06-11-2013, 07:18 PM
#1 |
Speed changes you.
Oddometer: 567
Whats the tricl to put a rear tire on rim, seems impossible
04 ADV 950 |
06-11-2013, 07:29 PM
#2 |
Allergic to Asphalt!
Oddometer: 6,091
Gotta have the opposite side of the tire down in the dish of the rim (where the spokes connect).
Also review Neduro's Tire Changing Tutorial.
06-11-2013, 07:38 PM
#3 |
Oddometer: 273
Opposite side of the tire needs to be flush with the center of the rim like mentioned above.
Use lube. I use dish soap and water. Heat up the tire in the sun if possible. Wear gloves. I always tear up my hands. Don't give up. |
06-11-2013, 07:54 PM
#4 |
Oddometer: 139
Lube, more lube (that's what my wife says....), take little bites with the tire irons, and keep the opposite side deep in the well. Did I mention more lube????
06-11-2013, 07:56 PM
#5 | |
Speed changes you.
Oddometer: 567
04 ADV 950 |
06-12-2013, 07:08 AM
#6 |
Oddometer: 273
One more thing. I put the rear tire on with the disk side up if I don't have a wheel stand available. I worry about warping the disk. Glad you got it on there.
06-12-2013, 07:21 AM
#7 |
Semper Fi
THE MOST IMPORTANT THING!!!!
Don't let your wife catch you using her hair drier to heat your tire.
2012 300 EC Race 2010 690 R 2007 990 S
06-12-2013, 07:32 AM
#8 |
Uses lotsa band-aids
Oddometer: 9,659
![]() I just noticed the ratchet tie down around the axle and lever. ![]() Glad you got it on, OP.
Egotism anaesthetises the egotist's stupidity.
06-12-2013, 07:46 AM
#9 |
Positating the negative
Oddometer: 73,681
After a couple years in Latin America I got accustomed to paying people to put my tires on for me. I recently mounted my rear tire for the first time in a few years and it was way easier than I recall, I must be learning something.
For me I tried to focus on keeping the tire within the bead as I was spooning it on. I did this one on the ground but I prefer a good barrel for changing tires.
"So what you gonna do when the novelty is gone.."-- Joy Division Same as it ever was 2010 Latin America Route |
06-12-2013, 09:47 AM
#10 |
Where fun goes to die....
Oddometer: 3,230
Use small blocks of wood on the opposite side to keep the wheel in the dish of the rim, I travel with about 4-6 small derlin blocks I used for just that purpose makes changing the wheels much much easier.
DSM8 - A different kind of mean SQL > SELECT finger FROM hand WHERE id=3 WWW.DSM8.whereamiriding.com |
06-12-2013, 05:37 PM
#11 | |
Speed changes you.
Oddometer: 567
...pushing it into the dish on the opposite side did it with little effort.
04 ADV 950 |
06-12-2013, 06:03 PM
#12 |
Oddometer: 6,091
Motion Pro Bead Buddy
