Old 10-15-2011, 05:06 PM   #331
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,357
Originally Posted by GotMojo? View Post
Has anybody ridden the TAT to the west coast... then turned around and rode it in reverse back to TN? That'd be pretty hardcore.
Originally Posted by simonpig View Post
I could see hanging out on the west coast for a couple of months and then going back by Tat maybe but pulling a Forrest gump and turning back immediately would be masochistic and a bit pointless. Doing it in reverse doesn't make it twice as good.
I can see somebody picking up that gauntlet.
joenuclear is offline   Reply With Quote
Old 10-15-2011, 08:07 PM   #332
simonpig OP
packin' heat
simonpig's Avatar
Oddometer: 1,107
Both chain and f/r sprockets were brand new though?
Originally Posted by TwilightZone View Post
> "The chain was a standard non o ring chain, so I'm hoping my o ring masterlink will be ok as a replacement. First time this has happened to me. Not sure what would've caused it. Adjusted the chain after 500 miles but don't think I it was too tight?"
Looking at the chain/rear sprocket combo... looks like the chain is 'out of sync' with the sprocket. Unfortunately replacing new chain/old sprocket or old sprocket/new chain usually means problems. Explains why the roller links were coming off.
simonpig is offline   Reply With Quote
Old 10-15-2011, 08:17 PM   #333
simonpig OP
packin' heat
simonpig's Avatar
Oddometer: 1,107
Clip on masterlinks are a liability
After putting about 750 miles on the new chain, I stop at a gas station to fill up, and take a look at my chain to find the clip was once again missing. The plate was still intact and felt solid, so I popped a spare clip back on.
Not sure why the chain didn't fall apart on me. Maybe because it was an o ring type that had to be pressed on? I posted earlier that I lost my clip on the original TAT chain, god knows how far back, and the chain stayed together due to the pin welding itself to the plate.
I'm seriously gonna go with rivet masterlink from now on.
Old 10-16-2011, 07:14 AM   #334
CBAT
occasional wanderer
CBAT's Avatar
Oddometer: 837
Spring clips work because if everything is lined up there is no tension on the clip. It only holds the outer link plate on the pins. It has to be that something isn't properly aligned; like you are missing a spacer or something that is putting side stress on the plates causing the spring to pop off. Make sure the sprockets are in the same plane. You may have misplaced a spacer in one of your wheel removals. I have a friend who ran the chain on his KLR for several years a about 10K miles because he just could not get the clip on. He said screw it and rode anyway. Including trips in Big Bend and lots of trail riding. He was lucky that it didn't come apart on him, but it didn't. True story. Bottom line is the spring clip should not be taking a lot of force.
Bruce
2000 Suzuki DRZ400S, 2012 Yamaha Super Tenere
My Great Divide Ride 2009
Great Divide Part 2
CBAT is offline   Reply With Quote
Old 10-16-2011, 08:02 AM   #335
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
There are flat master clips and clips that have a twist, I've found that the flat ones spit off and the ones with a twist stay on. I think it's a DID clip that I've been using that has the twist in it and I don't lose the clip anymore.
larryboy is online now   Reply With Quote
Old 10-16-2011, 09:02 AM   #336
TwilightZone
Oddometer: 3,120
>"Both chain and f/r sprockets were brand new though?"
That's wierd. DID is good chain. Gotta keep non-'O' ring chain lubed though.
Take a few photos of chain sprocket fit...
TwilightZone is offline   Reply With Quote
Old 10-17-2011, 09:21 AM   #337
bigdon
Oddometer: 2,643
I like the rivet style master links. When a clip style is used I put a dab of Silicon on it. I have never lost one! Knock on wood
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 10-17-2011, 09:50 PM   #338
simonpig OP
packin' heat
simonpig's Avatar
Oddometer: 1,107
Got back last evening at around 7:30 last night. Life on the road was fun, but with the turning of the leaves and a chill in the air, it felt like the right time to get back to daily life.
simonpig screwed with this post 03-05-2013 at 08:54 AM
Old 10-18-2011, 12:10 AM   #339
Callahan
Callahan's Avatar
Oddometer: 1,181
Congrats,
from New York to Oregon and back,,, an adventure, no always on top of the bike but back with two legs two arms and a ton of photos and great memories.
