Thread Tools Search this Thread Rating: Thread Rating: 342 votes, 4.92 average. Display Modes
Old 05-22-2013, 07:12 AM   #7921
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
Originally Posted by Emmbeedee View Post
It's a crapshoot anyway. It's not like I'm taking scientific readings. Where is the best place for it, anyway? In a tank bag? In a pocket getting warm from body heat? In a fairing, getting warm from the bike? There is no easy answer, but at least this means I have it with me.
When moving, at least the forward part of the fairing should be getting clean, ambient temperature air. I'd certainly place the unit out of the sun and ahead of any engine, radiator, or oil cooler.
Old 05-22-2013, 08:10 AM   #7922
Rocky TFS
Rocky TFS's Avatar
Oddometer: 564
Originally Posted by Emoto View Post
I think we have a winner. I bought "The Classic Case - Camera / Hard Drive / GPS Case" by HandStands on Amazon.
That's what I got too. It's perfect.
Re: Emmbeedee's caution, I just haven't ever put anything in the pockets...
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 05-22-2013, 08:47 AM   #7923
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,299
Originally Posted by rpet View Post
My source data is Tracks. I plan to navigate using those, so as not to be led astray by the GPS's routing calculations. I believe I've read a few times in this thread and others, that following a Track is the safest way to stay 100% true to the intended path.
A track consists of multiple points and each point is connected by a straight line. It does not necessarily follow the intended path 100%. It is only as good as the points that are in it, the spacing and the accuracy of the device locating those points on the trail when you are using the track. If the points are too far apart (or were not placed properly if the track was made in Basecamp or Mapsource), it is easy to imagine that the track will not exactly follow the intended path on the ground. I think when you understand what a track is, how they were made and to some extent, the gps's accuracty, you will see that it can be very useful navigation tool. However, it is not necessarily 100% true to the intended path, but is instead a good approximation. A route, on the other hand, does more exactly follow the intended path if the routing data in the map is properly produced.
Edit: However, tracks are more accurately transportable between different GPS units because they are not calculated. Since a track is just a consecutive list of points, each GPS unit should see the same set of points with a straight line from one point to the next and they will all be equally as accurate or inaccurate on each unit.
Is it correct that the Montana won't do Turn-By-Turn directions when following a Track? (So, in effect, there is no "routing" when applied to a Track downloaded onto the Montana.)
Only routes do turn-by-turn directions. Tracks do not.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance screwed with this post 05-22-2013 at 09:29 AM
FatChance is online now   Reply With Quote
Old 05-22-2013, 09:00 AM   #7924
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,299
Originally Posted by Adventure Addict View Post
When navigating a track, what is the Montana basing the "distance to next" information on? Usually the distance just clicks off to zero, then it throws up another seemingly arbitrary "distance to next"
I can see no obvious pattern to what it is choosing... The tracks being navigated are continuous tracks that I had logged in the GPS on previous rides without making any stops, so where it is getting these "next" points??
A track consists of multiple points (lat/long) with an "imaginary" straight line connecting each consecutive point. It is not "continuous" like a route but is instead made up of discreet points separated by a distance determined by the rate at which the points are captured by the device and the speed at which you are moving when the track is created.
Durango, Colorado
Old 05-22-2013, 09:17 AM   #7925
MizzouRider
MizzouRider's Avatar
Oddometer: 1,773
I should have noted it at the time, and now I can't find it.
On my Alaska trip I have tracks of the whole trip going up in purple/pink, coming back in the bright green.
Then I'm going to run the routes (daily) over them.
What are the best colors to run, so I can see both clearly? (Routes and tracks)
Sorry for my poor searching abilities.
Jeff
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 05-22-2013, 09:21 AM   #7926
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Jeff
Routes are always displayed in Magenta, and can not be changed.
Routes will always display over tracks below, effectively hiding all portions of a track along the route. This makes it easy to see where the route is not following the track, however.
Track color can be changed, and I suggest using a color not common on the map you will be using, not too dark, not too bright, and not Magenta :)
atlas cached is offline   Reply With Quote
Old 05-22-2013, 10:07 AM   #7927
trampaslake
Oddometer: 256
Is it possible to have more than four icons on the main menu?
trampaslake is offline   Reply With Quote
Old 05-22-2013, 10:12 AM   #7928
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 702
Nope. Change your track to black and when the magenta route is on top of it you will see the thinner black track inside the magenta route line.
IBA #33260
cablebandit is offline   Reply With Quote
Old 05-22-2013, 10:15 AM   #7929
MizzouRider
Oddometer: 1,773
Thanks. Maybe the bright green? That should show up against Magenta.
My plan is to follow the track (if/when) when they differ. Then elect not to recalculate the route when prompted.
Hopefully I'll still end up where I've planned each night.
Thanks again
Old 05-22-2013, 10:18 AM   #7930
cablebandit
Web Adventurer
Oddometer: 702
Note the black TRACK is visible on the magenta ROUTE. It's easy to see where they deviate.
IBA #33260
Old 05-22-2013, 10:20 AM   #7931
cablebandit
Web Adventurer
Oddometer: 702
Yes. Under the Setup -> Main Menu then just hit the + to add more icons.
http://garminmontanagpsr.wikispaces.com/Setup
IBA #33260
Old 05-22-2013, 10:22 AM   #7932
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Of course - go to Setup/Main Menu and click the +. And if you want multiple menus click the right arrow at the bottom of the screen and create more screens for the Main Menu.
Old 05-22-2013, 10:43 AM   #7933
MizzouRider
Oddometer: 1,773
Ok.. Sounds even better.
Old 05-22-2013, 12:06 PM   #7934
atlas cached
OX Ambassador
Oddometer: 688
Read Up! Lots of reading to do!
Old 05-22-2013, 12:08 PM   #7935
atlas cached
OX Ambassador
Oddometer: 688
I stand corrected.
Thanks for the info!
Times are GMT -7.   It's 09:55 AM.
