Thread Tools Search this Thread Rating: Thread Rating: 296 votes, 4.91 average. Display Modes
Old 03-13-2014, 11:35 AM   #10546
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
Originally Posted by Ridin'nFishin View Post
I just bought a 600 and need to put CN on it. Do I install it in Base Camp then to the Montana?
Well, it depends.
What type of computer are you using?
Do you want CN on a DVD, or do you want it pre-installed on a MicroSD card?
Do you want to be able to update CN?
Old 03-13-2014, 04:05 PM   #10547
Ridin'nFishin
Oddometer: 460
I have a DVD in hand.
I do want to update CN to LM later.
I have a pc.
Riding a Motorcycle is like flying like a Eagle without ever leaving the ground.
Ridin'nFishin is offline   Reply With Quote
Old 03-13-2014, 04:08 PM   #10548
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
I have a pc.
Put the dvd into your drive and let it install on the computer, then use MapInstall to put the maps on your Montana.
Sent using strings and tin cans and Tapatalk.
Old 03-14-2014, 05:06 PM   #10549
ShaneBaby
Oddometer: 140
ARRRGGGGGhh!!!!!!
All night I have tried to do this!! Is it possible please Mr Guru
I want to make a line (route/track?) on Google maps
then export it to my 650T and be able follow it
cant be that hard surely????
I dont need google earth because I cant even figure how to make the line(route/track?) I want on that #@$%^ program
So the only way I can make a KML on the new google maps is to make a custom map and then export to KML is this right?
It seems to me i have done this successfully and I have the KML on my computer
Now I think I need to make a gpx from this for my garmin to read it?
so I installed gpsbabel and open that drop that KML file in the input box
and what ever output I select it appears it wont read the KML I dropped in??
I get this:
gpsbabel -w -r -t -i kml,lines=1,points=1,floating=0,extrude=0,track=0, trackdata=1,trackdirection=0,labels=1 -f /C:/Users/ShanePC/Downloads/Directions from Currimundi, Queensland to Donohue Highway, Amaroo, Queensland.kml -o gpx,suppresswhite=0,logpoint=0,humminbirdextension s=0,garminextensions=0 -F C:/Program Files (x86)/GPSBabel/Alice.gpx
XML Reader: Cannot open file '/C:/Users/ShanePC/Downloads/Directions from Currimundi, Queensland to Donohue Highway, Amaroo, Queensland.kml'!
Error running gpsbabel: Process exited unsucessfully with code 1
The line I want to follow on Google maps only has 6 points. So I could put each of them on my device as a way point and "where to" to each point as I go but is this using my device correctly?
Thanks guys my eyes are falling into my coffee Ive been up most of the night and tried lots of things none the right way
ShaneBaby is offline   Reply With Quote
Old 03-14-2014, 05:12 PM   #10550
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,464
The easy way is to use this G-Maps online application.
But, since you think you have a good KML Track, you could just import the KML file into BaseCamp and then transfer the Track to your Montana.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 03-14-2014, 05:14 PM   #10551
ShaneBaby
Oddometer: 140
This is the line(track/route?) I want to follow on my bike
https://mapsengine.google.com/map/ed...w.kyo-wukjB_do
Old 03-14-2014, 05:16 PM   #10552
ShaneBaby
Oddometer: 140
Hmmn Ill try both now Thanks mate I THINK I have a good KML indeed
Old 03-14-2014, 05:21 PM   #10553
DRTBYK
DRTBYK's Avatar
Oddometer: 5,464
Should look like this after import your KML file into BaseCamp...
Or this on Shonky Topo w/o Contour Lines...
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 03-14-2014 at 05:30 PM
Old 03-14-2014, 05:22 PM   #10554
ShaneBaby
Oddometer: 140
I have just connected my device and opened Basecamp
I go to file and the import option is not available how do I import the kml file?
Old 03-14-2014, 05:25 PM   #10555
DRTBYK
DRTBYK's Avatar
Oddometer: 5,464
Not sure why you don't see the Import option...
What version of BaseCamp are you running?
Cheers,
Dan
All Things GPS
Old 03-14-2014, 05:25 PM   #10556
ShaneBaby
Oddometer: 140
WOW!! my basecamp looks nothing like that!!!! its postively bare compared to yours I have city nav and NZ/AUs topo maps in there but nothing like that WOW I feel dumb
Old 03-14-2014, 05:27 PM   #10557
DRTBYK
DRTBYK's Avatar
Oddometer: 5,464
No worries just a different map. That was OSM Australia. But, let's focus on why you aren't seeing the Import option...
Cheers,
Dan
All Things GPS
Old 03-14-2014, 05:30 PM   #10558
ShaneBaby
Oddometer: 140
Thanks I have looking for what version and cant find that! basecamp.ink?
windows 8 and I installed base camp a couple of months ago and hope it updates auotmatically
Old 03-14-2014, 05:31 PM   #10559
ShaneBaby
Oddometer: 140
The export option is there but not import
Old 03-14-2014, 05:34 PM   #10560
DRTBYK
DRTBYK's Avatar
Oddometer: 5,464
BaseCamp --> Help --> About Garmin BaseCamp
Try just opening the folder where you have the KML file and drag/drop it into a List or Folder in BC.
Cheers,
Dan
All Things GPS
Times are GMT -7.   It's 01:36 AM.