Well done.
Callahan is offline   Reply With Quote
Old 10-18-2011, 06:55 AM   #340
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Well done,that's got to make you feel good inside. I'm hoping to head out from R.I. (solo as well) at some point and wondered how many days total,and was it 2 sets of tires you went through? Cheers
leftystrat62 is offline   Reply With Quote
Old 10-18-2011, 10:49 AM   #341
rudyunknown
rudyunknown's Avatar
Oddometer: 713
here i was thinking u would stop by in philly, but i dont blame ya, i would love to head back to my bed after a ride like that, stop by sometime in winter....we can have a fire going and some tea :)
Indian among Americans
Husky 250 "hit that tree"
Adventure bike KTM 690e
Vstrom 1000 For everything else
rudyunknown is offline   Reply With Quote
Old 10-18-2011, 11:00 AM   #342
simonpig OP
packin' heat
simonpig's Avatar
Oddometer: 1,107
Hey Rudy, I was sorta inbetween lunch and dinner when I got to the philly area, so I decided to get on to New York. What's the next ride you're doing? I'm getting back in the NY swing of things.
Old 10-18-2011, 11:30 AM   #343
rudyunknown
Oddometer: 713
Man Reshmi is almost there with the baby, due on thanksgiving, and i hear story from people all the time that they had baby way before the due date, i just did the Scrub Pine Enduro, my first Enduro, it was super fun...
Might swing by one weekend ride to the Pines if thats the most i can do, but i think my season of offroad riding has ended for this year.....next year everything will start back with either Pine Barren or Lawton which ever comes first...
Old 10-18-2011, 12:11 PM   #344
simonpig OP
packin' heat
simonpig's Avatar
Oddometer: 1,107
Dunlop 606's all the way. 2 rear tire changes, 1 front change
TOTAL MILEAGE: 11,293 MILES (60% street/40% dirt)
Observation: (Applies only to WR250R, If you have a big thumper, YMMV)
Dunlop 606s are legendary for a reason. They wear a very long time. Surprisingly if you only do tarmac and gravel, the rear will last you around 8,000 miles. On the other hand, the western desert rocky hardpack wreaked havoc on my tire, with my rear only seeing 5,000 miles.
The front tires wear like iron with my front seeing only 1 change.
If I had to do it over again, I would change my rear tire out in NY, and then again in Moab. The sections that are roughest on your tire is Colorado, Utah, and especially Nevada. You can also do a parade lap on the beach if you change out your rear in Moab, or later.
A brand new front might possibly make it the whole way from NY to Port Orford, I think. Its nice for the east, as the gravel traction is greatly improved. For the west, I don't think it matters as much. That said, having new tires is always nice, so its a matter of how fast you want to go around corners and your personal preference.
Details:
FRONT TIRE
NY to Moab, UT: ~3800 miles (on existing front that had about ~5000 miles on it)
Moab UT, to San Francsico, CA to Los Angeles, CA to NY: ~7,500 miles.
Front still has the middle 2 knobs, which go bald before the center or the side knobs.
REAR TIRE
NY to MS: ~1800 miles (on a existing rear that already had about 5000 miles on it)
Tire Change: After many gravel and highway miles. Close to being bald.
MS to Port Orford, OR to San Francisco, CA: ~5000 miles
Tire Change: The rear was pretty much bald, and looking super rough with micro leaks
San Francisco, CA to Los Angeles, CA to New York, NY: ~4500
The rear tire is still looking OK, a little more than 1/2 worn.
Old 10-18-2011, 12:22 PM   #345
simonpig OP
packin' heat
simonpig's Avatar
Oddometer: 1,107
Scrub Pine Enduro. Was it tough? I'm curious to do one, but not sure I want to do it on my chubby bike.
Times are GMT -7.   It's 10:23 AM.
