Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 07-17-2011, 03:50 PM   #136
DirtJack
DirtJack's Avatar
Oddometer: 1,606
Originally Posted by dhula View Post
While I've mucked around in TuneEcu a little, I've never watched what the maps do once you put it in gear and then release the clutch lever. The reason I mention this is because on my bike when I do this, the revs increase a little (~100-200rpm) and then once you pull the clutch lever back in the revs go back down to normal idle. I've seen this while the bike is no the centre stand but can't comment while normal riding.
I've not checked as to whether this is due to the clutch switch doing something or the engine sensing a load (via MAP for example) and increasing revs. Checking this may be difficult as TuneEcu from what I can see doesn't appear to follow changes on the L maps as it does on the F maps.
My suggestions would be that the stand switch - no probs. Clutch switch - maybe not a good idea but would certainly get you home. Perhaps a small toggle switch to bypass a broken clutch switch would be a way to get home if the worst was to happen.
Most (not sure this applies to the one Triumph uses in the XC) Keihin ECU's use the clutch switch when the bike is in gear, rpm's higher than a certain value and the throttle is closed to select between idle map (clutch pulled) and cutting all fuel to injectors (clutch not pulled). Given the interaction of the clutch switch with other sensor inputs, it is not easy to defeat.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-17-2011, 04:52 PM   #137
Burren Rider OP
Aussie Adventurer
Burren Rider's Avatar
Oddometer: 1,819
Originally Posted by Foot dragger View Post
I was thinking the same thing,the OP says he has a DRZ in the stable though.
Id have a hard time dropping that much cash on a big Street oriented 3 cylinder bike and then burying it in a mud hole straight off. I guess Ive never been drawn to big off road bikes,I think my DR is way too big for dragging through ugly woods trails. The Tiger does look neat with all the rough/tough off road stuff on it.
I will have a Triumph Triple at some point,the 1200 Trophy Ive got now is a kick!
I guess my logic is a little different. As mentioned earlier, I like riding big bikes in the dirt but even if I only planned on using the bike on dirt roads, I still want the dirt credentials to access out of the way places. Sure, you can get a long way on a road bike but dirt roads can quickly turn into quagmires with a bit of rain (and we have had a lot of that lately) and I reckon a capable dirt bike is good insurance. I am heading west on a 5,000km desert ride next month and I really wanted to see what the bike was capable of before planning a route that will include multiple dirt legs of 500km's or more. Maybe we are lucky in Oz to have access to these kinds of spaces and that is why you find so many of the "Adventure bikes" being used extensively in the dirt
Burren Rider is offline   Reply With Quote
Old 07-17-2011, 05:20 PM   #138
Burren Rider OP
Aussie Adventurer
Oddometer: 1,819
Originally Posted by G-Funk View Post
As far as DRZs go, which I've had one, and will probably have another at some point in the near future ....... this ....... this is what I'd consider the shit, when it comes to a DRZ, and the owner, and poster of the build thread, are in the OP's neck of the woods.
We are pretty fond of the DRZ's in Australia, to the point where they are one of the biggest selling bikes in the country. Mine isn't as trick as that one but I have had a few over the years and have had a lot of fun with them .
Burren Rider screwed with this post 07-17-2011 at 07:19 PM
Old 07-17-2011, 05:46 PM   #139
bmwmc
Slow Rider
Oddometer: 36
Originally Posted by glitch_oz View Post
Hi Danny
Love the thread...great posts!!
Thanks for the effort taken
Re: sidestand switch...Rather than bypassing the switch, how about just re-locating it.... out of harms way, that is.
Like this perhaps (on a DL)
Didn't mess with any electronics to just make a little alum bracket, bolt the switch onto that, then re-route the cable to make the whole shebang sit unter a side-panel, away from sticks and mud.
That is brilliant. I have been debating removing the switch. Your idea is much better.
bmwmc is offline   Reply With Quote
Old 07-18-2011, 07:28 AM   #140
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,784
This weekend I removed the spent Battlewings from my Tiger and mounted up some more aggressive tires.
I put a Kenda Big Block in front:
And a Shinko 705 on the back:
That Kenda front felt really squirrelly at first -- vague, unstable, and prone to head shake. After a 300-mile street ride with some sportbike-riding friends, the little molding hairs were still clinging on tenaciously, and I realized they were the culprits. There are four per tread block; I cut them off Saturday evening, and when I went for a ride yesterday, the front end felt much better.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 07-18-2011, 12:50 PM   #141
KildareMan
KildareMan's Avatar
Oddometer: 692
Originally Posted by DRTrev View Post
Now isn't that a bloody simple but very efective idea.....well done Sir
Nice bracket, but, NOT necessary on Tiger as the plunger compressed is the side stand in use (down). Engage gear with the side stand down and engine cuts out.
I've just fed mine up and zip tied it to a cable tidy just above the top end of the gear change rod. Works a charm.
KildareMan is online now   Reply With Quote
Old 07-18-2011, 02:12 PM   #142
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,330
Good to know
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-18-2011, 02:23 PM   #143
Rastus
World Traveler
Rastus's Avatar
Oddometer: 84
Thumb Tiger 800 XC
Man, I love this Bike!!!...
