Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 05-31-2013, 08:59 PM   #1906
some call me...tim
some call me...tim's Avatar
Oddometer: 279
I managed to get mine in without going to the airfilter, though it took me way longer than it should have. First I took out the air duct, thinking that was the snorkel, and couldn't figure out how the Uni filter was supposed to fit in there with the ABS module and all. Then I finally looked at a picture and realized my stupidity, after having removed the battery and whatnot. Once I figured out that I had more removal to do, it went a lot better. It was a little tricky getting the Uni filter installed just because there's not much finger room, but once I got the rear corner started in the hole in the airbox, the rest of it followed pretty easily. Definitely less of a hassle than getting to the air filter, but still not all that user friendly.
some call me...tim is offline   Reply With Quote
Old 05-31-2013, 09:36 PM   #1907
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,452
Originally Posted by levain View Post
I did mine the other day. I'd like to hear from others about this subject. Like you, I waited until I had time to swap the OEM filter as well. The UNI instructions say to just pop out the old snorkel and pop in the new pre-filter. I don't see how that is possible. Getting the rubber inside the airbox and around the lip with the little bit of space allowed?
Has anyone added the UNI filter without removing the standard air filter? Just seems next to impossible, but maybe not..
What the instructions didn't mention was to take out the cage that holds the stock seat in place (and covers the ABS) before pulling out the stock snorkel.
With the cage out, I inserted the three close sides of the Uni Filter. With those in place, I rotated the Uni in a counterclockwise motion in order to fit the last/far corner. When that popped into place, I rotated it clockwise into the correct position.
It took a bit of niggling to figure out, but it is done.
JG
live2ridetahoe is offline   Reply With Quote
Old 06-01-2013, 04:01 AM   #1908
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,261
JG
Good to hear. I was hoping this was going to prove to be an easily serviced item, but if it meant removing the oem filter that isnt so easy is it!
Click Here!
2012 Triumph Tiger 800 XC
2008 Yamaha WR250R
1971 Lambretta DL
levain is offline   Reply With Quote
Old 06-01-2013, 07:09 AM   #1909
live2ridetahoe
RN
Oddometer: 1,452
I believe the UNI is an easy to service item. Better to have to service that, than take the entire tank off to check your air filter.
The next time I need to check my air filter, I'm going to borrow one of the fiber optic cameras from the emergency airway/broncoscopy cart at work. I'll be able to look in there without removing anything except the UNI!!!
JG
Old 06-01-2013, 07:36 AM   #1910
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,750
Firstly, you do have to remove the cross brace just in front of the battery box to get access to the snorkel.
I've probably posted these before but here goes again.
I had my pre-filter on for about 6000 miles and it looked like...
I did, however, find that the air filter was still pristine...
So once you've got the pre-filter in place you shouldn't have to worry about the stock filter for many, many miles. There was some dust at the bottom of the airbox but that had come up through the drain hole.
Now, whilst I had it all apart, I experimented with methods of removing the pre-filter. I found that if you push a blunt flat blade screwdriver mid way along the top of the rubber part and wriggle it so that it goes under the edge of the airbox, the rubber is flexible enough to push it right through. You can then hook the whole thing out.
I also found that a bit of LM grease around the rubber makes it easier to fit. And you can use that same blunt flat blade screwdriver to push the last (hardest) bit into its seated position.
Also, I realised that the reason for the pre-filter being so dirty was that it was getting sprayed with crap from the chain. If you look at this photo, you can see the chain through the gaps in the top left.
So, I fashioned a cover out of modeling PVC to shield the filter...
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 06-05-2013, 01:44 PM   #1911
GuiltyParty
drifter
GuiltyParty's Avatar
Oddometer: 318
Great idea, I checked and found the same thing after servicing mine today.
Also mine crapped itself during the service. It's been having some dodgy starts and today as the throttle bodies were getting adjusted it stalled. When we went to restart it the instrument panels blinked and went kaput.
We checked all the fuses and the obvious stuff but couldn't find the cause. After a bit more investigation we found the culprit - a dodgy solenoid fuse located under the battery. The drain hole must have become blocked and water built up causing it to corrode. How so much water got in there I have no idea because I'm doubly careful when I'm washing it that water doesn't get up in there.
