10-09-2011, 07:31 PM
#1021 | |||
Oddometer: 227
You guys should send an email to montanabeta@garmin.com explaining what happened, include your x:\garmin\system.xml and the file corresponding to the profile you were using x:\Garmin\Profiles\whatever.gpf as attachments. The system.xml file logs crashes and includes some register values that might help them duplicate the problem.
QUOTE=spyderryder;17036822]
10-09-2011, 07:41 PM
#1022 | |
Procrastinators
Oddometer: 5,779
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
10-09-2011, 08:42 PM
#1023 | |
Long Haul Adventurer
Oddometer: 3,170
Not sure what you can do but call product support. Cheers,
Cheers, Dan |
10-09-2011, 09:29 PM
#1024 |
Oddometer: 3,170
Made a great discovery this weekend.
I was going to the Shelton Valley Adventure & Dual Sport Ride and wanted to see if there was any way to reset the Trip Odometer with one touch. The ride is a Roll Chart only affair but I used the trip odo on the Montana cause it measures hundredths of a mile. But I couldn't afford to have to make five button presses just to do a reset - which happened frequently on this really great off-road event. Turns out that the Montana team enabled a "one touch reset" shortcut. Although I still had to leave the Map page I only had to press the Reset Shortcut and then back to the map. Only thing that would be better would be to have a Trip Odometer "Large Datafield" dashboard that had a one-touch reset button in the dashboard. Cheers, It just occurred to me on my ride back over the mountains today that there is a one touch solutions to the Trip Odometer Reset. The Programmable Power ON/OFF button! I now have my Power button set to Reset Trip Odometer with one press. I show the Status display with two presses.
Cheers, Dan DRTBYK screwed with this post 10-10-2011 at 02:17 PM Reason: The light bulb just went on upstairs!!! |
10-10-2011, 07:23 AM
#1025 | |
Oddometer: 29
spyderryder screwed with this post 10-10-2011 at 08:14 AM |
10-10-2011, 12:23 PM
#1026 | |
Aged Adventurer
Oddometer: 1,110
I have heard of cases when both Topo and CityNav are installed on a GPS and routes "appear" to auto-route in Topo but it is actually CityNav generating the route. I have an older set of Topo for Canada on 3 or 4 CDs that will auto-route, but it is bizarre, to say the least. Curious.
Phil in Seattle, WA |
10-10-2011, 12:38 PM
#1027 |
REMF
Oddometer: 8,546
I only have the ancient 3-CD 100K topo, but have always heard that the 24k regional topo would autoroute
Mike S. '09 Bonneville Black AMA MSTA STOC http://autos.groups.yahoo.com/group/...orcycleriders/ |
10-10-2011, 12:43 PM
#1028 | |
Aged Adventurer
Oddometer: 1,110
"These highly detailed maps on DVD include terrain contours, topo elevations, summits, routable roads and trails, parks, coastlines, rivers, lakes and geographical points."
10-10-2011, 01:02 PM
#1029 |
Oddometer: 264
Just bought a new Montana and was wondering what is the latest firmware that I should have installed? So far love the item along with the City Navigator DVD. I have the PNW topo maps but don't like it as much. Too much clutter on the screen.
10-10-2011, 02:01 PM
#1030 | |
Oddometer: 3,170
So, no single track can be more than 10,000 points or it get's truncated. You can have 200 x 10,000 points showing on the map based on Garmin's numbers. I haven't tried it - what's the point? ![]() Cheers,
Cheers, Dan DRTBYK screwed with this post 10-10-2011 at 02:54 PM Reason: Trying to be more clear. . . |
10-10-2011, 02:10 PM
#1031 | |
Oddometer: 3,170
My 100K Topo is routable in BaseCamp. I personally don't use Topo's at all, just bought them to better understand what was going on. I have since given away the DVD's for my 100k Topo and half of my 24K topo's. If the Montana would have supported turning off the contour lines I might have kept them. Cheers,
Cheers, Dan |
10-10-2011, 02:13 PM
#1032 | |
Oddometer: 3,170
Cheers,
Cheers, Dan |
10-10-2011, 09:23 PM
#1033 | |
Oddometer: 29
10-10-2011, 09:41 PM
#1034 |
Dubbious Adventurer
Oddometer: 4,691
How do the routing algorithms work?
So there are some variables
It looks like we can adjust the settings in Basecamp, but not on the Montana. Things like how the calculation works on auto vs moto are a little mysterious. If avoidances are the same, the shortest route calculation should be the same in all activity modes. Is this really true? If we don't alter the defaults in Basecamp, will the route match on the Montana if the activity is the same? BTW, on my recent trip, I got some whacky discrepancies between TTD and DTD. At one point the unit said I had two hours to go with only a mile or so remaining on the route. Bad information was very common. 276 was always spot on. Not this baby. Also, I found that DTN was very slow to pick up an accurate reading to the next turn. When the turns come close together, this becomes an issue. There were also multiple shutdowns. Once the unit did a full on reset without being prompted. Went straight to the language prompt and dump all settings. Not nice. I have my track archive set to daily and it dumped my previous day's ride since the archive is created when the unit first boots. Still pleased with the Montana screen and features, but not the bugs!
MINIMOUNT |
10-10-2011, 11:00 PM
#1035 |
Oddometer: 264
Avoidance Set up icons
Question: In avoidance set up if the green check mark is showing does this mean that the system will avoid this or seek it. Kind of confusing.
Thanks |
