Thread Tools Search this Thread Rating: Thread Rating: 340 votes, 4.92 average. Display Modes
Old 07-21-2013, 12:55 PM   #8866
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Originally Posted by DirtSolace View Post
You were correct: tracks & waypoints & profile customizing NOT lost, although menu priorities: hierarchical standings defaulted to original ordering.
Unfortunately, reset did not solve the problem. Intend to contact GPSCity and Garmin by phone on Monday...
Unless--more Inmates have suggestions?
I did reset "backlighting" to "stay on" with no result....
Are you sure it's getting full power from the mount? Have you tried different mount systems, or even powered via usb cable to see if it behaves any differently?
Old 07-23-2013, 10:35 AM   #8867
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 345
Picked up a 600 this weekend. First off, thanks for this thread...yes, all 500+ pages. Second, I have a question. With the included general map is it normal for the accuracy to be off? I hit Track on the way home just to play with it. It shows my location about 100 feet off. Did I miss some setting or is this normal with the included maps?
THRASHED is offline   Reply With Quote
Old 07-23-2013, 10:43 AM   #8868
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 701
Seems a little off. Do you have WAAS turned on under Setup/system/gps?
IBA #33260
cablebandit is offline   Reply With Quote
Old 07-23-2013, 11:00 AM   #8869
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 345
Nope, it is set to Normal.
Old 07-23-2013, 11:05 AM   #8870
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,351
The included Base Map is not meant for use below about the 2 mile scale
You have to have detailed maps at the closer zoom levels.
The base map just is not accurate at the closer zoom levels.
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE
Robert
rwamf homepage
rwamf is offline   Reply With Quote
Old 07-23-2013, 12:00 PM   #8871
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 345
rwamf. Thanks for that. I kind of figured that was the case. I'm going to order maps this week (or hit up Airborndad for some of his )
Old 07-23-2013, 01:00 PM   #8872
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,418
Originally Posted by Emmbeedee View Post
Well I must be living right, because on version 5.10, I still have the Speed Limit indicator and the Lane Guidance info. I went on a 4 lane highway today, just to see if it was there. (The things I do for the sake of knowledge!)
Just curious, but if you're not navigating a route will you still see the speed limit indicator on the Nuvi screen?
Old 07-23-2013, 01:28 PM   #8873
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Yes, I do.
Old 07-23-2013, 01:37 PM   #8874
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,418
Ehhh, I thought so. Guess mine doesn't work then and I rolled back to the 4.9 firmware. The speed limit data is in the main map file right?
Old 07-23-2013, 01:52 PM   #8875
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,653
I believe it's in the CNNA mapset; at least, the only time I get limit data is when CNNA is enabled.
Old 07-23-2013, 01:54 PM   #8876
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Not sure where it is, but the Speed Limit field shows up on the Nuvi screen even if CNNA is disabled. I run an old map called Canada Enhanced Basemap most of the time and it dates back to Y2K, and I see the SL info on that one too.
Yossarian and I are at odds, apparently.
Here's a screen shot of CEB, the old mapset, with the SL showing. I know the mapset is CEB because there isn't another mapset which displays more back road data at that resolution.
Old 07-23-2013, 02:12 PM   #8877
Countdown
Oddometer: 5,454
Robert, are you on the way to Colorado?
Jerry Counts
Countdown is online now   Reply With Quote
Old 07-23-2013, 03:00 PM   #8878
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Can we stay on topic? PM if you're chatting.
Old 07-23-2013, 06:27 PM   #8879
SheRidesABeemer
Go Big or Go Home.
SheRidesABeemer's Avatar
Oddometer: 1,952
Can someone point me to the thread that shows me how to activate the City Navigator map on the device? I took it out of the box yesterday, uploaded the city navigator NA map, on what I thought was the device, but I can't see it in the map menu.
MyGarmin says it's loaded and activated
From Basecamp, I can select city navigator NA
I created a route and uploaded it to the device, but it shows up as a straight purple line (no streets)
Help...
Gail
My Blog
05 R1200GS
87 K75
Do what you love, and do it often.
SheRidesABeemer is offline   Reply With Quote
Old 07-23-2013, 06:29 PM   #8880
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Help...
You probably installed the map to your computer but have not yet loaded it to the gps. Have you run MapInstall? That is how the map would get from the computer to the gps.
Times are GMT -7.   It's 05:36 PM.