Mention of a 30A fuse in the service manual is only a foot note and to me easily overlooked so luckily it happened in the shop otherwise it could have left me stranded.
Triumph Tiger 800 xc
Walkabout in Russia and Central Asia http://www.advrider.com/forums/showthread.php?t=877576
GuiltyParty is offline   Reply With Quote
Old 06-05-2013, 09:29 PM   #1912
ilbiker
Oddometer: 160
Look around the forums and find the relocation process for moving this up and out of the water tray. Worth it...
I don't suffer from insanity, everyone else around me does...
ilbiker is offline   Reply With Quote
Old 06-05-2013, 11:06 PM   #1913
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,648
i'm sure that mod would even help those that do not do the pre-filter.
looking at the previous picture of those 2 stock side by side filters,
you can see the same black road grime. with that shield, i bet stock filters would stay alot cleaner.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 06-06-2013, 02:32 AM   #1914
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,750
I'll bet you're right. The grime suspended in the air must get sucked into the snorkel.
Old 06-06-2013, 02:35 AM   #1915
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,750
Craig, check out this thread http://www.tiger800.co.uk/index.php/....html#msg63388
Page 4 shows the state of my solenoid http://www.tiger800.co.uk/index.php/topic,4035.30.html
My photos http://s396.photobucket.com/user/bla...?sort=3&page=1
blacktiger screwed with this post 06-06-2013 at 02:50 AM
Old 06-06-2013, 03:57 AM   #1916
stevedo
Oddometer: 42
Looking to buy a UNI Filter pre-filter in the UK. Does anyone know if/where they can be purchased. if not in the UK, where would be best/easiest to source one?
Steve
stevedo is offline   Reply With Quote
Old 06-06-2013, 04:20 AM   #1917
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,750
Steve
Australia. I was lucky as a friend was down there on holiday and was able to bring one back for me.
Old 06-12-2013, 03:32 AM   #1918
KildareMan
KildareMan's Avatar
Oddometer: 658
Made my shield from a 2L plastic milk container. Yours looks neater.
KildareMan is offline   Reply With Quote
Old 06-13-2013, 11:57 PM   #1919
GuiltyParty
drifter
Oddometer: 318
Fantastic, thanks for re-posting. I'll have to see if I can get it relocated while I'm in Tbilisi.
Remember we had a short chat about the bike cutting out? http://advrider.com/forums/showpost....postcount=1625 & http://advrider.com/forums/showpost....postcount=1626 and we figured it might have something to do with a short or the solenoid. Now the solenoid is clean again and rest of the bike is checked I thought that would be the end of it but it's done it twice on this trip now and concerning me.
The first time it happened is right at the end of this video after some pretty heavy clutch use - not exactly riding to Triumphs recommended specs but I would expect the bike to be up to the task. I gave it 10 minutes to cool and it fired back up as though nothing had happened.
The second time it happened was in heavy traffic going uphill in Istanbul in hot weather. Bike stopped as though I'd stalled it and again I couldn't start it and had to let it sit until it cooled a bit. I wasn't crawling with the traffic and slipping the clutch, just normal use.
The third time was again going uphill in Turkey in hot weather and again not much clutch use, just normal operation.
As you know I have a fair bit of weight on the bike - riding two-up with enough spares and belongings for a 4 month trip. I've also dropped the front sprocket to a 15 tooth which should have helped the situation. Twice the radiator has made some gurgling noises as though it was overheating and I've replaced the fluid, blown compressed air into the fins of the radiator and checked the fan and it's all ok. It hasn't made gurgling noise since. Second time it made the gurgling noise was in this hill climb
Any ideas what it could be? I think it must have something to do with the clutch getting too hot but I wouldn't expect this type of operation to be pushing the bike beyond it's limits.
Old 06-14-2013, 01:20 AM   #1920
bluesman
Oddometer: 3,330
what was temperature bar showing at that time?
bluesman is offline   Reply With Quote
Times are GMT -7.   It's 11:23 PM.
