Thread Tools Search this Thread Rating: Thread Rating: 369 votes, 4.93 average. Display Modes
Old 07-09-2013, 08:14 PM   #8731
marbee40
Some Fear is Good
marbee40's Avatar
Oddometer: 1,116
Trust me, if I could troubleshoot it, I would.
R1150GS
01 WR426F
marbee40 is offline   Reply With Quote
Old 07-10-2013, 11:07 AM   #8732
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,512
Having problems with the speed of my unit. It will still be saying turn right a minute after I have made a turn and often that causes me to miss the next turn if I am city driving. Seems slow drawing maps also.
I am using City Nav from 2011, will a newer map help? I've done a hard reset.
B.E. Coyote is offline   Reply With Quote
Old 07-10-2013, 11:20 AM   #8733
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,656
Do you have multiple maps enabled at the same time? That can slow things down. And if your Map Speed is set to Fast, you may be losing signal. Maybe turn it to Normal, if it's set to Fast.
Emmbeedee is online now   Reply With Quote
Old 07-10-2013, 11:27 AM   #8734
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,663
I normally run multiple mapsets on my Montana.
For example, the 100K topo, some state 24K topo, Baja, and CNNA latest version.
For the 100K Topo profile I disable CNNA in that profile.
For the 24K profile, I disable CNNA and 100K topo.
For Nuvi and CN profiles, I leave everything enabled, as CNNA mapset has a higher priority over the topo mapsets.
Should I disable the topo mapsets within the Nuvi and CN profiles?
Old 07-10-2013, 11:33 AM   #8735
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,656
Unless you want to use Snooker's trick, I would disable any map which isn't necessary. That's why I have a profile configured for each map. Makes it very easy to switch quickly.
Old 07-10-2013, 11:50 AM   #8736
OneEffinName
Oddometer: 466
Show All Tracks
Hi
is there an easy way to "Show All Tracks" on the Montana? I searched this thread and google. Found a bunch of requests, but no solution.
thanks
Check out Don's Adventure Blog http://cameronsoftware.com/blog/dons...dventure-ride/
2012 KTM 350 excf
2015 KTM Freeride 250
2012 GasGas Raga
OneEffinName is offline   Reply With Quote
Old 07-10-2013, 11:54 AM   #8737
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,656
Originally Posted by OneEffinName View Post
Hi
Nope. There is no easy way to enable multiple tracks on the map. There are other alternatives like IMGfromGPX, a Javawa tool which can have a similar effect, though.
Old 07-10-2013, 12:41 PM   #8738
OneEffinName
Oddometer: 466
Yeah I saw that - I dont want to really have to create and install a map each time I want to simply show a bunch of tracks. I suppose it is worthwhile for more static tracks.
2012 KTM 350 excf
2012 GasGas Raga
Old 07-10-2013, 01:24 PM   #8739
konfucius
konfucius's Avatar
Oddometer: 220
Hi
thanks
Why don't you just set Show On Map on each of the track you want to be visible on the map?
You can set different colors on them to distinct them from each other.
konfucius is offline   Reply With Quote
Old 07-10-2013, 01:28 PM   #8740
OneEffinName
Oddometer: 466
It becomes a pain to "show on map" for each individual 50 tracks. It would be nice to have a "show all tracks". Even more of a pain when I do this evyer 2nd or 3rd day for many of the areas I go to.
2012 KTM 350 excf
2012 GasGas Raga
Old 07-10-2013, 05:37 PM   #8741
waynegs
waynegs's Avatar
Oddometer: 231
Enabling more than one map at a time slows my 650t. I leave the basemap enabled and one map only on any profile.
waynegs is offline   Reply With Quote
Old 07-10-2013, 05:45 PM   #8742
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,656
Good point - I forgot to mention I also leave the Basemap enabled in all the map profiles. There is a consensus that disabling the Basemap or deleting it from the gps will slow the gps. The Basemap also includes the DEM (Digital Elevation Model) data.
Old 07-11-2013, 06:04 AM   #8743
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,663
Okay, I'll make changes to the profiles that I use to have the fewest reasonable number of mapsets enabled per profile.
In the case of my 24K topo profile, I'm going to leave all of the 24K maps enabled, as none of them overlap. Make sense?
Old 07-11-2013, 06:12 AM   #8744
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,656
No problem at all, leaving all the 24k maps enabled.
Old 07-11-2013, 07:51 AM   #8745
esp41
esp41's Avatar
Oddometer: 119
Originally Posted by DRTBYK View Post
Download JavaWa Device Manager and set your CNNA to "show in BaseCamp".
Only factory installed maps show automatically in BaseCamp. Otherwise you need to use a program like JaVaWa to change the bit in the Map so it will show.
Have a great ride!
Interesting enough, his non factory installed CNNA shows in Basecamp.
None the less, I did the JavaWa thing on my GPS and it works great. Maps from my GPS are now showing.
Thank You
2006 Husqvarna TE610- TAT 2013 survivor!
TAT Ride Report Here
2008 KTM 300 XCW-e
1993 Harley Heritage Classic
Tomos ST
esp41 is offline   Reply With Quote
Times are GMT -7.   It's 05:48 PM.
