06-20-2011, 09:56 AM
#1 |
Oddometer: 749
Yamaha DT400 Clutch Question
![]() My buddy is replacing the clutch plates on his DT400 and he's stuck at the torquing down part. His books says to torque the clutch bolt down to 55 ft/lbs. The schematics refer to the six bolts in the pic as clutch bolts, but the torque specifications says clutch bolt (singular). My google-fu found a tute for replacing the clutch plates on a DT400, but he didn't torque anything down nor did his clutch basket have the center adjuster nut. Anyone know anything about this clutch setup?
'71 r75/5 |
06-20-2011, 12:33 PM
#2 |
Oddometer: 4,315
DON'T DO IT!!!! The 55 ft-lbs figure is for the nut that attaches the hub to the mainshaft!! The spring screws are 7 ft-lbs. Honestly they'll be fine if you run them in 'til they bottom and snug them up gently. As far as the adjuster lock nut just snug it up while holding the screw from moving with a screwdriver.
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
06-20-2011, 01:29 PM
#3 |
Oddometer: 749
Sweet. Thanks for the help.
'71 r75/5 |
06-20-2011, 06:15 PM
#4 |
cheap bastard
Oddometer: 2,999
glad somebody stopped him,,, 55 ft lbs would snap the aluminum under the spring screws
04-03-2012, 11:24 AM
#5 |
Oddometer: 4
Dt400
I was wondering if someone could help me with how to reattach the clutch cable on a DT400. The cable was removed about 6 months ago to rebuild the engine and I can't figure it out. The bottom end of the cable has a flat metal plate with a hole in it but the engine case does not have a hole in it that lines up. Any help or pics would be great.
04-03-2012, 12:10 PM
#6 |
Oddometer: 1,025
Is that hole D shaped ?
If so it'll line up a matching shaft, nut and washer under the sprocket cover where the throw out mechanism resides. Purely a guess, btw. |
04-03-2012, 12:14 PM
#7 | |
Oddometer: 1,025
04-03-2012, 12:54 PM
#8 |
Oddometer: 4
OK, so the metal plate goes vertical and the hex bolt that holds the sprocket cover also holds the clutch cable?
I will give that a try tonight. The clutch plates are also stuck together and need to be removed this weekend. The fun doesn't stop. |
04-04-2012, 12:26 PM
#9 | |
Oddometer: 1,025
It's been a while since I've had my hands on one, pics would help. |
04-08-2012, 06:40 PM
#10 |
Oddometer: 4,315
You need to host the images online and link from there. I use Photobucket for mine.
04-09-2012, 04:14 AM
#11 |
Oddometer: 4
http://s1162.photobucket.com/albums/...t=DT400001.jpg
Here is a pic of the clutch lever. Does anyone know, or have a pic of how to connect the bracket? Thanks beaton172 screwed with this post 04-10-2012 at 09:48 AM |
04-15-2013, 05:22 AM
#12 |
Oddometer: 6
I'm having the same problem...I have no idea how that cable mounts. Please Help!!
04-15-2013, 08:09 AM
#13 |
Oddometer: 234
There should be a bolt hole on the underside of the cylinder that holds the bracket I believe.
04-15-2013, 03:25 PM
#14 |
Oddometer: 6
I looked but didn't see any bolt holes....
04-15-2013, 03:58 PM
#15 |
Oddometer: 234
If the clutch actuation arm is on top of the motor, like a 1977 there will be a bolt hole in the bottom of the cylinder. It shows it on the parts fiche. The 76 may have hooked up like the YZ's which was under the motor.
