05-21-2011, 08:47 PM
#16 | |
Oddometer: 260
The Extinguished gentleman. Do or do not. There is no try. Yoda |
05-21-2011, 08:50 PM
#17 |
Scott Whitney
Oddometer: 2,225
Nice wheel!
Go get'em Neptune! |
05-21-2011, 09:52 PM
#18 |
Oddometer: 687
Awesome!
Following for sure. Would like to build a sidecar'd rig one day for my dad whos in a wheelchair.
Matt - SikMoto www.Facebook.com/SikMoto San Luis Obispo, CA |
05-21-2011, 11:46 PM
#19 |
ONE HACK AT A TIME
Thanks for that Neptune looking at doing something simiular on my hack build.
01 HONDA VFR800 13 HUSQVARNA WR125 |
05-22-2011, 04:09 AM
#20 |
Oddometer: 70
Yamaha FZ1 dual sport sidecar build
![]() The calipers are mounted so they are floating. The bearing is clamped by a split collar that I welded a small bracket to. Then I cut out the larger bracket that the caliper bolts onto. You can see the three bolts that attach it to the split collar and its bracket. The brackets were cut out of 1/4" metal plate using a hand held angle grinder. The tolerances between the wheel and caliper are very close and the two sides had to be identical. I wish there was a way to have kept track of all the hours I spent grinding metal. ![]() ![]() ![]() If you look closely you can see how the width of the front tire was accommodated. I machined a short section of tube at both ends that then fit into the upper and lower triple clamps. The actual down tubes were temporarily held in place to the short tube in the triple clamps with two split collars welded together. The down tubes are forward and rotated outwards from the tubes in the triple clamp to achieve the needed width. ![]() The down tubes are double wall. I slid one tube inside the other before bending them to meet the swing arm's mounting brackets / pivot point. I have seen pictures of leading link forks broken below the triple clamp so the double wall should hopefully eliminate that.
05-22-2011, 07:19 AM
#21 |
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,968
05-22-2011, 10:14 AM
#22 |
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 370
I do like your fabrication skills, outstanding!
The front swingarm double walled and fitted up with machined ends is real clean. Good thoughts there, lots of contemplation I'm sure. Fitting the hub/spokes to a new rim..... that takes skill and some nice equipment. Super welder you got there. Still anxious to see the final product. ![]() Come on.. just one shot from the rear, consider it a teaser. Don in Nipomo |
05-22-2011, 11:06 AM
#23 |
The Examiner
as was already mentioned above.... THIS picture:
![]() MUST be on the front page of some magazine i'm really not sure which one but... you've really touched a lot of folks with this one thanks for posting it in fact, i've spiced that picture up a bit, too hope you don't mind me posting it (i'll remove it, if you do)
Greg '07 K1200 GT '11 R1200 GS Adventure with a DMC M72DX Sidecar live life like you mean it... but take your family and friends (and DOGS) along for the "ride" |
05-22-2011, 09:52 PM
#24 | |
Oddometer: 70
Response to D. Bachtel's request
05-23-2011, 06:28 AM
#25 |
Oddometer: 70
![]() Thought I should mention, in the previous pictures of the front end, it looks like I used rod end ball joints at the bottom of the leading link down tubes (the pivot point of the swingarm). That would have been an easy choice but Bill suggested that if rod end ball joints were used they would allow movement that was not desired, especially as they became worn. Because I wanted the ability to adjust the pivot point vertically I started with a 3/4" rod end but removed the ball and welded in some parts I machined so I could insert nylon bushings and a brass sleeve (the brass sleeve that goes into the bushings is not shown in the picture). I should have taken an after picture, but I hope you get the idea. ![]() ![]() Only caught myself on fire once while welding because I got smart and picked up a cheap long sleeve welding jacket. ![]() ![]() I picked up a VFR single sided swingarm on EBay for a reasonable price. In one easy step I had, a nice looking strong swingarm, shock, brake rotor and caliper. The 15 x 5.5 car wheel was purchased from Wheels Next and to provide clearance for the wheel and 175/70/15 rally tire I found an aluminum spacer online that only needed minor modification to mount to the four bolt pattern of the VFR swingarm. |
05-23-2011, 08:58 AM
#26 |
Oddometer: 370
05-24-2011, 07:17 AM
#27 |
Oddometer: 70
05-24-2011, 07:28 AM
#28 |
Scott Whitney
Oddometer: 2,225
WOW, very nice!
05-24-2011, 07:45 AM
#29 |
The Examiner
Wow from ME, too
05-24-2011, 08:40 AM
#30 |
Paint it black.
Oddometer: 12,863
Super nice work!!
