Thread Tools Search this Thread Rating: Thread Rating: 431 votes, 4.94 average. Display Modes
Old 04-15-2013, 02:34 PM   #7516
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Originally Posted by DRTBYK View Post
I get no "Automotive Turn" data on either the nuvi Dashboard or in a Data Field. The data we were discussing was the Dist to Next data field option which is not shown as available with Routing with the nuvi Dashboard. It is available when you use a Data Field in another Dashboard or the Trip Computer.
There are other anomalies with this release related to navigation so I think I would avoid this update - it came so fast I think it received very little system testing. Garmin doesn't do Regression Testing the way the rest of the Software Industry does - at least that's my impression.
The anomaly above I have not been able to reproduce as I was just running through a bunch of random actions.
Cheers,
Does not 'Ready To Navigate' insinuate a destination has yet to be chosen?
atlas cached is offline   Reply With Quote
Old 04-15-2013, 02:41 PM   #7517
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,982
Exactly. Indicating that the unit is not navigating.
But, and I was not clear on this, the point that I was making with the screenshot was that the non-navigating data field on the left shows an option that is not one of the nuvi picks even when it IS navigating.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 04-15-2013, 02:43 PM   #7518
atlas cached
OX Ambassador
Oddometer: 688
Cheers,
OK, got it!
Little slow today ;-)
Old 04-15-2013, 04:11 PM   #7519
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
Same experience with v4.9: "Dist to Next" not offered as an option in the nuvi Dashboard and....etc.
Cheers,
Garmin, that sucks!!!!!!
I forget, how do your regress to 4.7? I have Montana 4.70 GCD.zip saved on my HDD. Just extract and run the Montana 4.10.gcd file with the Montana connected?
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 04-15-2013, 04:15 PM   #7520
DRTBYK
DRTBYK's Avatar
Oddometer: 5,982
Not quite. FIRST...set your GPS Profile to Recreation then connect the unit to your computer and Unzip the file and change the name of the resulting GCD to GUPDATE.GCD. Then place that file in the \Garmin\ directory of the Montana. Then disconnect the unit in the usual way and power back on.
Cheers,
Cheers,
Dan
All Things GPS
Old 04-15-2013, 04:52 PM   #7521
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
Not quite.
How could I forget something as SIMPLE as that that I only use once every two years or so?
How do you keep all this Byzantine stuff straight in your head?
2010 Yamaha TW200
Old 04-15-2013, 05:16 PM   #7522
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,841
Cheers,
I decided to go back to 4.70 too, but I had already copied the file over to the gps when I saw your warning about switching to the Recreation profile. I let the gps apply 4.70 though I knew I was in one of my customized profiles. The update did bring me back to the Recreation profile, but it made no difference to the other profiles so once I changed profiles back to my Topo setup, it was exactly as before. So was my Canada Enhanced Basemap, and my Auto Nav profile. They were exactly as before the firmware change.
I think your warning is probably important if you're using a standard Garmin supplied profile, because that may be changed back to some default, but if your important profiles are ones you created yourself with names which Garmin hasn't chosen, then you're probably ok to leave it in whatever profile it's in when you change firmware versions.
Old 04-15-2013, 05:28 PM   #7523
DRTBYK
DRTBYK's Avatar
Oddometer: 5,982
Yes, I noticed this new behavior today myself. Previously (before v4.7) if your custom profile was the first profile in the Profiles List, when you did a Master Reset (which can happen depending upon how you do a software update) the first profile in the list was reset to Recreation but the "name" was not changed so it still had your custom profile name but was the Recreation profile and your profile was overwritten.
Now, it appears that all custom profiles are moved from the top to the bottom of the list and then the Recreation profile is rewritten and set to the current profile. This was one of my "please change this" behaviors that has now been fixed.
Cheers,
Cheers,
Dan
All Things GPS
Old 04-16-2013, 02:53 AM   #7524
Madhouse
Semi-Goodlookin!
Madhouse's Avatar
Oddometer: 3,362
Many Thanks to you all!
Thanks everyone that spoke up to help me get the City Navigator installed on the SD card on my Montana.
Its working great and figured out how to make it work like the Nuvi that I keep in the car.
Able to switch from CNNA to Topo with no problems.
Could not have done it without everyone's help.
Thanks Again!
Madhouse is offline   Reply With Quote
Old 04-16-2013, 05:39 AM   #7525
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
Thanks Again!
That's what we are here for.....you sure as hell can't depend on Garmin for a lot of this abstruse stuff. The wealth of information here and in the Wikispaces puts them to shame....if they had any, that is.
2010 Yamaha TW200
Old 04-16-2013, 05:43 AM   #7526
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
Cheers,
Yes, but most of us will still have to overwrite the Recreation Profile with our own if we want any functionality out of it. Why do they have to change anything?
2010 Yamaha TW200
Old 04-16-2013, 07:36 AM   #7527
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 705
4.9 Update
OK, before downgrading to 4.6 (the last stable, glove friendly firmware) I think I got most of my major issues with 4.9 resolved. I ended up installing 4.9 and then doing a master reset. As a result I now have distance to next (with lane assist) as well as the speed limit. The indicated speed also now changes to red again when exceeding the limit. I'll poke along some more with 4.9 and reserve final judgement for a little longer.
I guess the key here is to always do a master reset after any firmware update.
IBA #33260
cablebandit is offline   Reply With Quote
Old 04-16-2013, 08:54 AM   #7528
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,609
Aside from having no dashboard at all, is there any way to get rid of the annoying speed limit field and its little red friend that pops up if you exceed it?
Old 04-16-2013, 09:14 AM   #7529
DRTBYK
DRTBYK's Avatar
Oddometer: 5,982
Not if you want to use the nuvi Dashboard.
P.S. My v4.90 started working as well after my second MR and third install. I'm not sure yet how good it's working still running scenario's.
Cheers,
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 04-16-2013 at 09:22 AM
Old 04-16-2013, 09:25 AM   #7530
DRTBYK
DRTBYK's Avatar
Oddometer: 5,982
Good that you're working now as well. EDIT: I finally had my wakeup call and understand what you were talking about. Yes, dist-to-next in the lane assist window is working for me as well.
I'm still fixated as to why my nuvi dashboard actually did come up with Dist to Next in the lefthand data field during one of my testing sessions.
Cheers,
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 04-16-2013 at 09:48 AM
Times are GMT -7.   It's 05:21 AM.
