Thread Tools Search this Thread Rating: Thread Rating: 414 votes, 4.93 average. Display Modes
Old 03-30-2013, 06:08 PM   #7351
chaslins
chaslins's Avatar
Oddometer: 7
Great information. Thank you. Anything for or against up loading to basecamp then down to 32 g card. Getting smarter with this. Thanks
chaslins is offline   Reply With Quote
Old 03-30-2013, 06:18 PM   #7352
250senuf
250senuf's Avatar
Oddometer: 2,410
As Mac said. Just copy the file from one card to the other one. Keep Basecamp out of the move.
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 03-30-2013, 07:43 PM   #7353
chaslins
chaslins's Avatar
Oddometer: 7
Thanks sure like this forum. You guys will be tired of hearing from me but when I am done I will understand. Sam sends tracks tomorrow of TAT.
Old 04-01-2013, 09:29 AM   #7354
SteveAZ
SteveAZ's Avatar
Oddometer: 1,209
When the Montana "archives" a track where does it go? Internal memory? SD? Is it archived in whole or is it "compressed" or "filtered" with some of the data thrown out?
SteveAZ is offline   Reply With Quote
Old 04-01-2013, 03:54 PM   #7355
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Internal memory, X:\Garmin\GPX\Archive
AFAIK, there is nothing stripped out of the archived gpx, and if you want to use it in any way, you can make a "Favorite" out of it to bring it out of the archive directory.
GPX files are very small so there's no need to fear filling your Montana's memory with them. The screen shot below is my Montana's GPX directory, including many routes and tracks from as far back as I can remember, and it's only 105 megabytes in size for 478 items.
Old 04-01-2013, 04:20 PM   #7356
SteveAZ
SteveAZ's Avatar
Oddometer: 1,209
Thanks! I usually setup the tracking for 1pt/sec which even though it will consume the most memory, like you say it would likely take years worth to take up any appreciable space. Someday it would be nice if Garmin would create "real" documentation but I'm not holding my breath...
I did find out the answer to my other question about GPS elevation too... As I presumed it will only display and log the barometric sensor elevation. Oh well. I still have handheld units without sensors that will for the times it's important and if I really want I can get some other really slick "board level" units that will log at 20hz very accurately by using GPS, Glonass and Galileo signals...
Old 04-01-2013, 06:05 PM   #7357
dresda
shut up and RIDE!
dresda's Avatar
Oddometer: 987
Speaking of multiple maps, emmbeedee, tell us the story of the GPS that had no idea where any of our destinations were :)
Sent via semaphore on Tapatalk
Stephanie
'01 Suzuki DR650 (Patsy Q), '11 VW Golf TDI Wagon
'....and I shall baffle you with cabbages and rhinoceroses in the kitchen, incessant quotations from "Now We Are Six" through the mouthpiece of Lord Snooty's giant, poisoned, electric head. ' from My Pink Half of the Drainpipe by Bonzo Dog Doo Dah Band.
dresda is offline   Reply With Quote
Old 04-01-2013, 06:47 PM   #7358
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Your guess is as good as mine, but it looks to me like the OSM map was interfering in some way as the gps worked well once I deleted that map. But with the OSM map in the gps, even when it was disabled, I would do a search on a town and the gps would find the town but report it as being in the US, not Canada, where it actually was.
Totally bizarre and makes me a little reluctant to put the OSM map back on.
Here's an example. The Prescott NY actually refers to Prescott ON.
It works as it should now that the OSM map is gone.
Emmbeedee screwed with this post 04-01-2013 at 07:02 PM
Old 04-02-2013, 04:13 PM   #7359
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,897
The reason that the OSM map reported the Canada location as being in the US is because the site (person) that compiled the map coded some of the Canada tiles as US.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 04-02-2013, 05:06 PM   #7360
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Cheers,
And that's how the invasion starts, right?
If this was the only anomaly I'd still use the OSM maps but I saw many more bizarre names like Pembroke, ABC, and when searching for a location, I don't have time to guess what that ABC stands for.
What's especially weird about my example, Prescott, NY, is that City Navigator was enabled at the time so why didn't it offer up Prescott, ON? What gives OSM priority/dominance?
Old 04-02-2013, 05:53 PM   #7361
dvmvm
Oddometer: 23
GPS Elevation
....I did find out the answer to my other question about GPS elevation too... As I presumed it will only display and log the barometric sensor elevation.....
Actually it cán record the gps elevation:
  • Setup - Altimeter - Barometer Mode = Fixed Elevation => GPS-elevation is logged.
  • Setup - Altimeter - Barometer Mode = Variable Elevation => barometer-elevation is logged, possibly correced by the GPS-elevation:
    Auto calibration on: a slow correction with time constant of half an hour. Just after power-on (when powered-off for more than 2.5 minutes) there is a fast correction in 1-2 minutes.
