Thread Tools Search this Thread Rating: Thread Rating: 371 votes, 4.93 average. Display Modes
Old 03-18-2013, 03:01 AM   #7246
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,666
Originally Posted by Rocky TFS View Post
Must be the solar flare......
I sure hope it was. Neither gps could do the simplest task: navigate to home. They kept telling us to get off the highway and do a u-turn to go off in the opposite direction. It was bizarre.
Old 03-18-2013, 12:29 PM   #7247
gspdbill
noobie allover again
Oddometer: 404
Originally Posted by gspdbill View Post
Anybody else having the grey/white screen on startup? I've had this problem occasionally since I got the unit 4 months ago but it happened infrequently, until this past week. I've had it happen 4 times this week. Tried to search the Garmin Forums but their forums don't seem to be set up for questions like this. Google search found a Geocaching forum that has a thread on this problem from about 18 mos. ago but they report it mostly happens when the Montana is installed in a cradle, mine does it both when installed in the cradle and when hand held. Usually powering down the unit 1 or 2 times will bring it back to normal startup but yesterday I had to remove it from the cradle and cycle power in handheld mode to get it to start normally.
The condition is when starting the unit up the screen lightens up a little (what I call "gray" screen) but goes no further than that. Holding the power button down gets you the normal 2 beep power down signal and it will usually power down. Hitting the on button again the unit may power up normally or I may have to repeat the process again. On the Geocaching forum they reported they had to remove the battery to get it to shut down.
This problem has occurred in both 4.60 and with my current 4.70 F/W installed.
I'll be calling Garmin on Mon.
Called Garmin, 1st guy I talked to said he'd never heard of this problem before, put me on hold to ask someone else about it and about 2 min later hung up on me.
Called Garmin back, this time got James, he too said they never heard of this problem, wanted to know if I had any other s/w loaded on the unit (I said just CN & Topo) then wanted to know if I had a SD card installed (yes I do) said the SD card may be hanging up the unit to remove the card and see if it still happens, if it does next step is master reset of the unit.
I think Garmin is hoping the problem (me) will go away, not a chance.
At least I got a ticket no. from James to refer to later.
Don't think I'm going to wind up being real happy w/ Garmin on this......
Update: 3rd time I powered the unit up after removing the SD card (and after hanging up w/ Garmin) the unit went into White Screen mode..... (it's not a SD card issue)
3rd call to Garmin I did the Master Reset with them on the line followed by 5 reboots, came up each time (not surprising), will be using the daylights out of it to see if it fails again.
Do we have a separate thread for Montana "issues"?
Bill
'05 R1200GS for now......
gspdbill screwed with this post 03-18-2013 at 01:24 PM
gspdbill is offline   Reply With Quote
Old 03-18-2013, 03:21 PM   #7248
Rocky TFS
Rocky TFS's Avatar
Oddometer: 565
Battery dies in 2 weeks
Has anyone else had this problem? I came back from a trip with the Li-on battery fully charged in the cradle for many hours, turned it off, put it away, and 2 weeks later turn it on to see the battery nearly dead.
Does anyone think there is a small parasitic draw in these units that behooves one to remove the battery for longer term storage, since Li-on batteries generally don't like being fully discharged?
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 03-18-2013, 03:55 PM   #7249
ramz
Professional Trail Rider
Oddometer: 2,000
From my post on 11/19/2012:
My Garmin rugged mount is wired directly to the battery. When my bike's ignition is switched off with the key, the rugged mount is still powered.
I measured 8 ma draw from the rugged mount when my Montana is in the rugged mount and is turned off and my bike's ignition is switched off.
I measured no draw from the rugged mount when my Montana was removed from the rugged mount.
I use non-rechargeable lithium AA batteries in my Montana for those rare instances when I want to use my Montana and it is not in the rugged mount nor connected to my iMac.
Others do not detect this parasitic draw....
ramz is offline   Reply With Quote
Old 03-19-2013, 05:56 AM   #7250
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 704
The way I read your quote they DO see a parasitic draw. If there is a draw when the GPS is in the cradle and none when it's removed then logic dictates the GPS is drawing the juice.
It's probable never "off" I'm sure it checks it's location from time to time when powered down to help with satellite acquisition when you fire it up.
IBA #33260
cablebandit is offline   Reply With Quote
Old 03-19-2013, 06:03 AM   #7251
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,666
If the gps is in the mount, I'm sure it still draws power, but the mount alone uses none, AFAIK.
Old 03-19-2013, 07:01 AM   #7252
Rocky TFS
Rocky TFS's Avatar
Oddometer: 565
Sorry, I did not make it clear that I removed it from the mount and put it away in my desk drawer for that two weeks.
