Old 01-20-2012, 09:57 AM   #391
Snarfy
Oddometer: 63
Just ordered one, have enough of my carbtune.
Should be coming to Rotterdam, Nederland.
Snarfy is offline   Reply With Quote
Old 01-20-2012, 11:28 AM   #392
Grok OP
Grok's Avatar
Oddometer: 3,566
Originally Posted by jndomin View Post
Just wondering if it's available yet.
Unfortunately no. Still a few months away :(
You can't go backward if you are facing the right direction
Grok is offline   Reply With Quote
Old 01-21-2012, 01:01 AM   #393
Mens Rea
Mens Rea's Avatar
Oddometer: 274
san rafael ca
Ok, no exciting overseas destinations - just inside CA, so lucky me gets to pay sales tax
I'll be using this on my r1150r commute bike, but I am reviving a 91 k100rs - is there a post on using it on 4 cylinder bikes by balancing in pairs?
thanks
Mens Rea is offline   Reply With Quote
Old 01-21-2012, 11:11 AM   #394
Grok OP
Grok's Avatar
Oddometer: 3,566
thanks
I have balanced a 4-cylinder bike with it. I kept the red port always connected to number 1 cylinder and moved the yellow port connection to cylinders 2,3, and 4. Some bikes have a designated reference cylinder and that cylinder has fixed or limited adjustments. For example, some Honda's specify cylinder number 2 as reference.
Quite frankly it isn't the most convenient tool for motors with more than 2 intakes. But it can be done.
I am working feverishly on a 4-cylinder version but it is still a few months away.
Old 01-21-2012, 03:29 PM   #395
Howie333
Oddometer: 4
I'm presently considering the 4 cylinder model, but need only a balancer for a twin now. Just figure my next ride could possibly be an in line 4. If I was to buy a current 2 cylinder version harmonizer, It seems fairly easy to just use an aquarium type manifold for the remaining cylinders, but would be simpler to just be able to see all 4 cylinders at once while doing adjustments.
Howie...
Howie333 screwed with this post 01-22-2012 at 06:27 AM
Howie333 is offline   Reply With Quote
Old 01-22-2012, 09:50 PM   #396
jay956
jay956's Avatar
Oddometer: 75
I have a tuning question. You say you can use the gauge mode to tune each carb using the fuel screw, and reaching the peak vacuum is also the peak efficiency. My bike bike does not have the vacuum port on the carbs themselves, rather on the cylinders. Would I use the same technique? I would imagine so but I wanted to double check. Thanks.
jay956 is offline   Reply With Quote
Old 01-22-2012, 10:18 PM   #397
Grok OP
Grok's Avatar
Oddometer: 3,566
Yep, Vacuum is measured anywhere between the carb slide (or butterfly in your case) and the intake valves in the head.
I found a little bit of info here:
http://www.superhawk996.net/
Navigate to:
VTR1000F/Performance and Mods/Carburetor Synchronization on the VTR
I've never tuned a Hondacati but I think this info will be useful to you!
Grok screwed with this post 01-22-2012 at 10:24 PM
Old 01-22-2012, 10:26 PM   #398
jay956
jay956's Avatar
Oddometer: 75
Thanks. I've don the sync before. your tool should be a lot nicer than the two snapple bottles I've been using!
Old 01-25-2012, 11:31 AM   #399
fair1535
Oddometer: 1
Harmonizer
Just a quick line to say many thanks for Harmonizer, looking forward to using it, new to this site and already found a wealth of valuable information to help me keep my pride and joy ship shape. 1150 GSA 2003
fair1535 is offline   Reply With Quote
Old 01-25-2012, 06:04 PM   #400
Grok OP
Grok's Avatar
Oddometer: 3,566
Old 01-28-2012, 05:50 AM   #401
Snarfy
Oddometer: 63
I got it !
Somewhere during next week i'll give it a try !
Old 01-28-2012, 03:42 PM   #402
ereneT
Oddometer: 76
Got mine, thanks.
I was looking at the end (bike side) of the Harmonizer hoses, and noticed that the hoses are cut (4" long) with a piece of plastic tube (coupling), that must be there for a reason.
Is it ok to cut a couple of pieces of hose (about 2" each) from both of them, so they stay the same length, make a T I need to sink my S10, then replace the two 4" end peaces with the plastic coupling back again?
ereneT screwed with this post 01-28-2012 at 03:47 PM
ereneT is offline   Reply With Quote
Old 01-28-2012, 04:35 PM   #403
Grok OP
Grok's Avatar
Oddometer: 3,566
Originally Posted by ereneT View Post
Got mine, thanks.
Hello sir,
The plastic "couplings" act a restrictors to protect the Harmonizer from backfire and over-stress conditions.
They work in conjunction with the hose volume to act a "snubbers" that limit peak pressures presented to the sensor.
They should remain in place.
There is enough hose length so that stealing a couple of inches from the inboard section wouldn't compromise their function. But if memory serves, the fittings on the S10 are on the small side. So you might get a better permanent fit by buying some 1/8" ID vacuum hose to fabricate your "T" instead of using the Harmonizer 5/32" ID hose.
I tried doing exactly as you suggest when I had the opportunity to use the Harmonizer on a local S10. The Harmonizer hoses didn't leak, but the Yamaha wire-clamps didn't seem to work very well on the 5/32" hose. The local Tenere guys seem to prefer 1/8" hose where it fits to the throttle body.
-Mark
Old 01-29-2012, 01:19 AM   #404
ereneT
Oddometer: 76
OK, I'll look for the 1/8 ID vacuum hose.
Thanks again
Old 01-31-2012, 11:46 AM   #405
ekowob
ekowob's Avatar
Oddometer: 1
The harmonizer has arrived.
It's the greatest thing i've ever work with.
Thank you, from Hungary!
ekowob is offline   Reply With Quote
Times are GMT -7.   It's 04:25 AM.
