Thread Tools Search this Thread Rating: Thread Rating: 434 votes, 4.94 average. Display Modes
Old 05-06-2013, 10:17 PM   #7711
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Originally Posted by sintax View Post
I've been having some issues getting the WEST 24k topo maps onto my Montana. I was able to install the south east, south central, south west, but the West is giving me issues.
It appears to install, it says it completed successfully, shows up on the card, basecamp says its there, but when i go into the map setup on the device, every map is there EXCEPT the West. SE,SC,SW, and the base map. You can enable and disable all of them, but the West is no where to be found.
I've deleted the West off the card 2 times and readded it without issues from Basecamp.
Basecamp sees the maps correctly in its system as well, you can view the full topo maps just like the other areas.
I'm kind of out of ideas.
Anyone have any?
You can experiment without having to wait to delete and add maps back. Simply change the extension from *.img to something like *.zip and they will be ignored, just as if you had removed them. Simply replace the *.img extension to re-enable them after testing is complete.
I suspect you may have exceeded the 4000 map segment limit with all those maps installed.
Try changing the extension of one or two of the other maps, and see if the West map is now available.
atlas cached is offline   Reply With Quote
Old 05-06-2013, 10:24 PM   #7712
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,996
Originally Posted by SCflyer View Post
In a time crunch, have the TAT tracks from SAM but just noticed one of the Oklahoma and Colorado sections are viewable. I go to the track and no matter what I select...view, delete whatever it's like it's stuck. I can download easy enough and says it's successful but can't view...or delete.
Suggestions? Thanks
You most likely have some bad data. Try removing all of the tracks on the unit using Windows Explorer or Finder (Win/Mac). Then open BaseCamp and view the tracks there (I assume you have Imported Sam's GDB file into BaseCamp?). If they show on the map in BaseCamp, Export each of the offending tracks separately to a GPX file and just drag/drop that GPX file to the Montana\Garmin\GPX folder.
Then give it a try on the Montana.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 05-07-2013, 05:11 AM   #7713
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,700
How are files identified as tracks (or routes, for that matter) when viewed through Windows Explorer?
Old 05-07-2013, 05:31 AM   #7714
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
They are just .gpx files. I find the best way to check them for corruption is to run JaVaWa and it might report this kind of thing:
Old 05-07-2013, 07:34 AM   #7715
DRTBYK
DRTBYK's Avatar
Oddometer: 5,996
If they were transfered by BaseCamp each track would be named Track.gpx, track1.gpx, track2.gpx, etc. Same for Routes.
Cheers,
Dan
All Things GPS
Old 05-07-2013, 07:37 AM   #7716
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,700
Thanks, Dan.
Old 05-07-2013, 09:01 AM   #7717
sintax
Oddometer: 495
You fixed it man!
You rock
I'll adjust my maps to not deploy all the segments per map
sintax is offline   Reply With Quote
Old 05-07-2013, 03:42 PM   #7718
Spinalcracker
former redriderofma
Spinalcracker's Avatar
Oddometer: 1,089
I made a route in Basecamp on a Mac and I kept the waypoints under 50. The route in base camp is 263 miles. I also converted it to a track.
I then sent it to the Montana and when I select the route it is now 272 miles. The tracks milage still matches the route I made in the computer.
Any idea on how to keep the milage the same ?
Both the computer and Montana have the same version of CNNA 2013.1
Unless we change direction, we are likely to end up where we are headed.
It's county Fair time in New England
TET MA to NC
Vermont Covered Bridges
Spinalcracker is offline   Reply With Quote
Old 05-07-2013, 04:35 PM   #7719
DRTBYK
DRTBYK's Avatar
Oddometer: 5,996
Did you transfer the Route to the Montana internal storage or the µSD Card?
Cheers,
Dan
All Things GPS
Old 05-07-2013, 05:35 PM   #7720
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,849
Is it farther from the uSD card?
Old 05-07-2013, 07:48 PM   #7721
DRTBYK
DRTBYK's Avatar
Oddometer: 5,996
. . . uh...yes.
Cheers,
Dan
All Things GPS
Old 05-07-2013, 08:30 PM   #7722
KTMInduro
Off Road Montster
KTMInduro's Avatar
Oddometer: 354
Not on the Montana but you can in BaseCamp.
Originally Posted by dlh62c View Post
In BC you can set the proximity radius in feet or miles, a red circle will appear around the waypoint. Keep in mind, you will be prompted twice, once when you enter the radius point and again when you ride out of it.
Thanks guys !
Monty
Husaberg FE 390
BMW F800 GS
Borneo Equator Expedition - Jungle , Swamps and Heatstroke
KTMInduro is offline   Reply With Quote
Old 05-08-2013, 01:47 AM   #7723
dlh62c
Oddometer: 1,603
Using BC, I perfer to 'Export' my routes, tracks and waypoints to the gps. When a list is exported, it takes on the list name with a .gpx file extension. The routes, tracks and waypoints are all in a single file with a descriptive name when viewed through Windows Explorer.
Old 05-08-2013, 05:40 AM   #7724
MizzouRider
MizzouRider's Avatar
Oddometer: 1,788
Take lots of pictures. I like the sound of the 'plastic press on thumb cap' idea.
+1. I'd like to see this too..
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 05-08-2013, 06:19 AM   #7725
DRTBYK
DRTBYK's Avatar
Oddometer: 5,996
And that is a good way to manage your data with Windows Explorer. But, if you want the benefits of what the Montana can do for you, that isn't the best option. We discussed this last year when the Montana optimized the way it reads your Track and Route data.
There are two primary benefits of using BaseCamp to Transfer (Send to Device) your data.
  1. When BC transfers the data it breaks the Tracks and Routes in to separate files as I mensioned previously: Track.gpx, Track1.gpx, Track2.gpx…, Route.gpx, Route1.gpx, etc. By doing this the Montana does not have to load ALL of your data into memory at one time. It can optimise performance.
  2. Routes contain waypoints and the Montana will show you those waypoints in the Waypoint Manager. If you transfer your data in a single GPX file the Montana places all of that data where it belongs: Waypoints in the Waypoint Manager, Track in the Track Manager and Routes in the Route Planner. In so doing if you transferred a waypoint that was used in a route you will get duplicate waypoints in the Wayoint Manager. If you used BC, the Montana knows not to duplicate a waypoint that is in a Route if it is already in the Waypoint Manager.
In summary, if you have relatively long Tracks and/or Routes the Montana will preform much better if you transfer the Route/Track/Waypoint data to internal memory via BC. All other data I put on my µSD Card.
Cheers,
Dan
All Things GPS
Times are GMT -7.   It's 06:20 PM.
