Thread Tools Search this Thread Rating: Thread Rating: 428 votes, 4.94 average. Display Modes
Old 07-27-2013, 04:43 PM   #8941
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Originally Posted by DabsAlot View Post
I seem to have a corrupt track in my Archived track file. When selecting the track in the Montana, it will either lock up or shut down. I can't see the track in BaseCamp, nor can I delete in Windows explorer.
Here is a message I receive when I connect the Montana to my PC (Win 7):
What can I do to correct this?
Steve
^^ Yes I have tried to rename it and I receive the error message:
"The file name you specified is not valid or too long. Specify a different file name".
And I have tried several different file names, including trying to match the track log format.
Steve
Originally Posted by Emmbeedee View Post
If it's in the Archive, try to make a Favorite out of it, then see if you can delete it from the Track Manager. I got rid of a defective file that way recently.
I have an Oregon 6xx with the same issue. The file is corrupt, and un usable. The file can not be moved, renamed, deleted, etc. I suspect an internal memory failure of the GPSr.
The track on my Oregon 6xx has been like this for months, and Garmin has yet to tell me how to resolve the issue.
I think your Montana and my Oregon 6xx need new motherboards. :(
atlas cached is offline   Reply With Quote
Old 07-29-2013, 12:18 PM   #8942
Ridin'nFishin
Oddometer: 504
Thinking of buying a Montana 600 with City Navigator Noth America NT.
Which is better: Download, DVD or MicroSD Card?
Ridin'nFishin is offline   Reply With Quote
Old 07-29-2013, 12:21 PM   #8943
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 705
Dvd.
IBA #33260
cablebandit is offline   Reply With Quote
Old 07-29-2013, 12:27 PM   #8944
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
1 - DVD
2 - SD
3 - Download
The dvd is most flexible and can be updated, while the sd and download can't be updated.
The SD version has a big advantage in that it can be used in any Garmin device which accepts the card while both of the others are associated with one device when you load the map.
Old 07-30-2013, 06:29 AM   #8945
Jon_PDX
Oddometer: 1,106
That brings up a question that I think may have been answered in this thread but I can't remember the answer.
If you have the SD card with CNNA (or another country for that matter) in the unit I know base camp will load the map but does base camp use the map on SD so you can create routes, etc... and save them to your computer? Or can you only save the routes you create back to the GPS?
I think I asked that correctly.
Also, besides not being able to update the map without buying a new SD card, are their any other limitations to having the map(s) on SD other than having to plug the GPS into the computer every time you want to work with the map in base camp?
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 07-30-2013, 07:46 AM   #8946
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,806
Yes, you can use the maps on the SD card, and you can save the routes you create to your computer.
Old 07-30-2013, 08:04 AM   #8947
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 371
So, I've got the thing mounted and am ready for wiring. I would like to go switched and was thinking headlight. Where are you guys jumping in for switched power and do I need a resistor or anything other than splicing materials?
And yes, I did a search first just didn't find the answer I was looking for.
THRASHED is offline   Reply With Quote
Old 07-30-2013, 08:08 AM   #8948
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,688
headlight or parking lamp would work.
I would not think a resistor is needed if you are just supplying power to the cradle.
Old 07-30-2013, 08:56 AM   #8949
cablebandit
Web Adventurer
Oddometer: 705
If you plan on ever adding anything electrical down the road just go ahead an add an auxiliary fuse block now. Then you have a multitude of switched and always on power taps.
It's a lot easier to not burn up your bikes wiring harness this way as well.
IBA #33260
Old 07-30-2013, 10:42 AM   #8950
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 371
Thanks to you both. Not planning on adding anything down the road (hmm, heard that before) so I'll just stick with the headlight idea. Short run AND switched sounds good to me.
Old 07-30-2013, 10:46 AM   #8951
guavadude
de-composer
guavadude's Avatar
Oddometer: 888
be sure to keep the fuse of the amps mount intact.
If you have a parking lamp, use that.
guavadude is offline   Reply With Quote
Old 07-30-2013, 11:37 AM   #8952
BobM
DualSport
Oddometer: 326
... I would like to go switched and was thinking headlight. Where are you guys jumping in for switched power ...
Check your bike's Wiring Diagram as there is often an unused connector that you can plug into without needing to splice into headlamp wiring.
My V-Strom, KlR650 and DR650 all had this spare wire - the V-Strom was for the factory-option heated grips, and the KLR and DR were for the Australian model parking light (I think?).
Bob
BobM is offline   Reply With Quote
Old 07-30-2013, 12:59 PM   #8953
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,633
Anyway you do it I would at least put in a solenoid/relay to handle the load (Montana).
Not that current is that much.
Relays are cheap and easy to do.
And no battery drain with the key off.
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 07-30-2013, 02:07 PM   #8954
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,806
Fred
Adding a solenoid to a switched circuit would be absolutely pointless.
Old 07-30-2013, 02:17 PM   #8955
atlas cached
OX Ambassador
Oddometer: 688
Don't tell that to the Germans....
Besides, depends if the switched circuit is a 'Logic/Control' circuit or 'Work/Load' circuit.
Times are GMT -7.   It's 06:38 AM.
