Thread Tools Search this Thread Rating: Thread Rating: 396 votes, 4.93 average. Display Modes
Old 09-11-2013, 09:13 PM   #9421
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Originally Posted by Coho911 View Post
I'm having a problem with my new 650T...
I load north America City Navigator in and my Ibycus topo - ***BUT***
When I look at the maps available in my GPS, it comes up as them combined.... however.... no matter what zoom, no Topo shows.
And they were loaded at the same time but as 2 different maps with Roadtrip.
HELP !
Try again using MapInstall.
atlas cached is offline   Reply With Quote
Old 09-11-2013, 09:53 PM   #9422
Coho911
Coho911's Avatar
Oddometer: 1,369
Originally Posted by atlas cached View Post
ok - trying again with Ibycus 3.2 in .gmapi (Mac format)....
2007 KTM 640 Adventure 'Bricktop'
----> LC4 Info Thread <----
So many places to go and see, so little time...do it whenever you can, cause too late comes fast. - Coho
The internets BEST Site for Image Hosting ---> Smugmug <--- SAVE $ 5.00 on smugmug membership with this COUPON - hUuJ7EHBKXWDU
Coho911 is offline   Reply With Quote
Old 09-11-2013, 10:38 PM   #9423
Coho911
Coho911's Avatar
Oddometer: 1,369
No Go, used Mapinstall and got the Ibycus Topo 3.2 Label but no Topo & all the City Navigator info/maps.
Trying again now with Garmin Topo Canada. Gonna see if that works.
Am I supposed to upload maps from Base camp ?
Old 09-11-2013, 10:40 PM   #9424
atlas cached
OX Ambassador
Oddometer: 688
The complete process is demonstrated for you step-by-step at the link I provided.
Old 09-12-2013, 12:05 AM   #9425
Coho911
Coho911's Avatar
Oddometer: 1,369
Yeah, I have been following it, my Mac will go to step 3 but not 4, won't recognize the GPS. It will see the SD card, but when I install it all per the step by step - still not showing the maps per step 4 even though the SD card memory shows more maps/data is on there - nothing is seen by my Mac. Arg.
***But 650T DOES show the USB symbol on the screen when USB is plugged in. wtf. Maybe time to try a hard reset of the device.
Old 09-12-2013, 01:04 AM   #9426
Coho911
Coho911's Avatar
Oddometer: 1,369
Awesome. This thing won't even hard reset - yes I am doing it right, POwer off, top left corner pressed, power cycle on - continue holding left corner until hard reset yes/no screen comes up.
Nothing. Mine keeps going right through to normal menu.
It would seem I might have one of the buggy ones. Awesome. glad I still have my 60CSx - THAT is a machine.
Old 09-12-2013, 05:20 AM   #9427
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,618
Try doing the reset again but move your finger around and lifting it off the screen.
Still keep it in the lower left of the screen.
Mine does the same as yours sometimes.
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 09-12-2013, 05:22 AM   #9428
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,753
Maybe you're not pressing hard enough.
The 60CSx is an antique. Good in its day but very limited. I don't miss mine one bit.
Old 09-12-2013, 06:35 AM   #9429
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,618
I had another thought on this reset issue.
My Nuvi would sometimes lockup.
To fix this I would leave it on till battery went dead.
Then plug it back in and restart.
Same as reset.... I'm not sure but worth trying.
Fred
YouTube feed
Old 09-12-2013, 06:56 AM   #9430
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,753
New Garmin Montana
Fred
This would be a waste of time. The Nuvi differs from the Montana in that you can't remove the battery. You can on the Montana, obviously.
My Nuvi 780 in the car locks up fairly often. I just restart it by removing the power cable and holding the power button down for 20 seconds, which eventually kills it.
I then restart with my finger in the lower right, then when it asks if I want to reset, I say No, and it continues to start normally.
Emmbeedee screwed with this post 09-12-2013 at 07:16 AM
Old 09-12-2013, 02:28 PM   #9431
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 501
OK. First off - I just finished my first 4000 mi long ride with my Montana. Long slab ride at each end, with lots of curvy routes and tracks in the middle. Being able to switch back and forth between profiles was awesome. I should have got this thing sooner.
But - it has a weird glitch. I hope I can explain this right...
Automotive Mode, navigating either Short Dist or Fast Time.
While navigating a route that has long (30mi+) stretches between turns, it kinds goes nuts at a predictable point.
As you ride along the long stretch, it zooms out and gives you the bird's eye view. As you get in closer to the next turn, it zooms in. Normal.
Except: At about 8.5 miles from the turn, where it would make the switch to zoom in - - it gets confused and can't decide whether to zoom in or stay zoomed out. Back and forth it goes until exactly 6 miles from the turn, then it stays zoomed in. While this is happening, the screen position starts wandering off course.
It's a hard issue to Google to see if it's common, etc.
Any ideas?
NCD is offline   Reply With Quote
Old 09-12-2013, 02:51 PM   #9432
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,829
Any ideas?
I have a lot of miles on my Montana and I have never seen that one. Did you do a Master Reset anywhere along the way to see if that would clear the issue?
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK screwed with this post 09-12-2013 at 03:06 PM
DRTBYK is offline   Reply With Quote
Old 09-12-2013, 03:08 PM   #9433
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,618
Update the Montana if you haven't then do reset.
Fred
YouTube feed
Old 09-12-2013, 03:10 PM   #9434
Countdown
Oddometer: 5,658
What do you mean "kills it"?
My 760 locks up. Garmin said to power on holding lower right but unless I say "Yes" and loose a bunch of data, it locks again quick.
Jerry Counts
Countdown is offline   Reply With Quote
Old 09-12-2013, 03:18 PM   #9435
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,618
Kills it = Power Off
Talking about a Nuvi ....
YouTube feed
Times are GMT -7.   It's 01:23 AM.
