Old 01-26-2013, 04:18 AM   #601
ktmMike OP
Coordinator
ktmMike's Avatar
Oddometer: 1,099
Originally Posted by Kafn8td View Post
I just put one on my SMT and it has a sticker right on the filter that says to remap. Check out http://www.ktmsmt.com/viewtopic.php?f=13&t=3770
Kevxtx is the guru of modding the SMR/T.
Kevxtx
Thanx for that info kafn8td.
He has been on this thread a few times.
KTM MIKE . . . . . . . KTM EQUIPPED SINCE 1999
three 640's (sold), two 950's (sold),
530 EXC, 690 SMC, 990 SM-R
ktmMike is offline   Reply With Quote
Old 01-30-2013, 08:14 AM   #602
evanphoto
May G-d bless Evel
evanphoto's Avatar
Oddometer: 413
led lighting
i haven't found much on this thread about led tail and led for indicators. any recommendations?
"It’s a good feeling when they stand up and fight us. If 10 of them are gonna decide to stand up and fight us, I can tell you 10 of them are gonna die,"
Cpt. Schneider, US Army in Iraq, 2004
evanphoto is offline   Reply With Quote
Old 01-31-2013, 10:00 AM   #603
rellim_63
Oddometer: 38
Thanks for the exhaust info. Now the real question is the wings website says they design to run on the stock map. Also they say to do SAS removal and canister also. Is this really important to have them run right, or could i keep this stuff on? Ive only had the bike less than a year and dont really want to go tearing it apart yet.
rellim_63 is offline   Reply With Quote
Old 01-31-2013, 10:12 AM   #604
burgerking
echt bezopen
Oddometer: 402
I didn't change anything apart from the cans. But I use the insert with the smallest diameter, without them these things ehhh wings are just too loud.
Only did the 15 minute reset after installing, engine runs fine.
burgerking is offline   Reply With Quote
Old 02-01-2013, 12:10 AM   #605
ultrachrome
Poser
Oddometer: 225
You get what you pay for. Electrosport indicators wouldn't fully light up at idle speed. Replaced them with Rizomas which are nice and bright but probably not brighter than stock.
There's an LED tail light on ebay for the adventure. I've heard conflicting reports about whether it's an improvement over stock.
ultrachrome is offline   Reply With Quote
Old 02-02-2013, 04:48 AM   #606
ktmMike OP
Coordinator
ktmMike's Avatar
Oddometer: 1,099
Hey Ultrachrome, I've never tried LED's.
When you switch from stock taillights to LED's, are you just changing the bulbs, or are you changing the entire taillight unit???
Old 02-03-2013, 01:20 AM   #607
ultrachrome
Poser
Oddometer: 225
Usually the entire unit. You can find LED's with bayonet bases that will fit in the stock sockets but hard to know if they're any good.
I did a little research for an LED bulb replacement for the brake light but webbikeworld.com did a review of several and did not find one that was brighter than a stock bulb.
These are pretty trick but no KTM fitment. However, given the wide variety of bikes they cover with only two models, I wonder if it wouldn't fit ours.
Old 02-03-2013, 05:48 AM   #608
ktmMike OP
Coordinator
ktmMike's Avatar
Oddometer: 1,099
Good looking turnsignals, but it's the LED taillights and brakelights I'm curious about.
We aren't required to have turnsignals to pass inspection here.
Old 02-03-2013, 10:26 AM   #609
ultrachrome
Poser
Oddometer: 225
Me, too. I like the quicker illumination of LED and the long life. I'm a little nervous having only one brake light bulb. I don't religiously check it.
I've thought of building my own LED solution. Designing the PCB and driver circuit seems straightforward enough but choosing the actual LEDs to use is a bit overwhelming.
Old 02-04-2013, 01:55 PM   #610
ktmjvh15
Oddometer: 9
CPR Rottweiler KTM 990 Intake System
I saw earlier in the thread that TheTurtlesHead had installed this system on his bike. Did you do a custom remap with this? I was just curious if you remapped it using TuneECU or if you were using another tuning software. They gave me a map but its for the 08 version of the 990. Does anyone have any maps for TuneECU with this intake system to share?
I bought this for my 990 and have heard and read a lot of good things about it. Best upgrade for the money as far as horsepower is concerned.
http://www.ktmtwins.com/rottweiler-k...-intake-system
ktmjvh15 is offline   Reply With Quote
Old 02-04-2013, 02:31 PM   #611
ktmjvh15
Oddometer: 9
CPR Rottweiler KTM 950 990 Intake System
Hey TheTurtlesHead I saw you posted an earlier thread about installing this. I have this same system for my 990. Did you end up remapping your bike? I don't see anything out on TuneECU for this bike with the rottweiler intake system. They gave me a map at CPR but it was for the 08 year. I have a 2011 990 SMR. Just curious if anyone has a map they could share for TuneECU.
Old 02-04-2013, 03:45 PM   #612
ktmjvh15
Oddometer: 9
Exhaust for 990 SMR
I saw an earlier post about exhaust. I purchased wings exhaust for mine. This guy Ken Darvin over at alternate cycle got both cans for 980, 1035 total including shipping from canada to so cal. If anyone is looking for exhaust the wings exhaust has the same finish as the akras but a hell of a lot cheaper.
http://www.alternatecycle.com
Old 02-10-2013, 09:55 AM   #613
Spark01
V-Twin
Spark01's Avatar
Oddometer: 261
the map that cpr has is build on my 2010 SMT.
if you want a newer mapping just copy the fuel value's in the newer 2011 mapping.
the mappings are back wards compatible, because the engine and ecu are for all years the same
there are just minor changes on throttle control/lamda sensor reaction on the back ground on the newer mappings
'10 990SMT
Spark01 is offline   Reply With Quote
Old 02-16-2013, 06:20 AM   #614
ktmMike OP
Coordinator
ktmMike's Avatar
Oddometer: 1,099
I think Al (theturlteshead) must be out on the job. He's gone for long periods of time sometimes.
Old 02-19-2013, 12:35 PM   #615
ktmjvh15
Oddometer: 9
No problem. I actually ended up doing a search on the thread and came across some posts from kevxtx. Guess like an idiot I should have done this first before asking. He has a tone of useful information on the KTMSMT site. I found some TuneECU maps from some of his posts as well as all the mods he has done and details about them. His stuff is really helpful. Good stuff.
Times are GMT -7.   It's 01:24 AM.
