Thread Tools Search this Thread Rating: Thread Rating: 369 votes, 4.93 average. Display Modes
Old 05-17-2013, 02:53 AM   #7816
achesley
Old Motorcyclist
achesley's Avatar
Oddometer: 3,463
Originally Posted by TrotterD View Post
Hello, hope you are well,
You could try change the setting in Setup -> Tracks -> Auto Archive so that its Daily. Then I think this would save you one track per day even if you stop and start during your travellers.
Regards
Dave
Thanks Dave,
Did set it up for that yesterday while setting up shortcuts also.
Also, on the leaving it attached to the bike's power , even though turned off, I looked at it and touched it after being on over night and that thing was pretty warm. So, just back to unplugging it as I did my 276C at the end of the day if I leave it in the cradle. But, Pretty easy to just pop it out of the cradle and put it in the tank bag here at home.
Thanks to all the advise as this thing is a learning process on all it can do if I learn how to let it do it ;-)
A '00 KLR 650 40,000 miles, A '07 1250S 74,000 , A '03 5.3L Chevy Truck 78,000 + '43 style dude , Simper Fi ;-)
achesley is offline   Reply With Quote
Old 05-17-2013, 05:31 AM   #7817
Spinalcracker
former redriderofma
Spinalcracker's Avatar
Oddometer: 1,087
I on a 2 week trip and I am using my new Montana but seem to be having some issues.
1. Several times the map would stop scrolling and it looked like the screen froze but the speed in the lower right and the distance to next turn in the upper left still worked. I have it on nuvi dashboard. I would shut it off, turn it back on and would still do it. the map would not refresh.
2. Several times when I start the bike, with the garmin in the powered cradle wired to the canbus plug on a 800GS, I would get a white screen. I would have to take it out of the cradle , push the power button and then put it back in and it would be fine. This doesn't do it all the time just whenever it wants to.
any ideas ?
Unless we change direction, we are likely to end up where we are headed.
It's county Fair time in New England
TET MA to NC
Vermont Covered Bridges
Spinalcracker is offline   Reply With Quote
Old 05-17-2013, 05:50 AM   #7818
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,595
Originally Posted by achesley View Post
Thanks Dave,
The rugged mount should not get warm.
It's just a set of contacts...Mine is wired through the bikes ignition.
And it never is warm or does it draw any current.
I haven't tired this but....if the mount is wired to the battery (hot all the time) and the Montana's battery is low it might get the mount warm by recharging the Montana's battery???
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 05-17-2013, 05:56 AM   #7819
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,654
any ideas ?
What version of the software do you have on that Montana? Older versions had the white screen issue you describe but that bug was squashed ages ago.
And with regard to the screen not scrolling - is it possible that your screen protector, assuming you have one, is making selections on its own. The Garmin protectors are a little thick and they tend to cause that kind of problem in sunlight.
Old 05-17-2013, 06:36 AM   #7820
Rocky TFS
Rocky TFS's Avatar
Oddometer: 565
I think Achesley meant the Montana was warm....As I said above, I think it's charging even when turned off in the mount, if the lithium battery is in place.
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 05-17-2013, 11:17 AM   #7821
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,595
Sorry I missed that
This is a big thread....
Fred
YouTube feed
Old 05-17-2013, 05:51 PM   #7822
Spinalcracker
former redriderofma
Oddometer: 1,087
I thought I had the latest version. I just got the Montana in February and before I left on this trip I made sure it was updated
I am using the garmin screen protectors
TET MA to NC
Old 05-17-2013, 08:16 PM   #7823
achesley
Old Motorcyclist
achesley's Avatar
Oddometer: 3,463
Yes, it's the unit itself. After unplugging it, the unit cooled off lots when I went back and checked later that day. Not a problem though. Just a learning curve on what the Montana can and can't do for me. Just takes getting used to after 18 years with the 167 and 267 units.
Old 05-18-2013, 05:33 AM   #7824
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 704
I don't use screen protectors on anything. My Montana's screen still looks new.
IBA #33260
cablebandit is offline   Reply With Quote
Old 05-18-2013, 05:41 AM   #7825
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,654
I use screen protectors mainly to cut down on glare.
Old 05-18-2013, 02:40 PM   #7826
Chip Stevens
Oddometer: 117
Emmbeedee, Are you using the Garmin screen protectors? chip
Chip Stevens is online now   Reply With Quote
Old 05-18-2013, 02:51 PM   #7827
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,654
Yes, I have a lifetime supply, having bought 4 mounts, and Garmin sent me a bunch for free.
Old 05-18-2013, 03:16 PM   #7828
advNZer?
advNZer?'s Avatar
Oddometer: 2,878
is there another kind?
aka BMWST?
advNZer? is offline   Reply With Quote
Old 05-18-2013, 04:05 PM   #7829
JMartin
JMartin's Avatar
Oddometer: 459
Hearing the Montana without the Car Mount?
Hi,
What options do I have for hearing the Montana in a car without the suction cup mount w/ speaker?
I do not yet own a Montana but, in addition to using it on the bikes, would like to be able to use it in a rental car when in an unfamiliar place and be able to hear the turn-by-turn directions without having to bring along the suction cup mount with speaker. What, if any, are my options?
Thanks,
Jay
6. There is a very fine line between "hobby" and "mental illness." 16 Things it takes most of us 50 years to learn.
JMartin is offline   Reply With Quote
Old 05-18-2013, 04:38 PM   #7830
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,654
Originally Posted by JMartin View Post
Hi,
Thanks,
Jay
You could plug in an external speaker or earbuds to the speaker out connector on the Montana itself.
Times are GMT -7.   It's 09:20 PM.