2008 Harley Road Glide "The Paint Shaker" Owned 23 days (Sold)
2006 Victory Kingpin "60,000 Trouble free Miles, Needed Bags" (Sold)
Rastus is offline   Reply With Quote
Old 07-18-2011, 05:17 PM   #144
G-Funk
That ... Umm ..... "Dude"
G-Funk's Avatar
Oddometer: 5,259
Please know I was not inferring that your DRZ was inferior in any way. Mine wasn't that trick either. I just think the OP of the Rallye DRZ did a great job on his build up.
In fact I still have the thread subscribed so I can review from time to time. Really, IMHO, the only thing lacking with the DRZ is that it's a 5 speed, and not 6. Why Suzuki did that with the DR350, and didn't carry it over to the DRZ is beyond me.
Though - This is an 800xc build thread, and not a DRZ build thread so to get back on track, I think what you've done with yours is sweet.
Right now, the only real thing I'm researching out is crash bars and the bash plate, for when I get mine. The OEM Triumph "upgraded" bash plate looks nice, but so does the sw-motech one. As for crash bars I was just going to get the OEM Triumph ones, until I saw the H.B. lower, and, upper bars. Then I saw the Happy Trails unit, which handles both the lower end as well as the upper end. So at the moment, I'm deciding between either of those two.
Tire wise, I thought is either TKC-80s, which I'm quite use to, or - either - E09 Dakars, or the Mich. T63 for a rear and an E09 up front. I know a few peeps that run the Mich. T63 on the rear of their Africa Twins with a TKC or E09-D up front, and the AT is 100 lbs heavier than the 800xc.
Again, thanks for the write up, it is helping me quite a bit, and I haven't even bought mine yet.
G.
EDIT: One other thing - have you thought about an aux fuel tank on the left hand side since the 800xc is a 3 into 1? Or, would you just go with like rotopax (correct manufacturer?) to carry additional fuel for extended long off-road trips? Your thoughts?
03 Caponord
"The Funness out-weighs the Dumbness ....." - Mr. Jetmoto
G-Funk is offline   Reply With Quote
Old 07-18-2011, 07:09 PM   #145
Burren Rider OP
Aussie Adventurer
Oddometer: 1,819
No worries, I certainly didn't take it that way. I really attached to the mighty DRZ so any excuse is a good one to post a few photo's . That is one really nice DRZ and I reckon it would be very competitive in the long distance rallies it was set up for
At this stage I am probably going to run a bladder of some description for the desert trip in August and then look at the Aqualine tank when it comes out. They are looking at a capacity of around 30 Litres at this stage but production is still a fair way off.
Old 07-18-2011, 07:13 PM   #146
Burren Rider OP
Aussie Adventurer
Oddometer: 1,819
G'Day Mark,
That front looks pretty good for a road legal tyre. Interesting that the trimming made a difference, wonder if that explains why some tyres feel sketchy for the first 500km's?
Cheers,
Danny
Old 07-18-2011, 07:44 PM   #147
Burren Rider OP
Aussie Adventurer
Oddometer: 1,819
Photo's of the home made Fender raising brackets. I went for a 20mm lift and in my typical fashion of over engineering everything, placed an additional bolt through the fork guards into the extra lug on the forks.
The result is a big increase in clearance for the front tyre.
Old 07-18-2011, 07:46 PM   #148
Burren Rider OP
Aussie Adventurer
Oddometer: 1,819
Navigation
An SW Motech GPS bracket makes way for the GPS and it seems to fit nicely into the scheme of things. Although fairly basic, the rubber damping system appears to work well and the GPS sat there perfectly in the dirt.
Old 07-19-2011, 01:16 AM   #149
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,895
Originally Posted by Adv Grifter View Post
This is a good, cheap and effective safety device. We put cable safety snakes on our enduro and dirt bikes for years. It saves your shift or brake lever catching on a stiff branch or lose barbed wire and bending it in a full U turn while flipping you over the bars.
Nice idea ... and one I hope anyone who rides off road will consider. Many of us have seen shift levers torn clean off in a fall or by catching something along the trail. Magic little cable really works to prevent that. CheerS!
Glad to be of assistance.
My cheap versions are made from a peddle cycle brake cable (2.80), which has a nipple at each end. So you can do both levers with one cable. And an electric cable connector as you can see in the picture. There's enough clamping power in those two screws for it to work as I proved a while back on my Triumph Scrambler. I also used a piece of plastic tube over the cable to stop the cable rubbing the crash bars away.
P.S. I've turned it around now so that the excess cable is pointing rearwards.
P.P.S. remember to leave enough slack that the lever does what it was designed to do.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 07-19-2011, 05:31 AM   #150
fasteer
fasteer's Avatar
Oddometer: 283
all very interesting info, thanks everyone.
I'm craving a bike like this for gravel roads & jeep trails.
It would have to do some 2-up duty to get by the VP Finance.
How's the passenger accomodations?
87% of all statistics are made up right there on the spot.
fasteer is offline   Reply With Quote
Times are GMT -7.   It's 01:09 PM.
