Thread Tools Search this Thread Rating: Thread Rating: 295 votes, 4.91 average. Display Modes
Old 09-17-2011, 06:45 PM   #811
waynegs
waynegs's Avatar
Oddometer: 231
Originally Posted by DRTBYK View Post
Good catch - It also doesn't clear the Satellite objects when you change pages unless there is a Dashboard that will overwrite the Satellite Dash objects.
Change page. . .
Cheers,
I've seen the main menu bitmap get screwed up in a bunch of instances, leaving the map etc. I wonder what processor / OS they're developing this in? We ran into some horrible memory management issues at work - infamous compiler bugs (real ones, not blamed to cover coding bugs).
waynegs is offline   Reply With Quote
Old 09-18-2011, 10:50 AM   #812
Romatsu
Romatsu's Avatar
Oddometer: 50
Montana AMPS rugged mount.
The two screws holding the contacts look like they are not in all the way.
Anyone elses similar?
Romatsu is offline   Reply With Quote
Old 09-18-2011, 11:29 AM   #813
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,463
All three of my AMPS mounts are like that.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 09-18-2011, 01:49 PM   #814
Romatsu
Romatsu's Avatar
Oddometer: 50
Cheers,
Old 09-18-2011, 02:49 PM   #815
DRTBYK
DRTBYK's Avatar
Oddometer: 5,463
Bummed!
I was loading up my "new" Montana this morning with a few tracks and waypoints to go for a ride (beautiful day!) I unmounted the volume from my Mac and waited for it to boot. . . . and waited. . . and waited. . .
Finally, I realized that it was "frozen" in the boot process so I removed the battery and my microSD Card and then replaced the battery and pressed the Power On/Off button. No joy. It gets to the "Loading Photo's" part of the boot sequence and there was a "White Screen" flash and the unit shutdown. I then tried a Master Reset. It appeared to work properly but the boot sequence again shutdown as before. Now, it just "freezes" during the boot process. Since it can't make it through the boot process, it can't go into USB Mass Storage Mode.
Bummer. . .
I can't tell if this problem due to Firmware failure or if it is due to installation of v3.40 - which I did upon receiving the "new" unit.
Looks like another call to Garmin on Monday and two or three weeks without my Montana.
Cheers,
Cheers,
Dan
All Things GPS
Old 09-18-2011, 03:06 PM   #816
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,521
Cheers,
Jeez, that's terrible. Garmin had better cross-ship to you this time, don't you think?
Old 09-18-2011, 03:18 PM   #817
bmwgrrl
Goin' Minimalistic
bmwgrrl's Avatar
Oddometer: 438
sigh. And that's why I still carry my Oregon as a backup. :(
Sent via Tapatalk iPhone - The scourge of workplace productivity.
2005 BMW F650GS
Emma Beagle, 11.1.96-5.11.11
You Ride Shotgun on my Shoulder Now
Not All Who are Lost Wish to be Found
bmwgrrl is offline   Reply With Quote
Old 09-18-2011, 03:42 PM   #818
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,521
Originally Posted by bmwgrrl View Post
sigh. And that's why I still carry my Oregon as a backup. :(.
Good point. Must pack my 62S to bring to CroMag.
Old 09-18-2011, 03:50 PM   #819
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 767
I had a simular freeze occur on a previous firmware. I had just transferred a couple GPX files onto the SD card prior to the boot freeze. Occured at the Loading Pictures message.
As a workaround, I removed the micro-SD card from the unit and plug directly into the PC. After removing the GPX files and re-inserting the SD card, unit booted as normal. One of the GPX files was very large (~10MB) so filtered a couple of the alt tracks, regenerated GPX and recopied file to the unit without problem. Only thing that came to mind at the time was Basecamp may have corrupted one of the GPX files?
dvwalker is offline   Reply With Quote
Old 09-18-2011, 03:58 PM   #820
waynegs
waynegs's Avatar
Oddometer: 231
Bummer. . .
Cheers,
Have you tried leaving the power off and plugging it into the USB port and letting that wake the processor up? Probably won't make any difference, but worth a try if not done before.
Old 09-18-2011, 04:42 PM   #821
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,521
Now that I think about it, I had this same kind of thing happen. The Montana took such a long time to start up that I thought it had locked but it was just very very slow, and when I left it for an hour, it did finish and start up, and has been normal ever since.
Old 09-18-2011, 07:57 PM   #822
DRTBYK
DRTBYK's Avatar
Oddometer: 5,463
Thanks folks. . .but,
Confession: I keep a database of ALL of the bugs and anomalies that are posted here and on the other forums I frequent - good (old) development habits are hard to brake.
But, one has to acutally check the database - oops
I let the unit sit (frozen) in the boot process at the Copywrite screen (hasn't read the startup.txt file yet) for two hours with no change. I did this with both battery power and USB power.
Hello? Garmin. . .
Cheers,
Cheers,
Dan
All Things GPS
Old 09-18-2011, 10:35 PM   #823
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 767
one more thing you might try to force the USB connection, worth a shot anyway...
  1. turn off the device
  2. hold down the power button and connect the device to your computer via USB
  3. continue holding power button for 30 seconds or until device goes into mass storage mode
Old 09-19-2011, 08:28 AM   #824
DRTBYK
DRTBYK's Avatar
Oddometer: 5,463
Thanks, I tried that one last night - after I read through my database notes
I did manage to get into USB mode on the second try but even using WebUpdater the boot loader still "freezes" at the Copy-write screen - yep, I still let it sit for over an hour - no joy.
Hello? Garmin. . .
Cheers,
Dan
All Things GPS
Old 09-19-2011, 09:36 AM   #825
DRTBYK
DRTBYK's Avatar
Oddometer: 5,463
Joy. . .Sort of
Isn't it always the way. . .
As I was talking with Product Support, it dawned on me that, although I had deleted the data I placed on the Montana (Custom Symbol) while in USB mode last night, I did not replace my Factory image. I decided to try one thing at a time. First up was the Profile Folder. Disconnect USB and Power On. BOOT, BOOT, BOOT. . . It worked! Said thanks to Product Support for engaging my brain and I'm back in business.
Now, where is that Custom Symbol that started all of this? By the way the Custom Symbol works in BaseCamp just fine and it worked on my previous Montana. I'll update when I figure it out.
Cheers,
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 09-19-2011 at 10:35 AM
Times are GMT -7.   It's 12:24 PM.
