Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 468 votes, 4.94 average. Display Modes
Old 06-17-2013, 09:20 AM   #8461
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Originally Posted by Emmbeedee View Post
Just put an earplug under the battery cover and be done with it.
Or two. Or three.
atlas cached is offline   Reply With Quote
Old 06-17-2013, 10:03 AM   #8462
Rocky TFS
Rocky TFS's Avatar
Oddometer: 605
Originally Posted by atlas cached View Post
Or two. Or three.
Interesting placement. I did three side by side on the cover. I still have the occasional shutdown, but I can't correlate it to use on the TW in the dirt (very buzzy), on the BMW on the slab (pretty smooth), and in the Toyota (very smooth).
It seems totally random and only happens three or four times a month....
The ear plugs are two years old, so I am replacing them with fresh ones.
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 06-17-2013, 10:03 AM   #8463
SteveAZ
SteveAZ's Avatar
Oddometer: 1,219
I've found an interesting....feature...I'm not sure what's going on...
I've got CN installed and enabled, firmware 4.7. I do a search for a "recent find" POI and hit "go" (automobile routing). I got the following screen:
Since that didn't make much sense, I rotated to portrait and got this:
When I touch "yes" I get this:
If I touch "no" it just bails on routing.
Not sure what's up....
SteveAZ is offline   Reply With Quote
Old 06-17-2013, 10:52 AM   #8464
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,979
Or two. Or three.
Mine and my wife's 650 have never shut down once since we put the one earplug into each, under the battery cover itself. We all know how expensive they are, so I prefer to use only one.
Emmbeedee is online now   Reply With Quote
Old 06-17-2013, 10:58 AM   #8465
SKINNY
SKINNY's Avatar
Oddometer: 668
Even with the extra foam you still see shutdowns. I spoke to a couple of guys this weekend who experienced that exact situation. Just put an earplug under the battery cover and be done with it.
My experience with 2 different 600's in rough off-road use says foam doesn't work...
best solution is to throw the rechargeable battery in the trash and use AA lithium's
SKINNY is offline   Reply With Quote
Old 06-17-2013, 03:43 PM   #8466
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 836
The only time I've seen this come up is when the only map that was enabled was the base map. Did you inadvertently change profiles that disabled the CNNA map?
FireDog45 is offline   Reply With Quote
Old 06-17-2013, 03:49 PM   #8467
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,979
Maybe you throw them out but I'd think most people don't have any problems once the battery's shimmed with an earplug.
Old 06-17-2013, 03:52 PM   #8468
Timmer
Timmer's Avatar
Oddometer: 2,409
That has happened to me when I created a route in BC on a different version of CN than was installed on the Montana.
Tim
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 06-17-2013, 06:00 PM   #8469
Rocky TFS
Rocky TFS's Avatar
Oddometer: 605
Tim
Yup, that's it. Every damn time you update CNNA on both BC and Montana you have to go through every single non-direct route on BC, change it to direct, then back to automobile or moto and let it re-calculate.
Or, like me, you can just save every route as direct in BC after fiddling with it on CNNA and automobile profile to get it correct for autorouting. Of course, when loaded on the Montana with a new CNNA version, it may not autoroute the way the older version did, so back to above kludge.
2010 Yamaha TW200
Old 06-17-2013, 06:43 PM   #8470
SteveAZ
SteveAZ's Avatar
Oddometer: 1,219
I haven't updated CN since I got the unit and the POI it puked on has only been on the recent find list a couple of weeks... Most of the recent finds work ok too, I could only find a couple of others that caused the puke. I'll look at it some more and see if I can figger it out...
Old 06-18-2013, 01:33 AM   #8471
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
Originally Posted by TravellingStrom View Post
I am not sure if this a fault of myself in setting it up or a Garmin design fault on a 650T
I make a waypoint and use Automotive mode to navigate to near it( it is a geocache) Once I park up I change to Geocache mode but it cannot see this waypoint, so I change to Recreational instead and I get the magneta line pointing to the waypoint
The problem is, it won't give me the distance to destination? There is the scale showing and bearing line but I have to guess using the scale how far to the point
What am I doing wrong, surely the basic idea of a GPS is to navigate in a straight line to a waypoint and the distance to it is essential information?
Cheers from Oz
TravellingStrom
Bump. Any ideas?
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 06-18-2013, 04:11 AM   #8472
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,979
New software out for the Montana. Version 5.10 shows up in Garmin Express. Haven't tried it yet.
Change Log:
Changes from version 5.00 to version 5.10:
Added support for additional ActiveRouting cartography
Improved support for Garmin LakeVu HD cartography
Fixed issue with incorrect letter capitalization of certain map points
Fixed issue where wirelessly transmitting a geocache to another device would result in an error message when trying to view the received geocache in BaseCamp
Emmbeedee screwed with this post 06-18-2013 at 04:26 AM
Old 06-18-2013, 04:52 AM   #8473
johnpitts01
johnpitts01's Avatar
Oddometer: 1,099
Loading CN to Basecamp on laptop
I know it's in this thread somewhere. I dont know how to structure a search to find it....
I have CN with lifetime updates loaded on the Montana. I want CN on Basecamp without the Montana connected. I want the ability to create routes on the laptop without the necessity to connect the Montana all the time.
Please point me to the post with the instructions or tell me (again).
John
johnpitts01 is offline   Reply With Quote
Old 06-18-2013, 05:11 AM   #8474
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,979
When you install maps you need to check this box in the Lifetime Map Updater (Mac version displayed but there is a Windows equivalent).
Old 06-18-2013, 06:50 AM   #8475
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 6,162
Cheers from Oz
TravellingStrom
Is it just one waypoint or does this happen repeatedly with all waypoints used to Direct Route while in Geocaching Profile?
I've never seen or heard of this as a "bug" so I'd guess that you have some corrupt data (waypoint). Delete it and create a new one.
Dan - All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Times are GMT -7.   It's 11:16 AM.
