Old 07-06-2011, 12:38 PM   #46
RideDualSport.com OP
TPB all the way
RideDualSport.com's Avatar
Oddometer: 1,596
Tbone, thanks for the cool photos! The FZ 750 was a super bike, I remember how the magazines raved about it.
These mid-1980s bikes are interesting, they show the trend in 16" front wheels, water cooling, multiple valves per cylinder and cool body work and graphics of the day.
To me, its not a thread high-jack when people post good content that is related to the topic, like yours is.
And even if stuff is not related, its just the internet...
"... I lock my rear up at least once every time I throw a leg over a bike."
The RideDualSport Forum
Mountain State Super Tenere Adventure
Alaska Deep Adventure
RideDualSport.com is offline   Reply With Quote
Old 07-09-2011, 12:38 PM   #47
TPB all the way
Oddometer: 1,596
I am fitting the body work to the bike, this is a trial fit to get the fasteners sorted out and make any adjustments to the mounting brackets.
It will come off again for some crack repairs, then a final mounting to the bike.
We will also be painting the upper fairing to match the rest of the bike.
It is rather lean and sporty looking, if I do say so myself!
RideDualSport.com screwed with this post 07-09-2011 at 12:49 PM
Old 07-09-2011, 03:11 PM   #48
vernon dent
vernon dent's Avatar
Oddometer: 702
that bike is pure bad ass. of course i'm fond of p.m. chicanes too.
I only ride 'em. I don't know what makes 'em work.
Oddball
vernon dent is offline   Reply With Quote
Old 07-09-2011, 06:28 PM   #49
TPB all the way
Oddometer: 1,596
Wicked
Most excellent indeed, axis! That is a very clean and sane-o looking GS 1000 (something tells me there may be a big bore kit in there?). Man it is great to see so much motor, and a round headlight! Your bike puts the "motor" in motorcycle for sure! Exciting! Thanks dude!
Old 07-10-2011, 06:37 PM   #50
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,322
Man what a sweet GS! I miss my 83' 1100ES.
Tbone is offline   Reply With Quote
Old 07-11-2011, 06:25 AM   #51
TPB all the way
Oddometer: 1,596
Tbone, its cool to see our old photos, brings back some memories for sure! It is interesting how, having the latest bike in the 1980's was every bit as exciting as getting new bike now. Sure the 1980s bikes suspension and frames were behind the curve compared to the motors, and sometimes the handling was rather scary, like the 16 inch front wheels, but we still raced the bikes and rode them to the limit!
I like the big seats and tail sections, todays more sporting bikes have rather extremes styling, which does not make them as practical for luggage and a passenger.
We have been doing some noodling on the web about Brent Adams, who owned Quadracycle in Austin. My brother worked for him, and he built the motor for the 900 Ninja. Brent built a lot of air cooled drag and custom bikes back in the day and knows his stuff. Several of his old bikes are still lurking around. Here is one of his old Hondas, found on a forum, where people are wondering about him!
This bike was on a Honda SOHC Air Cooled site, I think the owner rescued it from his older brother that had it setting in a barn for a long time. Brent Adams built the motor in about 1984, and the guy that lived in Austin moved to Michigan. The current owner got it in Michigan and is putting new life into it.
RideDualSport.com screwed with this post 07-11-2011 at 06:36 AM
Old 07-13-2011, 06:58 PM   #52
TPB all the way
Oddometer: 1,596
We used this plastic repair product called Plastex, and despite the rather dubious packaging, it worked really good to fix the various cracks in the lower fairing and belly pan. Much better than JB Weld and the repair is instant.
It uses fine plastic beads and a solvent to weld cracks, fill holes and even comes with a mold for replicating parts.
I used a jig saw and file to cut out the relief in the belly pan to clear the header pipe, mounted the radiator and oil cooler.
I installed the rather hard-to-find plastic filler pieces that dress up the gap between the fairing and motor.
