02-28-2013, 02:52 PM
#1666 | |
Oddometer: 2,278
Reminds me of a dial up modem.
On the Mend ![]() (Black 2012 Tiger 800 XC. ) You think hiring a professional is expensive, wait until you hire an Amateur! |
02-28-2013, 03:34 PM
#1667 | |
Once you go Triple...
Oddometer: 20,421
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
03-01-2013, 06:59 AM
#1668 | |||
Oddometer: 2,459
![]() Stepper motor? ![]() ABS module? ![]() Can't be any of those. My '06 Daytona 675 and '09 Tiger 1050, both, did/do it. The commonality between them and T800 is the EFI; they run the same brand. It has to be the ECU, based on where the sound originates and that they all three sound identical. You can't pull the tank completely off to investigate, but, you can lift it and cycle the key. Whatever you do, don't cycle the key with fuel lines disconnected, as that'll trigger a CEL.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) ducnut screwed with this post 03-02-2013 at 06:01 AM |
03-01-2013, 07:41 AM
#1669 |
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,397
It's been well-established that the sound is the stepper motor, which actuates a lever that resets the idle. You can actually watch it in action if you know where to look -- and you can also give that lever a squirt of WD40 if you're having the stalling issue. Plenty of discussion on this in the main Tiger 800 thread.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe My ride reports: Missile silos, Labrador, twisties, and more Bennington Triumph Bash, May 31-June 2, 2013 |
03-01-2013, 07:52 AM
#1670 |
Tigers R great.
Since when does a solid state processor make a noise? Also my ECU isn't under the tank where MY noise comes from. It's under the seat. I'm still going with the stepper motor. Although, when I first heard it, I thought it was the fuel rail de-pressurizing.
2002 Tiger955i in black, 68500 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... |
03-01-2013, 08:27 AM
#1671 |
Oddometer: 357
Lol your right bad choice of words on my part, had my helo DECU motors on my mind at the time which is essentially the same thing as the stepper motor on the bike.
Ill try to keep my helicopters and my bike terminology separate
Jeff
03-01-2013, 10:08 AM
#1672 |
Reformed Kneedragger
Oddometer: 4,381
I read somewhere that your last sentence is the closest to correct. Something about purging excess pressure from the fuel system after engine shutdown.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides "A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad |
03-01-2013, 10:21 PM
#1673 |
Oddometer: 4
On a funny note, I thought I had all the bases covered by reading all about the tiger before I bought. I knew about the front mudguard and bought the tt fender riser, and wouldn't ya know I just had to go offroad during break in and came across maybe at mist a 20 foot mud patch and BANG fender launches out in front of me. Here is the kicker....I get home and what showed up, yep you guessed right the fender riser! Not all bad as the pieces glued back together with some loc tite super glue and some epoxy and good as new(FYI 180 bucks for a replacement best price!). So thanks to all of your for your wisdom and observations and a word of advice to any prospective Tiger owners take heed to this forum.
03-02-2013, 06:35 AM
#1674 | |
Oddometer: 2,459
I did a little investigating on this "noises" topic. I called a Triumph mechanic that I know. One of the things he mentioned was a solenoid, in addition to a servo motor (depending on bike-Daytona has an exhaust valve that cycles, upon shutdown) and ECU. He said, to his knowledge, the fuel system does not go through a de-pressurization process.
I broke out my Daytona and Tiger 1050 service manuals and got to reading. Then, I went out to the shop and started investigating, with numerous cycles and starts of my 1050. The stepper motor is very quick to act, made no noise, activated upon startup, and quickly retracted during the bike's shutdown sequence (~30 seconds after key off). There is a solenoid located in the secondary air injection system (Daytona and Tiger both have it). I can't see it, without taking off the tank. However, based on the location of the noise (front of my tank), the manual showing the solenoid being there, and the mechanic stating "solenoid" in his list, I'm convinced that's what is making the shutdown noises. The stepper motor's action is extremely quick (milliseconds) and it made no noise, during that movement (the 1050's is just inside the right frame spar and can be seen/touched). With gas cap open during the shutdown sequence, I don't hear any release of pressure inside the tank. The next step is to get my tank ran down and unbolted, so that I can get a better look at this solenoid. Interestingly, I found mention of an "EMS main relay" that does the following: Quote:
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
03-02-2013, 07:45 AM
#1675 |
Tigers R great.
Whilst the fuel system doesn't go through a de=pressurization "process". It does de-pressurize. Otherwise you wouldn't hear the fuel pump running when you turn her on. If it is fuel related it could just be the fuel releasing pressure back through the pump after shut down.
The secondary air injection theory doesn't apply because the 800s don't have it.
03-02-2013, 08:41 AM
#1676 | |
Oddometer: 2,459
03-02-2013, 03:18 PM
#1677 |
Tiger Rider
Oddometer: 64
The fax noise is a movement of the throttle butterflies, Torque (the android app) and my elm-327 (obd reader) confirm this as the TPS value fluctuate while the sound is present.
03-02-2013, 06:58 PM
#1678 |
Oddometer: 62
The stepper motor controls idle by creating an effective idle stop on the butterflies. It makes perfect sense that the TPS would change as the stepper motor is recalibrating on shut down.
03-03-2013, 07:15 AM
#1679 |
Oddometer: 3,814
I love it, finally the mystery may be solved.
"Deeply flawed people make deeply flawed decisions." |
03-04-2013, 06:39 AM
#1680 |
Oddometer: 2,397
If you read through the Tiger 800 main thread, you'll find that the mystery was solved a long time ago. Reread my previous post.
--mark
