Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 11-13-2013, 07:07 AM   #2356
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
Originally Posted by Dubl-A View Post
Attempt a tube swap which is what you'd be doing in the field in your garage but leave the tire changing and balancing to the shop. I take the wheel off and get charged $30 per wheel for mount and balance. It just doesnt make sense to buy all these tools if you're not doing it on a regular basis for yourself and other riders
That's a lot of cash every time. This side of the pond we normally get free fitting on a loose wheel when we buy the tyre from a tyre depot type place. However, I buy my fronts online for the XC. If I were to take it there for fitting they'd charge about 15 so 22 for the balancer will pay for itself quite quickly.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 11-13-2013, 09:32 AM   #2357
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
I hear ya and I'm pretty sure you got both myself and Kilo by some years in experience. Right now I'm averaging a tire swap every 18-24 months so I still cannot justify the loss of garage space on a tool I use so infrequently. That may change in the future though
Dubl-A is offline   Reply With Quote
Old 11-13-2013, 09:51 AM   #2358
KiLO
Adventure Cafe
KiLO's Avatar
Oddometer: 341
Thanks everyone. And yeah, Dubl-A is right, I've done a total of 2 tires in my career, so I am leaning toward having them mounted professionally and doing the tube change in the garage. I don't know that I'm ready to tackle the balancing.
'09 Triumph Thruxton | '13 Triumph Tiger 800XC
KiLO is offline   Reply With Quote
Old 11-13-2013, 09:52 AM   #2359
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,232
Used to be when I lived in the lower 48 I got free mount and ballance when purchasing the tires from the shop. Not so much anymore. So with three bikes in the garage, I bought the changing stand and a ballance stand. Takes a bit of time, especially when mount Mitas Dakar tires.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is offline   Reply With Quote
Old 11-13-2013, 10:31 AM   #2360
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
That really is the easiest part. Once you've got the wheel mounted on the balancing stand it'll settle with heaviest part at the bottom. Give it a couple of gentle spins to make sure and add balance weights opposite and check again. Gravity does all the hard work for you.
Old 11-13-2013, 11:29 AM   #2361
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,250
Easiest, but can be the more time consuming portion. It helps to get both the large ans small weights.
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is online now   Reply With Quote
Old 11-13-2013, 02:23 PM   #2362
Bikenstitches
Bikenstitches's Avatar
Oddometer: 539
Pfft- balancing stand? make one-
A couple pair of old bearings from in-line skates or skateboard
plus a bit of hardboard, and some nuts and bolts
presto-
Tom
Bikenstitches is offline   Reply With Quote
Old 11-13-2013, 11:03 PM   #2363
y0y02369
y0y02369's Avatar
Oddometer: 1,210
presto-
Well aren't you fancy?! Lol I was actually thinking of making something similar too cheap to buy one.
Drive?! Why?! Cars have too many wheels... just makes me feel... awkwardly stable... I'll ride thank you!v
Not knowing where you are going in part of the adventure! :loll
Daisy the Tiger and Frenchie
y0y02369 is offline   Reply With Quote
Old 11-13-2013, 11:30 PM   #2364
onetire
onetire's Avatar
Oddometer: 57
presto-
Well done. I did a similar make "your own tool" and have used it for years. It worked for more than 2 dozen tire changes. I sold my old used up bike for a new one. Now I have noticed in my tire changes that the rollers do not spin, but the newer axle bearings do the spinning. So maybe for someone just starting out, there may be no need to make something other than put the wheel on axle stand and spin it. When the bearings get stickier, then we will need to make the tool. Thank you for sharing. I have learned so much from this forum from all of you. Just trying to make it easier for some others.
onetire is offline   Reply With Quote
Old 11-14-2013, 03:38 AM   #2365
Bikenstitches
Oddometer: 539
I made this set when I owned HDs, as they used tapered roller bearings and unable to set up on a stand.
Tom
Old 11-14-2013, 06:52 AM   #2366
ducnut
Oddometer: 3,317
In using my No-Mar balancer versus wheel bearings, I've come up with different balance values and placement. I've found if I allow both sets of bearings to freely turn, I can't get the assembly balanced. When I have a case where the wheel bearings are spinning, I use a piece of duct tape wrapped from the wheel hub and around the balancer's rod. This ensures the wheel bearings aren't altering my balance. I sell tires out of my home shop and can't begin to say how many set of tires I've done.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 11-14-2013, 08:06 AM   #2367
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
All very well if you've got that stuff laying around. I don't so I'd have to buy the bearings and the rest so for me 22 ready designed and made was a good deal. Plus it's a good solid steel construction so It's going to last my lifetime.
Old 11-14-2013, 10:12 AM   #2368
KiLO
Adventure Cafe
KiLO's Avatar
Oddometer: 341
Am I the only one that gets annoyed when multiple people quote a post with several images, so those images appear several times in the thread?
Sorry, rant over... As you were
Old 11-14-2013, 10:34 AM   #2369
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
No, you're not alone which is why I didn't quote the photos in my reply.
Old 11-14-2013, 10:38 AM   #2370
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,698
There are already bearings in the hub.
Just place the axle ends on a pair of jackstands and I'm good to go for static balancing.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Times are GMT -7.   It's 03:58 AM.