After some fiddling about I got the bars installed. Good thing we had two pairs on hand, as one bar was bent.
The Telefix fork brace that my brother purchased in the 1980's fit very well.
I am on to getting the electrics sorted out, I got the turn signals, tail light, brake light and starter motor working.
Old 07-13-2011, 10:13 PM   #53
mike-s
2 squeaky wheels
Oddometer: 609
I cannot endorse plastex strongly enough. As long as the prep work is solid and the plastic you are repairing compatible, the repair will be solid as a rock.
I.e. i've used it to fix the security remote for my car when i first bought that car second hand when the remote was about to fall into peices. The remote went on to survive daily (ab)use for a further 5 years before i had to touch up a crack in the plastic that i had only done a half arsed repair on in the first place.
The bikes looking pretty damned good there.
mike-s is offline   Reply With Quote
Old 07-16-2011, 01:45 PM   #54
TPB all the way
Oddometer: 1,596
Ok, so I cleaned the Mikuni RS Series Radial Flat Slide and installed new pilot jets, main jets and cleaned the float needles. I also put coolant in the bike, cranked the motor over and checked for spark and installed new plugs.
The Mikuni RS Series Carburetors were designed and built in response to the needs of the world's top motorcycle road race and drag race teams. They required carburetors which would satisfy the precise fuel metering demands and high flow volume required by highly modified race engines. And yet, also provide the smooth, controllable throttle response that is needed by any rider pushing his motorcycle to its limits on the race track and under high performance use.
The carburetors need to meter fuel correctly under a wide range of atmospheric conditions and engine tuning modifications while being easily accessible for trackside tuning changes which need to be made quickly.
Designed for in-line four cylinder performance motorcycle applications, the Mikuni RS Series Radial Flat Slide Carburetors offer superior horsepower gains with their maximum flowing smoothbore induction tract and radial flat slide design. An adjustable accelerator pump system helps to provide instant throttle response, particularly in the lower RPM range.
The RS series Carburetors feature a compact design which is 25% lighter than other performance carburetors, offers quick needle jet adjustment, and uses readily available standard Mikuni jets.
Old 07-16-2011, 04:12 PM   #55
pacman1
pacman1's Avatar
Oddometer: 1,141
Beautiful Kawi 900. Been drooling over a VR1000R for years. This thread makes me want one even more.
_______________________
Wayne
Honda Blackbird
Burleson, Texas
pacman1 is offline   Reply With Quote
Old 07-17-2011, 06:16 AM   #56
Fubars
What would Scoobydo?
Fubars's Avatar
Oddometer: 1,776
Mmmmmmm----Mikunis......
Fubars is offline   Reply With Quote
Old 07-17-2011, 12:41 PM   #57
TPB all the way
Oddometer: 1,596
Thanks Pacman, it is a very rewarding project. I am getting excited, it should be running in a couple of weeks.
And a new Corbin Gunfighter is on order.
Old 07-21-2011, 04:35 PM   #58
TPB all the way
Oddometer: 1,596
The new Corbin gunfighter came in today! In leather too!
RideDualSport.com screwed with this post 07-22-2011 at 09:38 AM
Old 07-22-2011, 09:26 AM   #59
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,322
Oh man...looking at the close up photo's brings back memories of working on mine. I liked the Corbin on my 900's...just looks right.
I also enjoyed my 85 FJ1100...awesome motor
Old 07-22-2011, 09:38 AM   #60
TPB all the way
Oddometer: 1,596
True Tbone, the corbin solo seat looks far better than the corbin gunfighter Lady that was on it. My brother in-law got into motorcycling with us and bought a new FJ 1100 back in the 80's. His best friend got one too. They had some really great rides on it, and he still talks fondly of it these days.
Thanks for the cool photos. I hope to fire up the GPZ 900, (actually 985cc due to the big-bore kit) in a week or so!
Cheers!
Times are GMT -7.   It's 04:53 PM.
