Thread Tools Search this Thread Rating: Thread Rating: 348 votes, 4.92 average. Display Modes
Old 11-15-2013, 08:29 PM   #9976
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,258
Just put a route, track and a bunch of new waypoints on my montana. Those are there but everything else is gone! First time that's ever happened. WTH?
Click Here!
2012 Triumph Tiger 800 XC
2008 Yamaha WR250R
1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-15-2013, 09:47 PM   #9977
Rocky TFS
Rocky TFS's Avatar
Oddometer: 564
Look at #9979 and later replies.....could be the same thing.
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 11-16-2013, 04:17 AM   #9978
Windrock
Windrock's Avatar
Oddometer: 21
Not a newbie but have a question pertaining to tracks.
I was given some tracks that had to be edited. I loaded them into Internal Memory on the 600. I can see them in Track Manager and have selected Show On Map for each Track. But they do not show up. I can go into Track Manager and select a Track then View Map and they show. But not during regular navigation. I have noticed that these particular tracks are missing the Elevation Data and a few other pieces. Does that make a difference not having the Elevation Data?
Also without going back thru this thread, has Garmin ever changed Basecamp to allow you to select multiple tracks and set the track to SHOW ON MAP before loading it to 600.
Trail Maintenance Supevisor - Windrock Park Trails
Oliver Springs, Tn
Trail Machine: 2013 Polaris RzR 570 LE
Windrock is offline   Reply With Quote
Old 11-16-2013, 08:47 AM   #9979
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,648
First, loading data you don't know the validity of on the GPS without looking at it in BaseCamp first is always suspect as far as I'm concerned.
But, if you can see the Track in preview mode (View on Map) then the only reason it will not show on the map when you are using the map (not sure what you mean when you say "navigating") is because you have exceeded the 10,000 total points limit prior to showing the last track.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 11-16-2013, 11:34 AM   #9980
Countdown
Oddometer: 5,471
Kind of obvious question but how close are you to the tracks and did you zoom out far enouigh to see them?
When you "View", the map jumps to where they are to prieview them. With "Show", you must find them.
Jerry Counts
Countdown is offline   Reply With Quote
Old 11-16-2013, 06:58 PM   #9981
Windrock
Windrock's Avatar
Oddometer: 21
I did load them in Base Camp first. I had to edit some of the tracks first before sending them to the Montana. I will go check the 10,000 point limit first. Thanks
Oliver Springs, Tn
Old 11-17-2013, 02:37 PM   #9982
BergDonk
BergDonk's Avatar
Oddometer: 3,479
My Montana keeps working great, but I do have a fallback for the cage:
I have a little GPS
I've had it most all my life
It's better than the normal ones
My GPS is my wife
It gives me full instructions
Especially how to drive
"It's sixty k's an hour", it says
"You're doing sixty five"
It tells me when to stop and start
And when to use the brake
And tells me that it's never ever
Safe to overtake
It tells me when a light is red
And when it goes to green
It seems to know instinctively
Just when to intervene
It lists the vehicles just in front
And all those to the rear
And taking this into account
It specifies my gear.
I'm sure no other driver
Has so helpful a device
For when we leave and lock the car
It still gives its advice.
It fills me up with counselling
Each journey's pretty fraught
So why don't I exchange it
And get a quieter sort?
Ah well, you see, it cleans the house,
Makes sure I'm properly fed,
It washes all my shirts and things
And - lets me have a shed.
Despite all these advantages
And my tendency to scoff,
I do wish that once in a while
I could turn the damned thing off.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 11-17-2013, 06:45 PM   #9983
Bob
Formerly H20Pumper
Bob's Avatar
Oddometer: 2,598
My GPS is my wife
Will it/she route you to the Mall
Bob is offline   Reply With Quote
Old 11-18-2013, 08:27 AM   #9984
CaseyB
Adventually
CaseyB's Avatar
Oddometer: 524
If I have an active track on my screen
How do I get the line of what I have previously ridden to show on top of the active track?
I know this has been discussed in a previous post. My google skills are currently lacking, I can't seem to find it.
