10-17-2012, 01:44 PM
#1501 | |
Oddometer: 1,479
it pulls fine with stock gearing on the highway. I believe that it will pull just fine with a tooth dropped as well. Just maybe at 75 instead of 80.
2005 Ural 2005 BMW F650GS 2012 Triumph Tiger 800xc |
10-18-2012, 04:02 AM
#1502 | |
RN
Oddometer: 754
JG |
10-18-2012, 04:15 AM
#1503 | |
RN
Oddometer: 754
BTW, it was only $15 for a 15T sprocket from my dealer. When the winter comes and I am not riding dirt anymore for the year, I might change it back for highway/commuting. The 15T is a no brainer if you are riding dirt/rocky jeep trails. JG |
10-18-2012, 04:29 AM
#1504 | |
Oddometer: 124
What about two sets of sprockets mounted, and a slider with a handlebar lever, like the gear change on a bicycle? It would be like a two speed, but actually be a twelve speed. |
10-18-2012, 05:42 AM
#1505 | |
Deputy Cultural Attaché
Yeah, I know. You see blue sky, I see clouds.
Successfully surviving motorcycling since 1976. |
10-18-2012, 05:45 AM
#1506 |
Oddometer: 2,482
A bicycle has a rear derailluer that acts as a chain tensioner. I'm not sure you could develop a tensioner that would be tensioned enought to withstand an 800cc motorcycle, yet, be slack enough to allow it the chain to climb to the higher gear. Also, the rear cassette has teeth shaped in a specific way, on a bicycle, to get the chain to climb the gears. Lastly, a motorcycle chain is designed to be ran only in a straight chainline, whereas a bicycle chain is designed to be cross-chained.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
10-18-2012, 05:58 AM
#1507 | |
Oddometer: 206
That way the extra running gear stay clean inside the enlarged engine cases :-) |
10-19-2012, 04:30 AM
#1508 |
Oddometer: 124
I suppose one of us could just email someone like Nova racing and ask them to cut taller 5th and 6th gear for us. Combine that with the shorter first from a 675, and we have a wide ratio transmission. That would probably be a whole lot simpler than adding a derailer and chain tensioner. It worked for the DRZ guys.
10-19-2012, 09:43 AM
#1509 |
Oddometer: 124
Asked Leo Vince about the spark arrestor. They ship with the pipe now. I bought mine in July, they are sending one at no cost. Awesome customer service.
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2 |
10-19-2012, 10:30 PM
#1510 |
RN
Oddometer: 754
10-20-2012, 06:26 AM
#1511 | |
Oddometer: 501
10-20-2012, 06:28 PM
#1512 | |
RN
Oddometer: 754
I really like this idea too. Any ideas of how much this would cost? I'm sure it would really help with first and second gear off road as well as fuel econ at highway speeds. JG |
10-21-2012, 04:58 AM
#1513 |
Oddometer: 501
I'll bet it would cost as much as $1500...
10-21-2012, 08:13 AM
#1514 |
Oddometer: 124
Here's a link to a thread on Thumpertalk about the DRZ transmission:
http://www.thumpertalk.com/topic/914780-drz-400-wide-range-gearbox/ He said it was 1250 GBP for the first one, and 800 GBP for subsequent transmissions. So it looks like our guinea pig would be out close to $2500. Chinookmark screwed with this post 10-22-2012 at 09:28 AM |
10-21-2012, 09:09 PM
#1515 |
Oddometer: 33
Clutch slip
I had a problem with my clutch slipping yesterday which sort of ties in with the gearing conversation. Bike is 15 months old with 14000 klm on it and a bit early to be having clutch problems I thought. We were pushing through an overgrown track I hadn't been on in about 15 years and it was a bit steeper than I remembered. So it was 1st gear moving slowly with a bit of push and shove and a lot of clutch work.The engine never overheated only going 1 bar hotter than normal running temp , I made sure I kept an eye on it. I noticed the lever engaging further out before getting drive and when back out on the road in high gears would rev but not increase speed at the same rate. It was ok if you were gentle on the throttle and rode home no problems. This morning I removed the clutch plates for inspection and found the friction plates still looked perfect but the steels were discoloured slightly black. I shuffled the plates , repacked them and gave the bike an oil change. I've only taken it for a 10 min test ride but there's no slipping and it seems to be back to normal again. What I'm wondering though is what happens if you're out past the black stump somewhere stuck in a mud hole or something and really abuse the clutch . I've treated enduro bikes a lot worse and never had clutch problems. Maybe what's basicly a road bike engine/clutch/gearing isn't up to this treatment . Anyone else had poblems? Still love the bike though, this is my first problem with it and appears to have been solved easily. ....Ian
