09-08-2011, 05:05 PM
#766 | |
Procrastinators
Oddometer: 6,046
We did report it here, bmwgrrl and I.You can go back to a previous software version, if you really want to, but I figure Garmin's going to fix this real soon so it's not worth reverting for me.. Edit - Sorry - My mistake. It was reported in a separate thread called "Montana Firmware 3.3 Out"
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 09-08-2011 at 05:19 PM |
09-08-2011, 07:33 PM
#767 |
Working to ride
Oddometer: 672
Followed Dan's advice with applying v3.3; backup \garmin-->remove SD--->restore defaults-->install upgrade-->copy custom profile back, so far no issues.
Would rather have seen a 4 corner style semi-transparent dashboard (276 like) than the newly added Satellite or Big Data Field dashboards. |
09-10-2011, 07:50 AM
#768 | |
Beef = Packed Vegetables
Same here !!!
KTM690r 2011 |
09-10-2011, 12:41 PM
#769 |
Goin' Minimalistic
Oddometer: 394
Update today available. Fixes the stuff they broke when they were fixing the broke stuff they fixed....
Sent via Tapatalk iPhone - The scourge of workplace productivity.
2005 BMW F650GS Emma Beagle, 11.1.96-5.11.11 ![]() You Ride Shotgun on my Shoulder Now Not All Who are Lost Wish to be Found Needle Grrl in a Haystack World
09-10-2011, 02:45 PM
#770 | ||
Procrastinators
Oddometer: 6,046
Not bad; took Garmin only a week to bring out these fixes! Not sure a new thread is the best way to announce this so I copied it here. Quote:
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 09-10-2011 at 02:50 PM |
09-11-2011, 04:21 PM
#771 |
Working to ride
Oddometer: 672
a new thread for every Montana bug fix? Nah...
Noticed the map screen scroll and repaint bug is mucho better. |
09-11-2011, 09:41 PM
#772 |
Dubbious Adventurer
Oddometer: 4,697
Just got back from a nice three day ride.
Montana touch screen crapped out just like others have reported ![]() Happened as soon as we got going. Where you touch has no relation to what happens next. Impossible to work around or recalibrate. I had to go the whole weekend with just the map displayed a single scale. Very annoying to say the least. I'll be calling Garmin in the morning.
MINIMOUNT |
09-11-2011, 09:45 PM
#773 |
Dubbious Adventurer
Oddometer: 4,697
If you read back and tape the battery pack (or use a 3m sticky pad), this issue can be completely eliminated. Not sure how a new battery will solve the problem. Then again, maybe they know something we don't.
MINIMOUNT |
09-12-2011, 10:47 AM
#774 |
Oddometer: 401
Read in the specs that route avoids are not supported. Can anyone confirm this? On my 478 I usually avoid things like toll roads and HOV lanes. Thanks!
Mark |
09-12-2011, 05:55 PM
#775 |
OCD
Oddometer: 41
Actually, they are supported...
Setup > Routing > Avoidances.. |
09-12-2011, 06:00 PM
#776 |
I want to ride
Oddometer: 1,785
Following this thread, it seems the screen calibration problem was hardware and if you bitch, they recall your unit and give you a newer one?
if one buys a new unit, do we know if the fix is already installed? Any serial number range to look for?
2010 F800GS Stone Road Touring bike! |
09-12-2011, 06:15 PM
#777 |
Procrastinators
Oddometer: 6,046
That's interesting. I hadn't changed profiles in the Montana when I was searching for the avoidances. When I went to the Automotive profile (from the motorcycling one I had already chosen) I found the avoidances.
There was obviously something in the settings of the profile my Montana was in causing it to not show the avoidances. Perhaps when you have 'Prompted' for both 'Activity' and 'Calculation Method' it doesn't give you avoidances cause I just don't see that option in the screen on mine, though I do see avoidances in the other profiles. Edit - just checked and sure enough, if you have 'Activity' set to 'Prompted' you don't see avoidances.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 09-12-2011 at 07:13 PM |
09-12-2011, 06:47 PM
#778 |
Almost there
Oddometer: 308
09-12-2011, 06:53 PM
#779 |
OCD
Oddometer: 41
09-12-2011, 07:25 PM
#780 |
Oddometer: 401
Good info all, thanks!
Mark |
