot,(test this by leaving your GPS in one spot for a day) you will see it wandering all over the place.
It is nothing to worry about and nothing you can really do about it.
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 03-15-2013, 02:43 AM   #7202
TrotterD
Geek
TrotterD's Avatar
Oddometer: 17
Hello, I think also the numbers with decimal points you have seen in are your archived tracks in track manager. They will be the time of the date that the track was created.
As far as accuracy goes, I don't think there is any settings you can tune as such. I don't know if playing with the "GPS" option in the "Draw" -> "Setup" -> "System" then changing between WAAS/EGNOS and Normal.
I am sure someone on this forum will be able to say what these settings mean to you depending on where you are using the GPS in the world.
But why wait, doesn't hurt to play with the settings and see how it behaves.
Regards,
Dave
Look where you want to go, not where your going.
TrotterD is offline   Reply With Quote
Old 03-15-2013, 05:20 PM   #7203
Rocky TFS
Rocky TFS's Avatar
Oddometer: 605
With WAAS (Wide Area Augmentation System) enabled in North America, or EGNOS in Europe, your typical accuracy will go from 12 to 15 feet down to 7 to 9 feet.
Hardly worth the additional battery draw unless you are geocaching, IMHO.
Rocky TFS is offline   Reply With Quote
Old 03-15-2013, 05:40 PM   #7204
woodsatyr
Kitty Boy
woodsatyr's Avatar
Oddometer: 504
Finally got my Montana replaced! I used it today out running errands and had it off and on, in and out of the mount, and NO WHITE SCREENS!! Gawd, that was frikkin annoying!! Now I have to work on putting all my customization back on it.
I noticed that the map doesn't show the speed limits anymore. Anybody else notice that? (Nuvi dashboard).
Also thought I'd mention what happened right before I returned the old one to Garmin: I had already made arrangements with them to return the unit but had a weekend of riding coming up. I told them I'd send it in after the weekend. So I'm out riding and got caught in the rain. Actually it started raining while I was in eating lunch and the unit was on the bike. Water got up under the screen and the screen quit responding. The unit was still working - making tracks that I was able to download later - but the screen was unresponsive. I thought it was supposed to be waterproof enough that rain wouldn't bother it. I was really surprised by that! That was weird.
That has me a bit nervous about kayaking tomorrow. I may put it in a ziploc.
woodsatyr is offline   Reply With Quote
Old 03-15-2013, 06:26 PM   #7205
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,975
Re: the speed limits - do you have City Navigator NA loaded?
I've ridden in the rain many times with mine and never had an issue with water getting into the screen.
I even dip it into the sink to wash it when it gets really dirty.
Emmbeedee is online now   Reply With Quote
Old 03-15-2013, 11:02 PM   #7206
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Really?
atlas cached is offline   Reply With Quote
Old 03-16-2013, 04:20 AM   #7207
TravellingStrom
Oddometer: 397
I had the same problem
I am guessing here but I reckon over a period of time you have done many many master resets. Because if the pressure needed there is a crack in the glass that develops in that exact position. Well it did for me after months of resetting
Water got in mine also. When I contacted Garmin they said screens are not included in warranty. But they agreed the correct Garmin reset procedure can end up cracking the screen and replaced it again
Cheers
TS
Old 03-16-2013, 04:30 AM   #7208
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,975
Originally Posted by atlas cached View Post
Really?
Why not?
Old 03-16-2013, 04:39 AM   #7209
woodsatyr
Kitty Boy
woodsatyr's Avatar
Oddometer: 504
Yes. The latest version. Although I may not be holding my mouth right. I followed the directions provided by Garmin (on the phone) because I had issues with the Express program. Got the maps and an update loaded. BUT... when I look at Basecamp with the Montana attached, I don't see the map set listed in the left panel. Any suggestions?
Ditto. I also use it kayaking and I have a sit-on-top kayak so it gets wet easily from that.
I am guessing here but I reckon over a period of time you have done many many master resets. Because if the pressure needed there is a crack in the glass that develops in that exact position....
Cheers
TS
Oh wow! I had no idea! But you're right, that was probably it.
Old 03-16-2013, 04:47 AM   #7210
woodsatyr
Kitty Boy
woodsatyr's Avatar
Oddometer: 504
I just rechecked. Garmin had me use MapInstall. I just started it up again and it says I have the maps installed. CNNA NT 2013.4
Why doesn't it show up on the left panel in BaseCamp?
Old 03-16-2013, 05:55 AM   #7211
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,975
Try Javawa Device Manager. It will allow you to set the map's visibility in Basecamp.
Old 03-16-2013, 09:02 AM   #7212
atlas cached
OX Ambassador
Oddometer: 688
Why not?
IT simply had not occurred to me to do so...
Old 03-16-2013, 10:56 AM   #7213
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,772
To topo or not to topo
I'm thinking about getting the 600, don't need a camera, and was wondering is there value in buying the Canada topo bundle with it or can I source what I need online cheaper/free?
I see I can get the 600 with the powered mount and ram bits for about $600 tax incl, or about $100 cheaper than the 650t motorbike bundle (per GPS City.ca)
What mapping comes with the unit and what is the must have software?
Cheers.
CanadianX is online now   Reply With Quote
Old 03-16-2013, 11:35 AM   #7214
dresda
shut up and RIDE!
dresda's Avatar
Oddometer: 999
The Montana makes an excellent bath toy. A great place to relax and explore all those menus and options. And waterproof too!
Sent via semaphore on Tapatalk
Stephanie
'01 Suzuki DR650 (Patsy Q), '11 VW Golf TDI Wagon
dresda is offline   Reply With Quote
Old 03-16-2013, 01:09 PM   #7215
Bli55
Oddometer: 398
I KNEW I wasn't the only one to play with it in the bath!
Bli55 is offline   Reply With Quote
Times are GMT -7.   It's 09:07 AM.
