Thread Tools Search this Thread Rating: Thread Rating: 403 votes, 4.93 average. Display Modes
Old 06-16-2013, 08:08 PM   #8446
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,876
Originally Posted by Feelstranger View Post
Thanks for the reply folks.
Well, I'm not impressed. This unit is messed up for sure, after a single 2 day ride on dirt roads. I've got it mounted to a ram mount, and 1 ear plug under the cover failed to stop the "unsupported battery" warning, and shut downs. Then near the end of the second day, the screen calibration issue started.
I just installed 5.0 (from 4.9) and did a master reset before, and after the upgrade, and it's still acting the same. The screen is uncalibrated enough to make it difficult too select items I want, and the screen calibration program gets stuck in a continuous loop - after pressing the dots as needed, I see a brief flash of the display setup screen again, and then it goes back into the calibration program. Have to shut it down to get out.
No screen protector on the unit, and I'm inside (no sun).
I hope Garmin hooks me up, and fast, but I still wonder if I can trust this thing to get me along the CDR starting in 3 weeks...
Your problem sounds strangely like the problems seen in the very first Montana's released. Where/when did you purchase your unit?
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 06-16-2013, 10:23 PM   #8447
BogeyMan
BogeyMan's Avatar
Oddometer: 451
I had this same issue - infinite loop in screen calibration mode.
Call/contact Garmin support - they replaced my unit.
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 06-17-2013, 07:15 AM   #8448
Two VT Riders
likely lurking
Two VT Riders's Avatar
Oddometer: 32
Yup, mailed off this am to Garmin for replacement.
Hopefully, the replacement will prove more robust than the previous, or my CDR ride may get interesting.
Two VT Riders is offline   Reply With Quote
Old 06-17-2013, 07:17 AM   #8449
Two VT Riders
likely lurking
Oddometer: 32
I bought it from the 'bay - completely unused - this winter.
Battery was manufactured in '11.
Old 06-17-2013, 07:50 AM   #8450
DRTBYK
DRTBYK's Avatar
Oddometer: 5,876
Almost all of the batteries were Mfg'd in 2011 but if your unit S/N was one of the original models it's pretty nice of Garmin to honor the warranty on a two year old eBay unit.
Cheers,
Dan
All Things GPS
Old 06-17-2013, 07:59 AM   #8451
Two VT Riders
likely lurking
Oddometer: 32
is there a serial number/date list someplace?
And indeed, Garmin is treating me well.
Old 06-17-2013, 08:15 AM   #8452
Cataract2
Where to?
Cataract2's Avatar
Oddometer: 1,788
So, got my Montana 600 finally. Something I wonder about. It's mentioned an ear plug in the battery compartment to keep the battery from coming loose. I noticed in mine there is some foam already on the cover and backing of the compartment. Did they make a change in the design to fix that issue?
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Old 06-17-2013, 08:18 AM   #8453
DRTBYK
DRTBYK's Avatar
Oddometer: 5,876
No list but this link to earlier discussions here might be helpful....
Cheers,
Dan
All Things GPS
Old 06-17-2013, 08:40 AM   #8454
drkab1
Oddometer: 9
A little guidance please!
I am leaving to ride the TAT next week. I have tracks entered for every leg except Oregon and Nevada, so I ordered them from Sam. They come as a ".gdb" file via email. Would someone be so kind to walk me through the sequence of key strokes to ge the data to my Montana. Thank you in advance!
DocBaby
drkab1 is offline   Reply With Quote
Old 06-17-2013, 08:41 AM   #8455
Two VT Riders
likely lurking
Oddometer: 32
Mine was 28t 000xxx
Old 06-17-2013, 08:47 AM   #8456
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
DocBaby
1. Create a new List in BaseCamp
2. Import the Garmin DataBase file into your new List
3. Send the List to your Montana
atlas cached is offline   Reply With Quote
Old 06-17-2013, 09:03 AM   #8457
DRTBYK
DRTBYK's Avatar
Oddometer: 5,876
Mine was 28t 000xxx
Yes...a very early S/N.
Cheers,
Dan
All Things GPS
Old 06-17-2013, 09:07 AM   #8458
DRTBYK
DRTBYK's Avatar
Oddometer: 5,876
The later units have a thicker pad of foam at the end of the battery compartment opposite of the contacts. But, I think you'd be well served to still put an earplug in there or some tap on the sides of the battery at the contact end.
Cheers,
Dan
All Things GPS
Old 06-17-2013, 09:08 AM   #8459
Rocky TFS
Rocky TFS's Avatar
Oddometer: 578
Yes, the newer ones have the extra foam. If you get no un-announced shutdowns you are good to go. If you do still have issues, try two plugs.
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 06-17-2013, 09:17 AM   #8460
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
Even with the extra foam you still see shutdowns. I spoke to a couple of guys this weekend who experienced that exact situation. Just put an earplug under the battery cover and be done with it.
Times are GMT -7.   It's 04:11 AM.