2010 Yamaha TW200
Old 03-19-2013, 07:12 AM   #7253
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,666
Did you have the barometer set to record while the gps is off? That would use some power.
Old 03-19-2013, 09:50 AM   #7254
Boughton
Oddometer: 24
Montana 600
I have a few questions that I have yet to find the answers to within this forum, or maybe I have just overlooked them.
1. I just bought a Montana 600 and now need to decide what maps to purchase?
2. I plan to use the GPS to navigate on streets and dirt roads across Idaho mainly. I also plan to ride the GDR.
3. I would like to trace a route on my MAC computer using the map software (basecamp?) then load it into the Montana and follow the route on the GPS.
4. I know I need to get the street navigator, but the question is what topographic map to get 100k or 24k? I was thinking 100k for a generalized map use. Can I trace a route with the 100k maps, I've read yes and no to this question.
5. ALL COMMENTS WELCOME!!!
Boughton is offline   Reply With Quote
Old 03-19-2013, 09:53 AM   #7255
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,595
For street and dirt road City Navigator or you could get free OSM maps.
The 100K topo maps are not routable, the 24K are.
Old 03-19-2013, 10:16 AM   #7256
Boughton
Oddometer: 24
Is road city navigator routable?
Old 03-19-2013, 10:21 AM   #7257
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,667
The product is known (for our neck of the woods) as City Navigator North America. And yes, it is routable.
The 100K topo map from Garmin is not routable.
I don't have any of the Garmin 24K map products, but believe that they are routable (if not, someone will doubtless correct me.)
Old 03-19-2013, 10:35 AM   #7258
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 746
City Navigator North America (CNNA) is routable and also contains a lot of other info such as fuel, shopping, dining, lodging... I recommend CNNA over OSM (open source maps) because of the this. OSM will get you in the general vicinity but not to a specific address. It also doesn't have seem to contain as extensive a list of the other goodies I mentioned. For example: I live on a county road and OSM will get me to the approx 3 mile section I live on but not my specific address. It also didn't know there was 3 fuel stations 5 miles from my house. It showed the closest fuel was more than 10 miles away.
These may be minor to some but to me the $80 that Garmin charges was worth it.
I do have the OSM topo maps installed but haven't a chance to give them a workout yet but on first glance they look like they'll do fine for me. Though these are not routable like the 24K Garmin maps are.
FireDog45 is offline   Reply With Quote
Old 03-19-2013, 11:13 AM   #7259
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Great purchase! Tons of great Montana GPS info also available here.
Use Garmin CNNA (DVD Only) if you require updated routable mapping, or Garmin 24k Topo if you want topo info and routing info from 2008.
I highly recommend NW Topos from Switchbacks. Not routable, but very detailed.
Many more great free maps here.
or get free routable OSM Maps here.
Some information about Routes in BaseCamp.
24k maps far more accurate than any 100k maps, and the link above to NW Topos is one of the finest 24k maps you will find for your area!
atlas cached is offline   Reply With Quote
Old 03-19-2013, 01:41 PM   #7260
ramz
Oddometer: 2,000
There is a new series of 100K topo maps from Garmin that IS routeable. Here are hi-lites from the Southwest map.
TOPO U.S. 100K - Southwest
$ 59.99 USD
Provides detailed digital topographic maps, comparable to 1:100,000 scale USGS maps.
Contains roads, trails and highways in metropolitan and rural areas so getting to your destination is easy by creating point-to-point routes on compatible devices.
Version: 5.00
Released: January 2013
Part Number: 010-D1312-00
Use with One Device Only
This product may be unlocked and used on 1 compatible device. If you want to use this same map on subsequent units, you must purchase a new map for each device.
Data downloaded to a microSD/SD card is associated with the device you select during the download process. Please purchase additional quantities for additional devices.
https://buy.garmin.com/shop/shop.do?cID=255&pID=127640
Here is the entire US version.
TOPO U.S. 100K
Version: 5.00
DVD ( $ 99.99 USD )
microSD™/SD™ card ( $ 99.99 USD )
Download ( $ 99.99 USD )
https://buy.garmin.com/shop/shop.do?cID=255&pID=127633
This series is more like the CNNA by allowing routing and locking to devices than the older 24K and even older 100K.
So to be clear, we should call maps in the new 100K series 2013 100K map; i.e. 2013 100K Southwest or some such.
ramz screwed with this post 03-19-2013 at 01:47 PM
Times are GMT -7.   It's 10:03 PM.
