Thread Tools Search this Thread Rating: Thread Rating: 371 votes, 4.93 average. Display Modes
Old 08-27-2013, 10:48 AM   #9271
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 704
Shaping points
Just loaded up 5.3 and after a couple master resets I got the speed limit back. (it disappeared after the initial upgrade)
Is anyone else having issues with shaping point still alerting after you mark them as "won't alert" in the routing properties? It's rather annoying.
IBA #33260
cablebandit is online now   Reply With Quote
Old 08-27-2013, 11:40 AM   #9272
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,768
Only the zumo's support Shaping Points.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is online now   Reply With Quote
Old 08-27-2013, 12:25 PM   #9273
cablebandit
Web Adventurer
Oddometer: 704
So I guess there is no good reason why they never announced prior to 5.2?
IBA #33260
Old 08-27-2013, 03:29 PM   #9274
achesley
Old Motorcyclist
achesley's Avatar
Oddometer: 3,463
Hot Montana 600 quit working today. Was riding along in about 95F sunny skies and it started reverting to 20 ft read out. Then quit responding to attempts. Turned it off for a few miles then back on. Main screen came up and no response. Now cooling off in the garage. Anyone have had this problem.
A '00 KLR 650 40,000 miles, A '07 1250S 74,000 , A '03 5.3L Chevy Truck 78,000 + '43 style dude , Simper Fi ;-)
achesley is offline   Reply With Quote
Old 08-27-2013, 04:42 PM   #9275
BruceWA
Oddometer: 556
Could this be related to a screen protector??
Figures don't lie, but liars can figure
BruceWA is offline   Reply With Quote
Old 08-27-2013, 04:45 PM   #9276
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,601
There has been a problem with the screen protector shrinking on expanding in the heat.
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 08-27-2013, 04:54 PM   #9277
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,670
Sounds like that to me. An extreme case.
Emmbeedee is online now   Reply With Quote
Old 08-27-2013, 05:44 PM   #9278
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,601
Look here
And the whole thing here.
It's a lot of good info.
Fred
YouTube feed
Old 08-27-2013, 10:19 PM   #9279
Timmer
Timmer's Avatar
Oddometer: 2,340
Updated to 5.3 and CNNT 2014.2
I've got a couple 1k mile plus rides in the next few days, so I decided to update the Montana to 5.3 firmware (Master Reset performed), and 2014.2 of the maps. for the first trip I have 21 'bonus' locations to hit in Eastern WA. For the second trip I have 5 all over Oregon. This should give a good work out to the 5.3 firmware. If it doesn't work, I'll go back to 4.7 which has been rock solid for me. I'll post my results sometime next week.
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 08-27-2013, 10:26 PM   #9280
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Excellent! Make sure you have Map Speed = Fast for those tests!
atlas cached is offline   Reply With Quote
Old 08-28-2013, 10:59 AM   #9281
SteveAZ
SteveAZ's Avatar
Oddometer: 1,195
Wish for timed auto power off function. Tired of dead battery(s) from leaving it on. Many other battery operated devices have this feature and it's very useful and would be extremely easy to implement on a GPS... Oh well...
SteveAZ is offline   Reply With Quote
Old 08-28-2013, 11:05 AM   #9282
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,601
There is a battery save feature.... setup /display
Fred
YouTube feed
Old 08-28-2013, 11:31 AM   #9283
DRTBYK
DRTBYK's Avatar
Oddometer: 5,768
So, you want a "Power Off if no movement in 2hours" feature?
Cheers,
Dan
All Things GPS
Old 08-28-2013, 12:01 PM   #9284
atlas cached
OX Ambassador
Oddometer: 688
Again, use a relay.
Old 08-28-2013, 12:03 PM   #9285
SteveAZ
SteveAZ's Avatar
Oddometer: 1,195
That actually makes things worse. It turns off the display and makes it even more likely to set the unit down and forget it's powered up. I can't tell you how many times I pick up the unit and then have to plug it in because I've set it down powered up and it's drained and I'm either throwing out a set of AA's or know I'm reducing the life of the more expensive Li battery for no good reason.
That would be good. Even simpler, power off after two hours (or one hour or half an hour, my radios do it like this and have similar "stand-by" battery draws) on battery (movement or no) would be ok with me. Send a message box up like it does when you remove external power that says it's powering down unless you tell it not to... tell it not to and it restarts the auto-power off timer...
I know it would help me a lot. no matter how many times I kill the battery I still keep setting it down powered up. Sometimes it's after using it handheld. Sometimes it's after setting it up. Sometimes it's because I go turn it on and set it down while waiting for it to complete the lengthy (too long in my book!) power up cycle and get distracted....
Times are GMT -7.   It's 10:15 AM.