CaseyB is offline   Reply With Quote
Old 11-18-2013, 09:12 AM   #9985
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
You don't. The active track log is always displayed over all map data.
atlas cached is offline   Reply With Quote
Old 11-18-2013, 09:32 AM   #9986
johnpitts01
johnpitts01's Avatar
Oddometer: 1,007
Cant get maps onto Montana
Anyone have any ideas how to fix this?
I am running the latest version of software on the Garmin.
Basecamp is up to date.
I recently exchanged my Montana due to a defect with the USB port.
With the new unit I cannot get my lifetime CN maps and Topo 100k maps on the unit.
I've spent more than 2 hours on the phone with Garmin support and @ 8 hours loading maps to the unit via various methids includling Garmin Express, Map Install, etc.
When I view my sd card using explorer the maps show up.
But on the unit the CN maps do not show up on the Map Enable screen.
The only way I have been able to get the maps on the unit is by using Mapsource to build a route and "Select Maps". I can then choose the appropriate CN maps and / or Topo maps and send them to the unit.
While this is a decent work around it just ain't right.
I want the entire CN mapset resident on the unit and the entire country Topo 100k maps resident on the unit. As they were with my orginal Montana.
If its already been posted to the thread please point me to the appropriate posts.
Also - how do I backup and restore my profiles?
I think I should do a hard reset on the unit and start all over again.
But I have lots of custom profiles that I do not want to rebuild.
Thanks in advance
John
johnpitts01 is offline   Reply With Quote
Old 11-18-2013, 09:36 AM   #9987
atlas cached
OX Ambassador
Oddometer: 688
Thanks in advance
John
What is your source for the 100k Topo maps? If You are loading the 100k Topo from BaseCamp/MapSource, you will exceed the 4000 tile limit of the device, and nothing more will be available on the Montana map selection screen.
Old 11-18-2013, 10:43 AM   #9988
BobM
DualSport
Oddometer: 326
... The only way I have been able to get the maps on the unit is by using Mapsource to build a route and "Select Maps". I can then choose the appropriate CN maps and / or Topo maps and send them to the unit.
I gave up on BaseCamp a long time ago and I use Mapsource for all my map, route, track, and waypoint transfers.
I build a mapset using Mapsource Map Selection Tool and note the size and number of segments in the Map tab. Stay below 4 GB and 4000 segments. Transfer to Montana (in the USB mode). Access the \Garmin folder on the GPS and rename the file from gmapsupp.img to CNNA.img or whatever describes the maps. Repeat for each mapset.
For routes, tracks, etc use Mapsource and transfer each data type separately to the Montana and then access the \Garmin\GPX folder and rename the userdata.gpx file to Route01.gpx, or Track01. gpx etc making sure each transferred file gets a unique name/number. You need to be familiar with data restrictions, like 50 points max in a "Follow Roads" route, 'unlimited' points in a Direct or Off Road route (I don't know what the limit is - I've tested up to 5000 points and they work OK), number of Characters in a waypoint name (14 I think), etc to make sure everything works.
The only difference I find between transferring data with Basecamp and Mapsource is that Mapsource always uses the same file name while Basecamp creates unique names, so Mapsource will overwrite the previous file transfer.
It works for me, YMMV.
Bob
BobM is offline   Reply With Quote
Old 11-18-2013, 11:37 AM   #9989
MasterMarine
Oddometer: 1,566
Bob
When I have transfered Direct Routes from Base Camp to my Montana, they could only have 250 points. Any more past that would be missing in the Montana.
Are you sure about "unlimited" points transfering from MapSource to a Montana for a Direct Route?
MasterMarine is offline   Reply With Quote
Old 11-18-2013, 11:40 AM   #9990
johnpitts01
Oddometer: 1,007
CN and Topo
OK, I can live with only loading the local Topo maps needed for any particular ride.
But I believe I should be able to load the entire CN maps to the device itself or the Sd card. Pretty sure that's what I had on the original unit.
I certainly dont recall having to select the individual CN maps and send them to the Montana.
In fact the first thing I did when I bought the original Montana was install CN.
My gut tells me that I need to do a hard reset on the current unit, install the CN maps before anything else and I will be good to go.
Times are GMT -7.   It's 04:06 AM.
