03-04-2013, 10:12 AM
#1681 | |
Tigers R great.
2002 Tiger955i in black, 68500 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... |
03-04-2013, 12:16 PM
#1682 | |
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,397
Then allow me to convince you. Get down on the right side of the bike with a flashlight and look up a few inches inside the frame, to the rear of the cylinder head, and find the small accordion-boot-covered plunger attached to the stepper motor. Cycle the bike's ignition on and off, shine the light on that plunger, and watch it move in sync with the faxing sound. From that position it also becomes quite obvious that the sound is coming from that location. Try it, you'll see. I'll also add that for those who have the stalling issue, giving that plunger a little squirt of WD40 and cycling the ignition will solve the problem. It happened to me a couple of times on my Labrador/Newfoundland trip this past summer, and the WD40 cured it until more dust accumulated. --mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe My ride reports: Missile silos, Labrador, twisties, and more Bennington Triumph Bash, May 31-June 2, 2013 |
03-04-2013, 01:40 PM
#1683 | |
Oddometer: 2,449
Once it warms up a bit, I'll set my tank sideways on the frame and go through my previous start/stop sequences. I'll find it, one way or another.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
03-04-2013, 03:59 PM
#1684 | |
Once you go Triple...
Oddometer: 20,417
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
03-05-2013, 05:48 AM
#1685 | |
Oddometer: 2,397
--mark
03-05-2013, 07:00 AM
#1686 |
Oddometer: 3,814
I'll check it out Mark, but if it is a common noise to all of the newer Triumph line, including those without stepper motors, then it has to be something else.
"Deeply flawed people make deeply flawed decisions." |
03-05-2013, 09:43 AM
#1687 |
Oddometer: 63
Mark, I will need to do the WD-40 treatment I guess. I am having serious stalling issue especially when the bike is hot from elongated time of 2nd gear riding. Has anyone put up pictures of this? Also, what else should I be doing to counter this stalling issue.
03-05-2013, 09:59 AM
#1688 |
More or less in line
Oddometer: 2,255
I don't know shit, but my dealer said its resetting everything for proper start up. Good enough for me.
Tek, remove the tank & airbox. The stepper motor arm needs to be clean & lubed. Here's some pics Stepper motor ![]() Throttle roller ![]() Wider shot
Heart of Dixie
03-05-2013, 10:11 AM
#1689 |
Tigers R great.
Make sure you've got the latest ECU tune in it. The tune in mine has anti-stalling properties like a diesel. So much so that it'll tickover up a 1in5 hill in second gear!
03-05-2013, 03:43 PM
#1690 |
Oddometer: 20,417
I have not heard the same noise on my Speed Triple and Sprint.
03-05-2013, 03:48 PM
#1691 |
Oddometer: 20,417
![]() OK, so when people say to remove the arm and lube it, what exactly are you talking about ![]() From the pic it appears the little nut bottom right has been remove to pull that shaft out - is that correct ? If so, how did you get that bolt out with the throttle body in the way - as per the pic ? When I was diagnosing my stalling issues, I wanted to undo that nut to get to the shaft and clean and lube but IIRC, I couldn't get it out due to the throttle body being in the way.
03-05-2013, 03:54 PM
#1692 |
Oddometer: 2,255
That pic is all that was done. I cleaned up with cloth & compressed air. Lubed the stepper arm & throttle roller.
You don't want to screw up this gap
Heart of Dixie
03-05-2013, 03:58 PM
#1693 |
Where we riding to?
Oddometer: 3,521
03-05-2013, 03:59 PM
#1694 |
Oddometer: 20,417
Thanks Rob - so you didn't actually remove that nut I mentioned then ? The one at the end of the shaft - it just looked like it had had a spanner on it at some point.
I did fix mine by pretty much doing the same thing, I was just curios if I was missing something.
03-05-2013, 04:05 PM
#1695 |
Loftin' the wheel
Oddometer: 152
Stepper motor
I thought you just pulled the rubber boot back and spray some dry lube in there?
