Old 06-06-2011, 10:40 PM   #1
ProblemChild OP
ProblemChild's Avatar
Oddometer: 106
Brake rotors for 2007 990 w/ ABS
One of my front rotors is slightly warped. Not a huge deal at the moment but I will eventually be looking for a replacement option besides the OEM for an '07 990 Adventure (ABS). Ran across this post and wondered. Anyone know of what options are available?
Originally Posted by Salzig View Post
I fitted new brake rotors to my off-road front wheel (and new brake pads too)
2007 KTM 990 Adventure
1970 Norton Commando 'S'
ProblemChild is offline   Reply With Quote
Old 06-07-2011, 03:40 PM   #2
75monza
75monza's Avatar
Oddometer: 354
I know that you can use Galfer's or Braking's:
http://www.ktmtwins.com/ktm-950-990-...ont-wave-rotor
Your picture looks like the Braking ones.
2006 KTM 950 Adventure - Go Everywhere Bike
1993 Suzuki GSX1100G - Street Touring Shafty
2000 Suzuki DR200 - A Little Smaller
75monza is offline   Reply With Quote
Old 06-07-2011, 04:23 PM   #3
ProblemChild OP
Oddometer: 106
Interesting. Now that you've made me look again as I had checked their site before, it appears the Galfers will not work as it specifically says "will not work with ABS bikes" at the bottom. The Braking ones say that too, BUT, offer a left and right and appear to be the ones in the photo. I wonder if that's a typo? Luckily, KTMtwins is down the street. Next time I pop by I'll ask them about that, too.
Old 06-08-2011, 12:09 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,176
Keep us posted pls.
Cheers.
Old 12-30-2011, 08:16 AM   #5
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
Any word on this? I'd love to have Galfer brakes, but I have the ABS...
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 12-30-2011, 11:47 AM   #6
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,731
I recon Salzig has it sorted
Peanuts is offline   Reply With Quote
Old 12-30-2011, 12:08 PM   #7
WelshLAMB
border raider
WelshLAMB's Avatar
Location: monmouth, hereford and the roads between (UK)
Oddometer: 73
change one thing......
Just don't forget to still use the longer dic retaining bolts on the ABS ring side.
Happy trails!
Welshlamb
990Adv, little talent
WelshLAMB is offline   Reply With Quote
Old 12-30-2011, 01:41 PM   #8
Duckhams
Duckhams's Avatar
Oddometer: 74
Cry help
Any one have problems with floating Disc brakes from BRAKING.
Mine is rubbing on my calipers for the front. Any suggestiong or any one came accros the same problem for 950 ADV?
Duckhams is offline   Reply With Quote
Old 12-30-2011, 02:31 PM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,731
On the EXC I had to grind the caliper bracket a little so it cleared the bobbins on the Braking disc, might be same on the Adv?
Old 12-30-2011, 02:33 PM   #10
Peanuts
Peanuts's Avatar
Oddometer: 1,731
Happy trails!
Good point. Stock discs have a recess for the screw head, this needs to be considered when adapting Braking discs onto the Adv.
Old 12-31-2011, 01:47 PM   #11
Duckhams
Duckhams's Avatar
Oddometer: 74
Mine look like this with stock but with floating disc it get abit worst. What should I do????
Old 12-31-2011, 04:10 PM   #12
Peanuts
Peanuts's Avatar
Oddometer: 1,731
Looks like its only rubbing on one brake. Could you have a damaged wheel spacer on that side ending up with the wheel set too far one way?
Old 12-31-2011, 05:48 PM   #13
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,759
EBC is making one for the 950/990. They have also updated the rivets to square ones.
I went this route on the SE after having the rivets loosen up on four stock ones..
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is online now   Reply With Quote
Old 12-31-2011, 07:03 PM   #14
slowinfastout
Just Ridin' By....
slowinfastout's Avatar
Oddometer: 1,909
Right now only KTM factory rotors work with ABS, though you can use many other brands if you re willing to give up your ABS (sensor ring won't fit on aftermarket rotors)
slowinfastout is offline   Reply With Quote
Old 12-31-2011, 07:55 PM   #15
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,759
Incorrect sir, EBC has that issue sorted..
Take a closer look at that EBC rotor it is recessed for the ABS ring...
Times are GMT -7.   It's 11:23 PM.
