07-30-2011, 08:34 PM
#61 |
Oddometer: 3,562
Thanks fellas!
I think you will be happy with your purchase!
You can't go backward if you are facing the right direction |
07-30-2011, 10:07 PM
#62 |
Oddometer: 851
Any idea on the price difference between the 2 and 4 cylinder version?
I need to decide which one to go for. Thanks
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat |
07-31-2011, 07:03 AM
#63 |
Oddometer: 3,562
It's too early to nail it down. 4-cylinder version will likely be somewhere in the $175 ballpark. I'm trying to make it lower, but I can't commit to a price just yet!
07-31-2011, 10:39 AM
#64 |
Oddometer: 403
07-31-2011, 10:54 AM
#65 | |
Creaks When Walks...
Oddometer: 1,211
CBX's...
And the six-cylinder version for folks with vintage Honda CBX's? ![]() Dallara ~
~ You never see a motorcycle parked outside a psychiatrist's office ~
07-31-2011, 11:01 AM
#66 | |
Oddometer: 3,562
I also thought about a modular approach where ports could be added to a base unit. But it got complicated quickly and caused the costs to go up too much. There was a fellow in Sweden that tuned a 12 cylinder Jaguar (4 Stromberg carbs) using the Harmonizer in a very inventive way. I think I might do a video tuning a Valkyrie with the Harmonizer at some point.
07-31-2011, 11:42 AM
#67 | |
Oddometer: 1,211
Multi-Multi's...
I think you know I was kidding, Grok... But you know, it's funny you mentioning that 12-cylinder Jaguar. Back in the early '80s we used to actually synch the Weber sidedraft carbs on a 1973 Ferrari 365 GTC/4... ![]() Using three sets of inline-four rack vacuum gauges hung on the back edge of the hood (it hinges forward). We calibrated all 12 individual gauges as best we could from a know vacuum source, making reference marks on each one, and then hooked 'em all up and went to work. Actually, it worked wonderfully, even if it did look rather like spaghetti with all those hoses hanging all over the place... ![]() Thanks for bringing back the memory! Dallara ~
08-01-2011, 12:37 PM
#68 |
Oddometer: 971
Problems
I was using the Harmonizer on my Ural Patrol this afternoon, I had done it a week ago with my Twinmax but wanted to fine tune it. OK I wanted to play with my new toy. Everything was close, as expected. Adjusted idle and off idle with no problems. Went back to fine tune idle speed and suddenly the display went to -155 mbar and no RPMs.
Disconnected the hoses, they are clear and no leaks as they hold oral applied pressure. Reconnected and let it zero, all it does is read 000 mbar. Tried it on my R1100R, which I did with the Harmonizer on Saturday, with the same results, 000 mbar. ![]()
The shortest distance between two points is boring. |
08-01-2011, 01:02 PM
#69 |
Mod-U-Later
Oddometer: 13,572
That is called infant mortality, and refers to a component dying during the first 2-3 weeks of use (±).
It happens, thankfully, rarely. JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. |
08-01-2011, 01:35 PM
#70 | |
Oddometer: 3,562
I'd appreciate you returning the defective unit to me so I can do a fault analysis! Thanks!
08-01-2011, 01:44 PM
#71 | |
Oddometer: 3,562
I cracked open the sensor and found the manufacturer had missed a sealing step during assembly. It was as if a goop dispenser (fancy technical term) had run empty during sensor assembly. I have put a pulsed overpressure test in place to catch this type of defect, but obviously one got through. D'oh! We'll get you fixed up immediately.
08-01-2011, 01:49 PM
#72 |
Oddometer: 93
Count me in as well!
I just made a purchase as well. Basically looking forward to better balancing!
Jonathan
Jonathan D. Howell Lieutenant Colonel, US Army 1972 KMZ "Dnepr" MB650, 2003 BMW F650CS, 2011 Yamaha Vino Classic |
08-01-2011, 02:03 PM
#73 | |
Oddometer: 747
2002 BMW R1150GS - Graphitan, PB riding 2000 Aprilia Pegaso - Blue, for the trails!! 02 Pagsta Choppa, 85 & 86 GSX-R 750 (projects) 2005 Ford F-250 Super Duty XLT 4x4, do-it-all Pine Barrens Beastie |
08-01-2011, 02:32 PM
#74 |
Oddometer: 2,385
One To Canada
I just ordered one a few minutes ago. All the good reviews here, made it hard for me to resist.
08-01-2011, 02:41 PM
#75 | |
Oddometer: 971
