Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 10-15-2013, 12:41 AM   #2296
Haggs
Tigre Verde
Haggs's Avatar
Oddometer: 134
Originally Posted by gqelements View Post
...so what's in your tool tube?
Tyre levers.......Learn how to fix your flats on the road,
You'll be better for it
2013 TIGER 800XC KHAKI
Haggs is offline   Reply With Quote
Old 10-15-2013, 08:22 AM   #2297
bross
Where we riding to?
bross's Avatar
Oddometer: 4,553
Your best friend for tire changes is "drop Center", learn what it is, use it and don't force anything.
Old 10-15-2013, 08:38 AM   #2298
btao
RIP Lilolita
Oddometer: 1,012
You can also use the tire iron with a stick or another tool under it just pushing down to break the bead.
Changing a tube really isn't that bad. Changing a tire is worse since my least favorite part is getting the second bead over. Tube is just break bead, pop one side over, pull tube out, replace, reinstall, air up, done. You can stick random objects in there to hold the tire open to get at the valve stem. I got most of my stuff from Harbor Freight but you need at least 1 good tire iron like a motion pro. The motion pro assorted pack is perfect.
_________________________
Current: '13 Tiger 800 XC, '09 Subi WRX, '11 405hp Sti (wifey's) Past: '74 Honda CB 360, '81 Yamaha 650 Special II, '01 Bandit 1200S, '07 Bandit 1250S
btao is offline   Reply With Quote
Old 10-15-2013, 08:52 AM   #2299
bross
Where we riding to?
bross's Avatar
Oddometer: 4,553
I bought one of those valve stem snakes, packs small, weighs nothing and makes a crappy job easier.
Sent from my iPhone using Tapatalk - now Free
Old 10-15-2013, 08:56 AM   #2300
btao
RIP Lilolita
Oddometer: 1,012
Ok, so my tool tube (small pelican case) contains:
Triumph pouch goes in John Deere tool tube, contains:
Basic allen keys, rear axle wrench, and basic spanners Chunk of foam and pieces of rubber matting
Spare nuts and bolts, metric
super glue
small rtv silicone tube
Zip ties, S, M, and really f'in big ones. Get really long ones because you can always cut them
Gorilla tape
Trail stand, adjustable
Pressure gauge
pump
Extra valve stem caps and valves and tool
Big hex key for front axle
Mini air compressor (metal one from HF) and powerlet adapter
Motion Pro tire lever with the bend in it
Two small pry bars, polished so they don't scratch(most used tool, good for straigtening things and as tire irons
Safety wire
1" webbing, 15' (for towing or lashing)
Cargo net
Spare Tube
Patch kit
Vice Grips, flat, long jaws
Hex keys that aren't in the standard kit
Knife
Tri Flow mini lubricant (for stepper motor someday, good for now)
And I never leave home without my Victorinox multi-tool.
Usually what happens is you either bend something or get a flat tire.
Old 10-15-2013, 08:57 AM   #2301
btao
RIP Lilolita
Oddometer: 1,012
I know, I know... keep forgetting to get one
Old 10-15-2013, 11:57 AM   #2302
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,699
+1
Once I removed the plastic covers from the Slime compressor there is now room in the zipper case for a can of patch glue with a brush (the glue tubes always dry out), patches, the snake mentioned above, and the patch rougher/roller tool.
I also carry front and back tubes, tire irons and a plethora of other stuff.
Much like carrying rain gear, having stuff along to fix things significantly reduces the need for these things. i.e.: It then seems to seldom rain and flats are fewer and farther between.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 10-15-2013, 03:07 PM   #2303
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,170
I have one, never used it. I saw a video where you just pop up the opposite side to the open side (hard to explain) and the valve stem practically falls into the hole.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-16-2013, 11:42 AM   #2304
vanjoosten
Oddometer: 97
Tiger Mud Flap
One of the off road features the Tiger lacks is a basic mud flap to protect the rear shock. I didn't see that anyone was selling one, so I ended up making one with a Honda part, and some angled aluminum. The nice thing about the stiffness of the Honda flap is that it clears the swing arm throughout it's entire range.
vanjoosten is offline   Reply With Quote
Old 10-16-2013, 11:58 AM   #2305
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Great job Van, looks factory fresh!!
Dubl-A is offline   Reply With Quote
Old 10-16-2013, 12:17 PM   #2306
btao
RIP Lilolita
Oddometer: 1,012
That looks like the best mod yet, and it doesn't rub! Can you give us the dirty details so we can shamelessly copy it??
Old 10-16-2013, 12:24 PM   #2307
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,778
Early adopters were doing that two years ago.
http://www.advrider.com/forums/showp...&postcount=125
Photo #8 in my post. Acerbis universal mud flap.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 10-16-2013, 12:28 PM   #2308
vanjoosten
Oddometer: 97
You win?
Old 10-16-2013, 12:28 PM   #2309
y0y02369
y0y02369's Avatar
Oddometer: 1,213
pardon my ignorance but that is the point of the cable lever snakes...? is it to prevent the lever from shooting up into the case in the event of it falling on that side?
Drive?! Why?! Cars have too many wheels... just makes me feel... awkwardly stable... I'll ride thank you!v
Not knowing where you are going in part of the adventure! :loll
Daisy the Tiger and Frenchie
y0y02369 is offline   Reply With Quote
Old 10-16-2013, 12:39 PM   #2310
vanjoosten
Oddometer: 97
It's a 2014 Honda CRF150F AirBox Flap. The aluminum and hardware I got from Home Depot. There may be other (better/wider) flaps that do the same thing including the Acerbis blacktiger used. The aluminum is L shaped but needs to be pinched a little to get the angle just right. Also, I had to file the backs of the rivets to allow enough clearance for the bolts inside the battery box.
Times are GMT -7.   It's 02:51 AM.
