Old 08-29-2011, 08:49 AM   #211
craftycoder OP
Motobrain PDU
craftycoder's Avatar
Oddometer: 2,308
Originally Posted by chrisspy View Post
if it's light & you have enuf surface area, might velcro work?
That's an interesting idea. I wonder if there is a harsh environment version of hook and loop? We definitely do not want metal box with a cable coming out the side swinging off your bars and into the front wheel, but if cable is wip tied down so there is little or no slack the odds of it going anywhere seem slim.
craftycoder is offline   Reply With Quote
Old 08-29-2011, 08:54 AM   #212
BENRON
I'm Mr. Crabtree
BENRON's Avatar
Oddometer: 3,609
Google "3M Dual Lock"
BENRON is offline   Reply With Quote
Old 08-29-2011, 09:19 AM   #213
CoDawg
HP c.180
CoDawg's Avatar
Oddometer: 13
Wow, the remote is looking great!
The connector you see is this.
I've done a ton of seaching for miniature connectors of this type for my own project. Are you sure you can get that particular connector from Binder? They show a stock of 0. I ordered some similar connectors from them, and ran their stock from 3 down to 0. They have not replaced that stock in the 6 months that have past. Maybe you already have, but you might check if you can actually get that connector without some crazy minimum order of 1000 units.
It seems you need a 6 pin connector (two for power in, two for power out, and two for USB data). The power grounds could be shared, getting you down to only 5 pins. Binder makes a nice 6-pin M8 IP67 connector that I've used, but it's down to 0 stock. Some other possible sources for similar miniature connectors:
http://www.turck-usa.com/Products/Connectivity/
http://www.newark.com/jsp/search/pro...-OP&CMP=AFC-OP
http://www.finecables.com/en/Product...id=251&Bid=306
http://www.mouser.com/catalog/catalogUSD/641/1295.pdf
http://www.phoenixcontact.com/indust...7844_52624.htm
CoDawg is offline   Reply With Quote
Old 08-29-2011, 09:23 AM   #214
craftycoder OP
Motobrain PDU
Oddometer: 2,308
Theoretically, I only need 4 connectors because the 5VDC and the ground can be shared. I have not sourced the connectors yet but I will. Thats funny that they are out of stock because I swear they had stock the other day. Arg.. I can find something no doubt.
Old 08-29-2011, 09:39 AM   #215
CoDawg
HP c.180
CoDawg's Avatar
Oddometer: 13
If you get down to 4 pins, then you can't beat this:
http://www.mouser.com/ProductDetail/...4LdmGYLQ%3d%3d
And this:
http://www.mouser.com/ProductDetail/...bQB7Xh6w%3d%3d
or the right-angle version (picture doesn't show it correctly):
http://www.mouser.com/ProductDetail/...0VPCUz0Q%3d%3d
Old 08-29-2011, 09:40 AM   #216
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,311
And this:
we used mouser for all our parts. Forgot about them. Almost always in stock with good pricing and shipping.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 08-29-2011, 09:48 AM   #217
craftycoder OP
Motobrain PDU
Oddometer: 2,308
I like this because its very low profile on the inside. It is in stock with 4 and 5 conductors.
Could a generic mount that just presents a small flat surface to Dual Grip to be fashioned then? We can all figure out how to clamp something to our bars. Something like this perhaps (not to scale).
I forgot to post this yesterday I think. This is the back plate with the electronics. Those screw holes are for hooking some kind of rubber band or fine cable to hold the electronics fast.
Old 08-29-2011, 12:54 PM   #218
Cromoth
Inspection due 5_31
Cromoth's Avatar
Oddometer: 571
velcro extreme
zip tie the cable & http://www.velcro.com/index.php?page...backed-extreme
Can you make the volume go to 11? Well it was funny in Spinal Tap...
"Four wheels move the body,
Two wheels move the soul." http://ridingacross.com/
Three move you & the dog!
Cromoth is offline   Reply With Quote
Old 08-29-2011, 01:39 PM   #219
CoDawg
HP c.180
CoDawg's Avatar
Oddometer: 13
Maybe something low cost that exists already can be adapted?
Super universal, super cheap, quick release, 0.6" wide. Just replace cylindrical piece with your remote. $1.22 ea qty 10+, no tax, free shipping (slow delivery):
http://www.dealextreme.com/p/univers...diameter-44318
Aluminum, $5.39 ea qty 10+:
http://www.dealextreme.com/p/bicycle...ra-black-69116
Speaking of velcro, $1.69 ea qty 10:
http://www.dealextreme.com/p/univers...diameter-31871
Others, search "bicycle mount":
Old 08-29-2011, 04:02 PM   #220
abhibeckert
abhibeckert's Avatar
Oddometer: 1,683
What about just a hose clamp?
abhibeckert is offline   Reply With Quote
Old 08-29-2011, 04:04 PM   #221
craftycoder OP
Motobrain PDU
Oddometer: 2,308
You still need a surface for the velcro. If you can do that with a hose clamp, then you are good to go.
Old 08-29-2011, 04:22 PM   #222
CoDawg
HP c.180
CoDawg's Avatar
Oddometer: 13
Just add a bend to this bracket and make the surface that mates with the remote wider, then the hose clap method works, with velcro or a mounting screw. One benifit to this hose clamp bracket and some of those I posted above is that they work with 7/8" bars, or somewhat down on the larger diameter of tapered bars.
Old 08-30-2011, 08:07 AM   #223
Tijuana_Taxi
Oddometer: 326
I went ahead and modeled the whole thing. Everything should fit nicely now. Now I just need a machine shop who can build it. Anyone?
These guys are right down the street from my house and I've heard good things about them locally. The also have a "Request A Quote" area on their website. Hope this helps.
http://www.envirotechind.com/Index.aspx
Tijuana_Taxi is offline   Reply With Quote
Old 08-30-2011, 03:14 PM   #224
craftycoder OP
Motobrain PDU
Oddometer: 2,308
Mount idea.
Based on the conversation we had the last few days, this is what I've come up with. Hose clamp the mount to the bar. Zip time the cables to the bar. Uber-Velcro the remote to mount. There is lots of surface area there. It should be good to go. The final image has a golf ball and iphone for scale. The app does not work with iPhones, it is Android only. It just happens to be something that I think most people have seen.
craftycoder screwed with this post 08-30-2011 at 05:22 PM
Old 08-30-2011, 08:47 PM   #225
trailNtent
trailNtent's Avatar
Oddometer: 179
Unticking the maps on the search menu?
Great app! I've looked through the settings and couldn't find anything that will allow me to default the maps in the search menu to be "unticked". Whenever I search in my area i get a bunch of maps (awesome)! But I have to untick every single one of them and them tick them one by one to to figure out what's what. Is there an option that I've missed to set the search results to default in the unticked state?
thanks
trailNtent is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