    Auto calibration off: no correction by GPS. Best acuracy is reached when manually calibrating with a known elevation at the beginning of the trip.
dvmvm is offline   Reply With Quote
Old 04-03-2013, 07:48 AM   #7362
caver
Missouri The Cave State
caver's Avatar
Oddometer: 711
Originally Posted by Mac View Post
I see a lot of questions about using multiple maps on the same device, or in the same folder. This is how I use three maps on the same device. There may be other ways, but this works for me. I reserve my memory space on the device for storing BirdEye imagery, tracks and such. All my maps stay in the same folder on a 32G uSD card, installed in my 650T.
By default, all supplemental maps are typically named the same - "gmapsupp.img". Just rename each img file as they installed on the card (or on the device). Once the installed map is renamed, then you can install another map (then rename it as well), and so on.
Here is a copy of the "Garmin" folder in my uSD card. Also, I keep a copy of this folder on my computer hard drive, as a backup.
Quick post since I'm at work. I bought my Montana 600 last year. Had trouble loading City Nav and Topo East/West. I loaded most of CN and areas of East West I would need. I'm leaving for a trip and realized the west topo maps I had loaded, did not cover the area I would be in. I tried to reload and it screwed it up. I can no longer toggle between Topo and CN. I figured out CN and topo were going into the same file. Gotta run...more later
caver is offline   Reply With Quote
Old 04-03-2013, 08:01 AM   #7363
SteveAZ
SteveAZ's Avatar
Oddometer: 1,209
I appreciate the feedback. It would be nice if Garmin documented how things work, however....
My understanding is that:
  • Setup - Altimeter - Barometer Mode = Fixed Elevation => the barometric pressure displayed being that of the direct reading of the barometric pressure sensor compensated for by the "calibrated" elevation (refer to auto calibration on/off) and that it expects that elevation to be fixed; i.e. the GPS is stationary. This is the mode you might use while at a fixed location to apply the barometric sensor as you would a barometer. My experience with other Garmin units with barometric sensors (e.g. 76Csx) in this mode is that the track logging and altitude display are not the GPS derived elevation but still the barometric pressure sensor derived elevation.
  • Setup - Altimeter - Barometer Mode = Variable Elevation => the barometric pressure displayed is simply compensated to the "calibrated" elevation.
GPS derived elevation is much less accurate than the horizontal GPS accuracy (usually about 2x or somewhat more than horizontal) and it depends on satellite position geometry. The "auto calibration" takes the average of the GPS derived elevation over time and "calibrates" the barometric altimeter to this elevation periodically to compensate for the normal barometric changes.
This works very well except for when you are in aircraft or even when the unit is mounted in the wind stream or behind a windshield on the moto where the pressure is not the static pressure and it can cause errors of more than a hundred feet or even much more. Forget about it in a pressurized cockpit where it is useless. I fly aircraft for sport (ultralights, sailplanes, other) and for a lot of these applications either don't need a aviation GPS or they are fix mounted in the aircraft and I'm just looking for a handheld so I can download the track logs easily when I get home.... Hence the desire for a more accurate track log then I get from the barmoteric sensor derived altitude. My experience has been that the GPS (actually GNSS) elevation in an aircraft with the antenna in a good position does much better than the barometric sensor derived elevation - particularly in these newer units that aren't just GPS but use other satellites like Glonass or Galileo (GNSS - Global Navigation Satellite Systems)... It would probably be a very different case if we could plumb a good static pressure source to the handheld but that's not practical.
Maybe this is different on the Montana but it's how it works in the 76Csx and since the setting fields are the same, I'm skeptical it's different. It's very easy to test. Just take the unit up in a commercial aircraft and see whether the elevation maxes out at 7.5-8.5K' instead of 30-40K'....
Old 04-03-2013, 08:12 AM   #7364
Mac
Mac's Avatar
Oddometer: 2,153
So load one map. Rename the file. Then load the next map. Repeat.
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is offline   Reply With Quote
Old 04-03-2013, 09:57 AM   #7365
caver
caver's Avatar
Oddometer: 711
MAC, Yeah I got pulled away for work stuff.
Can I delete those img files? My last upload, last night I ended up with an .img file that said City Navigator 2013.? or something similar to that. I also had another file (also .img) that had CN in it both similar in size after loading maps. Both files were on the micro disc. I also have the gmappsupp.img that people talk about. The gmapsupp may have been on the internal drive. I don't have the unit here at work so I may be wrong on that. Anyway last nights upload I couldn't find E or W topo but CN loaded fine. I have jumping back and forth between Basecamp and Mapsource trying to see if one program would succeed.
Times are GMT -7.   It's 11:31 AM.
