Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-05-2013, 04:41 PM   #1696
bross
Where we riding to?
bross's Avatar
Oddometer: 4,598
Originally Posted by motomart View Post
After a dusty few days of riding the bike developed the stalling issue. Tried power washing, did not help. Sprayed the stepper motor area with 10w40, the bike fired up with a rough idle which made me think I just F it up. After about 30 sec the idle was back to normal and no more staling. That was 14,000 km ago.
The motor oil must last a lot longer than WD40.
Old 03-05-2013, 05:18 PM   #1697
ducnut
Oddometer: 3,320
Originally Posted by bross View Post
My wife's Street Triple makes the same noise. Must be the 675s not the 1050s and since our 800s are based on the 675???
My Tiger 1050 and Daytona 675 have/had the same noise. It's supposed to warm up, toward the end of the week. I'm pulling the forks for servicing and am going to dig into the noise source. I'll report back.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-05-2013, 05:21 PM   #1698
motomart
Oddometer: 89
Ahhh WD40
motomart is offline   Reply With Quote
Old 03-05-2013, 09:05 PM   #1699
Chinookmark
Oddometer: 278
Just throwing this out there for the sake of discussion...
Every other bike on the planet just has an idle adjustment screw. No stepper motor. Has anyone considered removing the stepper motor and installing a traditional idle stop?
I know it would lose that cool anti-stall feature, but it would eliminate all the seized stepper motor problems.
Again, I'm not saying the stepper motor is so bad it needs to be removed. Just proposing a "what if" question.
Chinookmark is offline   Reply With Quote
Old 03-06-2013, 12:17 AM   #1700
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,813
This is odd because the 1050 does have a stepper motor system the same or similar to our 800s. http://www.worldoftriumph.com/triump...lock_03=610301
The 955 versions have an "Idle Air Control Valve" (IACV) instead of a stepper motor. http://www.worldoftriumph.com/triump...&block_03=9785 Different system altogether.
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 03-06-2013, 03:02 AM   #1701
KildareMan
KildareMan's Avatar
Oddometer: 681
The stepper motor isn't "seizing". It's length of travel is being limited by gunge buildup. Squirt of WD40 & turning ignition on/off a couple of times generally does the trick in removing gunge buildup - for a while anyway. Best solution - clean and lubricate with a dry ptfe type lub.
KildareMan is offline   Reply With Quote
Old 03-06-2013, 03:03 AM   #1702
KildareMan
KildareMan's Avatar
Oddometer: 681
Yup both my 1050 & now 800 both make the fax noise
Old 03-06-2013, 03:20 AM   #1703
Hardhead
Hardhead's Avatar
Oddometer: 2,427
I had the idle problem with mine a while ago so I took it to the dealer. I wanted to the dealer to see it so it was an "official" problem. First of all they said they'd never heard of the problem but in the end just sprayed it with WD40 and said it was fixed. I haven't put a lot of km on it since (maybe 200km) but there haven't been any problems.
You think hiring a professional is expensive, wait until you hire an Amateur!
Hardhead is offline   Reply With Quote
Old 03-06-2013, 05:57 AM   #1704
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
The throttle roller & stepper motor arm need some lube. WD40 is ok in a pinch, but cable lube or something that doesn't dry up is better.
I never removed that nut at the top of the stepper motor.
Yes. The Daytona guys have figured out a Manuel Screw idle adjustment to replace the stepper motor. I don't have time to search right now. It's on a different forum
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 03-06-2013, 08:33 AM   #1705
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,710
Suspension Mods and Sources
After looking though the existing XC threads on ADV, and searching the Beasts and other Tiger800 forums for information, I've started a thread to reference 800XC suspension mods, reviews, sources, etc. in the hopes of pooling resources for the available options.
Having read AV-Mech's "Hobbes" thread and his praise of the improvements gained from valving and spring upgrades tuned to his weight and riding style, this would be how I would like my forks (and shock) to behave. The business that did his mods no longer exists.
If anyone else has made improvements to their suspension please consider posting up the details of who, what, where, and how you like it in the linked thread above.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 03-06-2013, 10:04 AM   #1706
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
There was one at some point. I made this sticky thread a while back that had a link to one but then the mods started mushing things together and lots of information was buried. So, the sticky is now basically a waste.
http://advrider.com/forums/showthread.php?t=841372
I am running stock forks and Ohlins rear. I don't have much time of it yet but I can only imagine how sweet ass it will be!
fbj913 is offline   Reply With Quote
Old 03-06-2013, 10:23 AM   #1707
C5INC
Oddometer: 53
Stepper Motor Cure?
I know this has been discussed at length with cleaning and greasing being the most common cure for stepper motor issues. 5000 miles on my 2012 and it's time for my second motor! My dealer tech is pissed at Triumph telling him they don't have a fix and really don't care! When I get my bike to him he wants to see if there is any way to cut up an old oiled foam air filter to wrap the motor to keep the dirt out. Might work. Anybody tried this?
Also, I wanted to set the idle speed up just a little but he tells me there is no way to adjust that. Is that true?
C5INC is offline   Reply With Quote
Old 03-06-2013, 11:01 AM   #1708
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,813
I think you can do that using TuneECU.
Old 03-06-2013, 11:35 AM   #1709
C5INC
Oddometer: 53
You would think the Dealer software would do it too. Frickin electro-gizmo bikes!
Old 03-06-2013, 12:07 PM   #1710
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,813
They probably can but it'd be out of spec. and if anything went wrong they'd be blamed.
Times are GMT -7.   It's 03:39 AM.
